Question about Canon IS Binocular
Canon 10 X 30 IS HOW TO REPLACE BATTERY COVER
Instructions to replace battery cover for canon powershot a2000 is
1) Purchase replacement battery cover.
2) Remove original battery cover
3) Attach new battery cover.
Jun 23, 2017 | Canon Cameras
How do i replace lense cover on a canon sx170 is?
Since I cannot see your pieces, I can recommend actual replacement. You can Google your camera's make/model with replace lens cover and pick from the listings. You can also go straight to Canon USA and search their store as they have replacement lens covers. I did this here for another customer as an example.
Lens Caps ' Canon Online Store shop.usa.canon.com/shop/en/catalog/.../ef-lens-accessories/lens-caps
Canon Tips & Tricks When using a lens with IS while on a tripod, ... Canon Tips & Tricks That hole in your battery cover has a purpose! ... Lens Cap 14mm f/2.8L II.
Jul 19, 2014 | Canon PowerShot SX170 IS 16 Megapixel...
How to replace Canon powershot sx150is internal battery
Hi! Doesn't the instruction supplied with the camera has this information? Anyway you can try to find it here Canon Digital camera user guides and owners manual
Just choose the needed model.
Mar 27, 2014 | Canon PowerShot Cameras
Where has the replacement battery CR1620 must be placed?
1) Open the main battery compartment
2) Remove the battery tray
3) Inside the battery compartment directly behind the LCD screen there is a small cover about the same size as the CR1620.
4) Remove the cover
5) Replace the battery
6) Replace the cover
7) Replace the battery tray
Jul 20, 2012 | Polaroid Battery Grip for Canon EOS-7D...
I have a Canon Sure Shot Tele dated around 1993. Its a film camera and I'm having trouble finding where to replace the battery.
If it's the TELE/MAX, the battery cover is on the left end of the camera (as viewed from the back). Slide the cover toward the back to open. It takes one CR123A battery, positive terminal up.
If it's the TELE, the battery cover is on the right end of the camera (as viewed from the back). Use a precision screwdriver to unscrew the two screws. Hook your thumb against the side of the battery and lift upward, then pull the battery out. It takes one 2CR5 battery.
Do not replace the battery when film is loaded.
Jan 05, 2011 | Canon Sure Shot 80 Tele/Date 35mm Point...
How do I remove the battery door from my ixus 75? I need to replace it as it slides open and powers off the camera - the tiny catch near the hinge point has snapped off somehow. I can get a new door from...
hi..
1. Turn your device off and remove the battery cover and battery
2. Remove the end-cover by pushing the cover away
3. Pull the bumper tabs up to separate the bumper from the device and remove bumpers
4. Snap new bumpers firmly into place
5. Re-attach the end-cover, re-insert the battery and re-attach battery cover..
thank u
rate me!!!
Jul 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Replacing a battery cover
Hi!
I have the same problem with my camera. Mind telling me where you got a new battery cover? :-) I need one!
Maybe you have already found out how to replace the cover, but anyhow, here´s what I think:
I have looked closely at the cover and it seems like you should be able to just loosen the only screw on the inside of the cover and then you should be able to just slide the cover off and replace it with your new one. :-)
Hope this helps! :-)
Nov 07, 2008 | Canon PowerShot S70 Digital Camera
Canon digital camera
Same problem here with broken battery cover door! Called Polaroid and NO they do not have these parts to replace....if the camera was under warranty Polaroid would have replaced the entire camera.....soooooo when you find out any info as to where to get the battery door list the info! Thanks! & good luck too!
May 22, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Battery cover replacement
First, replacement battery covers may be obtained from dealers in the USA - I got mine from San Diego Camera Solution who list the item on eBay. Haven't found a UK outlet, but I guess Leung's at Goodmayes would offer a repair service if you don't fancy DIY.
(Disclaimer that I have no connection with either company).
Not sure what Canon recommend, but the easiet way (worked for me) does not involve stripping the camera down. If you dissemble the old and new battery covers via the three little cross-point screws (see warning), then it is possible to replace the new cover around the original hinge assembly.
The advantage of this method - aside from not opening the camera - is that there are "spares" the bits that will get dropped (spring and screws) so that there is less time wasted trying to find them while effecting the repair!
The trickiest part is the sprung loaded latch, which must be installed with the spring partly compressed. Beware when first taking the covers apart and especially when refitting, because the spring will do its utmost to escape.
Sep 22, 2007 | Canon PowerShot A640 Digital Camera
Canon IS Binocular Logo
176 people viewed this question
Top Canon Optics Experts
old marine
old marine
TC CAMERA REPAIR.Com...
Are you a Canon Optic Expert? Answer questions, earn points and help others
