Question about Vivitek D510 Projector
Vivitek projector is locked in standby mode - Vivitek D510 Projector
Change module on Vivitek projector
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Apr 05, 2016 | Vivitek Lamp for H5085 Projector
Vivitek D326MX DLP, does no power up right away.
Almost certainly a faulty switch mode power supply. Since these are both complicated and dangerous for the inexperienced to play with, the best advice will be to take it to a service centre for repair. It's almost certain to be either failing electrolytic capacitors, or a high value startup resistor, or both, in the smps :o)
Apr 07, 2014 | Vivitek H1080FD DLP Projector
How do we connect the projector to the pc?
Hook up using the S-Video port, the VGA port, RCA port, or the RS-232 port. The USB port is not used for input on at least some of the Viviteks as per Vivitek Service"The USB port is not in input port. This is used for service only. Please use another input port such as RGB input. Regards, Vivitek Customer Service"
Hope this helps.
Aug 06, 2011 | Vivitek D825MS Projector
I cannot seem to link up my projector and laptop computer
Assuming that you have all the connections between the laptop and the projector already performed, you should check in you laptop's manual what is the key combination necessary to switch between normal mode and presentation mode.
For instance, some Dell laptops need you to press the function key (key marked with Fn in blue) and, while keeping it pressed, press also the F8 key (marked with CRT/LCD in blue) to cycle between the options.
Some HP laptops will need you to do the same operation, but now using the function key and the F4 key, to select between "Computer only", "Extended (dual) presentation mode" or "Projector only" modes.
If even with these indications you are still not able to make your laptop show its information through the projector, please send us more details on how you connected your laptop to the projector, as well as the brand and model of your laptop.
Hope this information can help you!
Mar 09, 2011 | Vivitek D825MS Projector
We are a conference facility with a large projection screen we have recently bought a Vivitek projector and we are having problems making the picture small enouhg to fit on our Theatre screen the further...
You can go to the Vivitek website and they have a handy distance calculator to help you know the correct distance to place your projector from the screen to achieve an appropriate size.
http://www.vivitekusa.com/calculator/calculator.html
Mar 07, 2011 | Vivitek D945VX Projector
Miss operation to launch "Control
When the control panel lock ON of the projector so that the projector can be operated only with the REMOTE CONTROL.
If you loos your remote control then keeping the POWER key on the projector control panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you press and hold the MENU key for about10 second when the power is on the lock will be released and "panel key lock" is automatically set to "OFF"
Feb 23, 2011 | Sony VPL-CX70 Multimedia Projector
When i turn on the video projector and send me this message"the panel keys are locked "
Your projector key panel locked you have two option to operate the projector
1 . Use remote control press MENU the menu window displayed.
use DOWN ARROW key and select SET SETTING.
press ENTER
use DOWN ARROW key to select PANEL KEY LOCK.
press RIGHT ARROW key to OFF the panel key lock
press ENTER and then press MENU key to exit the menu.
now you panel keys are working
2. If you loss your remote control then;
When the key panel lock is ON keeping the power key on the projector key panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you keep pressing the MENU key for about 10 seconds when the power is ON, the lock will be released and "panel key lock" is automatically set to OFF.
Feb 05, 2011 | Sony VPL-CS7 Multimedia Projector
I am needing to verify if this projector allows for a widescreen image and what type of bulb does it use?
hi,
vivitek D510 supports 16:9 ( wide screen) format also. it uses 180w projector lamp.
ok
Dec 27, 2010 | Vivitek D510 Projector
What is code lock for xr30x..???
When the projector is in standby mode, you can release the keylock by holding down ENTER and STANDBY/ON on the projector simultaneously for about 5 seconds.
Feb 11, 2010 | Sharp XR-30X Projector
Sharp xr-1x is stuck in standby mode. just
hold down the menu, enter, and down arrow buttons then press the on button. this will reset the lamp timer. if it's not working, you may have a controller issue (main board).
Dec 04, 2009 | Sharp XR-1X Multimedia Projector
Vivitek D510 Projector Logo
19 people viewed this question
Top Vivitek Office Equipment & Supplies Experts
Electro Med Services...
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
