My Canon IR ADV c5035i is displaying error code E000075-0003 and I can not make copies. Please help!
Cogz
  • 1326 Answers
SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
Posted on Mar 16, 2008
SOURCE: Canon IR 8500 Error code E000069-0000
You have a high-voltage leak to the transfer corona. This could be due to several different things, usually it's a dirty corona, maybe excessive dust or toner in the corona assembly. Toner conducts electricity and can leak voltage from the transfer corona to the frame. It may also be the "end-blocks," the thing in the back of the machine into which the transfer corona plugs when you close the drawer and lift up on the green handle. These crack and can cause intermittant failure.
I would start by taking a can of air and thoroughly blowing out the corona assembly and see what that does for you...
Posted on Aug 05, 2008
  • 199 Answers
SOURCE: Canon IR 3300 switchs on it displays the Erro E000602-0003
replace hard disk drive
Posted on Feb 15, 2009
  • 59 Answers
SOURCE: canon IR 2200 error code E000002-0000
It's to do with the fixing unit (hot bit) left hand side. Make sure theres no paper **** any where near it. If so switch off then on.
If not it looks like there may be a fault with the fixing film or may just need the error resetting in service mode.
Posted on Mar 23, 2009
SOURCE: CANON IR C6800 ERROR CODE E000078-0001
error code E000005-0000
Posted on Aug 26, 2010
Canon ir adv c2030 error code e000713-0005
Error code was resolved by changing Bit 1 on SW2 located on the Finisher Controller from a '1' (ON) to '0'(OFF).
Jan 24, 2017 | Canon Office Equipment & Supplies
How to solve the error code E00001-0010 canon iR-ADV 6255i
Fuser noise and intermittent E001 code error :
The upper fuser roller section makes a noise and intermittently error code E001 occurs.
Nov 03, 2016 | Canon Office Equipment & Supplies
My canon iR c5185i displays error E000004-0401 please help me he solution
This is a fuser unit error, if powering off & on the machine the error doesn't clear then you will need to have the fuser unit replaced.
Aug 25, 2014 | Canon Ir-c5185i With Feed, Fax, Finisher,...
Error code E000005-0001 cannon ir-adv 6055
I have a problem with my machine,
Canon IR 6570 with error code E000005-0001
beg for a solution
Nov 09, 2011 | Office Equipment & Supplies
Canon ir c3200error codes
There are many error codes which the iRC3200 has, please be more specific.
i.e. copy the exact error code displayed.
Sep 23, 2010 | Canon imageRUNNER C3200 Copier
Error code E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Jun 01, 2009 | Canon iR 1600 Laser Photo Printer
Canon IR 400
i have canon ir405 cpier it dispays error code E243 please help me sir
Jun 01, 2009 | Office Equipment & Supplies
k24674
jasbo
jasbo
