Question about Sharp AR-5316 Advanced Digital Imager Copier
Hi-speed dryer motor
Not working
  • 163 Answers
Change the IC or STR of that motor board
Posted on Sep 27, 2007
SOURCE:
Fixing dryer. The start button won't "say on"the dryer turns on, but the start switch doesn't stay on, and has to be held/pushed for Speed Queen AGM479W2 the dryer to work.
well why didn't they come back and fix it?check the wires going to the motor or the switch in the motor is bad, basically you have to replace the motor.you can go here this guy really drags this video out but it can show you what's happening to your dryer.i know on ge dryers if this happens it's the belt switch that's bad and on the older whirlpool dryers it was usually a bad relay or a bad even heat board but you don't have any of these in your amana dryer,it might say speed queen but it's an amana when you look up the model number,i don't know if by shorting out the dryer it could have damaged the motor,i would call whoever worked on it and tell them it ran fine until they worked on it you never had this issue
https://www.youtube.com/watch?v=CaaqRXQERVc
Nov 18, 2017 | Dryers
My speed queen dryerit does'nt start at all. aem453
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 04, 2011 | Speed Queen Dryers
The dryer works, after a few minutes of running a noise is generated from the motor section. Looked a pulley, drum and belt, everything seems to be operating fine. It almost sounds like the motor is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Sep 01, 2010 | Frigidaire GLEQ332A Electric Dryer
Dryer does not heat. Electric ignition does not "spark" lighting
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 04, 2010 | Speed Queen AGS28AWF Gas Dryer
Roper dryer takes a minute to start then shuts off 2 minutes later
his is probably the motor going bad. The sensors wont cause this to happen. The start switch either, replacing all the sensors in the world wont make the motor be good again. But their is something you can do to try and make the motor last a while longer,their isn't any holes to oil the dryer motor so you must make some,using a 1/8th inch drill bit make a hole in either end of the motor where the bearings are (taking care not to hit the shaft), then add some hi temp oil such as zoom-oil, (dont use WD-40) and work the motor free as you can by hand. If this frees up the motor it may go a while longer. Also oil the rollers and check the slides to make sure they are not pinching and stalling the motor. If the motor can't reach top speed it will get hot,overload and stop.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 08, 2009 | Roper REX5635E Dryer
The Kenmore dryer worked for one load, pushed start button for next load and it makes a hum noise at the start button and won't start
This is probably the motor going bad. The sensors wont cause this to happen. The start switch either, replacing all the sensors in the world wont make the motor be good again. But their is something you can do to try and make the motor last a while longer,their isn't any holes to oil the dryer motor so you must make some,using a 1/8th inch drill bit make a hole in either end of the motor where the bearings are (taking care not to hit the shaft), then add some hi temp oil such as zoom-oil, (dont use WD-40) and work the motor free as you can by hand. If this frees up the motor it may go a while longer. Also oil the rollers and check the slides to make sure they are not pinching and stalling the motor. If the motor can't reach top speed it will get hot,overload and stop.
Sep 12, 2009 | Kenmore 63942 Dryer
DRYER WORKS 1 MIN. THEN SAYS PAUSE ON IT AND WON'T DRY THE CLOTHES
Sep 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Maytag neptune dryer mde5500ayq replaced old motor with new motor starts up first time alright I turn off and it will hesitate to restart. most times it will not restart. Humms then kicks out. I have no...
Compare the wiring connections on both motors. They may be marked. They may be different. Careful examination will determine the start and run wires. Other wires turn on the heat once the motor reaches running speed. The thermal fuse for the motor is internal and unservicable. The hi limit sensor will control the heat, but will not necessarily turn off the motor.
Apr 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
GE Profile Electric Dryer, Blower nt getting up to speed
You need to replace the blower motor. It says you are having temp problems because the blower is quitting and the heater is overheating.
Jun 01, 2008 | GE Profile Harmony DPGT750EC Electric...
May Tag Neptune Dryer
check for an open door interlock. the centrifugal switch inside the motor may not be coming up to speed to keep the motor turning. the door interlock is part of the seal-in circuit to the motor.
Aug 28, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Sharp AR-5316 Advanced Digital Imager Copier Logo
26 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
