Xerox 5222 Hello.Please help me. I can't print xlsx documents from windows7.Any other document is printed.Thank you
    Champion:
  • 219 Answers
Be sure that the sheet is unprotected. Then highlight and choose to print highlighted selection.
Posted on Oct 18, 2013
  • 8 Answers
SOURCE: xerox 5400 missing letters
Go to the Xerox website go to support and drivers and DL the newest Driver for the Product
Posted on Dec 29, 2008
  • 86 Answers
SOURCE: Problem with printing document footer text on RICOH SP C811DN
Check the paper size settings and orientation of the driver from the Control Panel, and that match to the paper size in the printer's trays.
Good luck and please rate me, thanks.
Posted on Feb 12, 2009
  • 684 Answers
SOURCE: Document in queue won't print.
In this case what i would request u to do is:
1. Let the Printer be Connected to the Computer......
2. Click on start then Click on Run or If Windows Vista Type Services.msc Under the Run Window if XP,Under Start Search if Vista.......
3. On that Services Local Window u need to find Print Spooler just Double Click on that and Click on Stop..........
4. Now let that Window still be Open now click on that start Menu Click on Run If XP........
Type in "Spool" and Click Ok...........
5. Double Click on Printers and Delete Each and Every File Inside the Printers Folder...........
6. Now Close this Window and now u will be back to the Print Spooler Window now u can click on Start under the Print Spooler....
Now Try to Print Will Work Fine....................
Good Luck :)
Posted on Mar 04, 2009
ramon_jleme
  • 94 Answers
SOURCE: print half of full page
If the printer starts to print and stop in the middle check the eletricity of your place, this may have a variation. If the printer prints a half page and give you the paper, with no jam, check the cartridges and then the main board.
Posted on Aug 13, 2009
  • 31 Answers
SOURCE: Trouble with my epson stylus c45 printer. PLEASE HELP!?
this is usually caused by clogged print heads, unfortunately epson is still one of few brands that still manufactures most of their printers with the heads built into the machine and thus upon print head clogging the printer must be taken in to be serviced or buy a new printer that does not have the print heads built in but rather built into the ink cartridges. hope this helps.
Posted on Sep 30, 2009
How to set the face up print in xerox workcentre 5875 printer
I am assuming you are using the document feeder, either way, usually found through the options one the menu once you select the copy tab. Select all the options you want applied to this particular job and then copy. If you wish for them to be permanent please go to Xerox's website and download the applicable manual - usually the system administrator's manual.
Xerox support for this model is located:
http://www.support.xerox.com/support/workcentre-5865-5875-5890/documentation/enus.html
Best wishes,
Joe
Aug 25, 2016 | Xerox Office Equipment & Supplies
Xerox 7132 printing dots after 35 pages
Check if it is with just one document or with all documents. Can also be coming from the job and not the printer
Apr 07, 2013 | Xerox WorkCentre 7132 Multifunction Color...
Error code 024-747 is given when trying to print a specific Word 2010 document although any other Word 2010 document seems to print without any problems. Can you tell me what this error message means and...
In my case was like when i tried to print MS Word or Excel document (Xerox WC 5020 & WC 7120) i had to set "Original document size" in Paper Type option as same as "Output document size" in Printing preferences - it should help.
Jul 22, 2011 | Xerox DocuPrint C4350 Laser Printer
White vertical lines down printed documents...
hello
you have to check the fuser film, it may be not good
regerds and dont forget to rate mt answer
Feb 19, 2010 | Konica Minolta PagePro 1400W Laser Printer
Hello my problem is, when I print a excel document, and I want more than one copy, example 5 copies from the sema document, only print one, what can at be? Thanks
I would try loading a different print driver. There should be a PCL6, PCL5 and PS print driver available for that machine. I would think the PS driver would work better with excel
Jan 06, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Everything prints on left half of page
First, are you using a factory Xerox cartridge and Xerox toner?
As to the document, are you getting the entire document printed or is the document simply cut off as if the printer cartridge is out of position?
Oct 19, 2009 | Xerox Phaser 6180N Laser Printer
Cant print Xerox Docucolor 240 with Creo CX250
its the problem of connecting cable.and other error 212 is for internal circuit board error.you will have to contact xerox service center and get the resetter for this online.or if its board problem you will have to order the parts.
http://www.office.xerox.com/multifunction-printer/color-multifunction/docucolor-240-250/sprt-enus.html
click the link directly and check out your areas service center or the nearest to your area.
thanks.
Please do rate the solution. Thank you for using fixya.keep updated. thanks.
Jul 19, 2009 | Xerox Office Equipment & Supplies
Print writimg ok,but very dusty black on both sides of paper
the supplier of the toner cartridge told me the drum must be cracked and he will supply me a new one.I appreciate your service and I recomment you for your assistant,thank you.
Dec 30, 2008 | Xerox Black Toner Cartridge 25000 Page...
Phaser 3200 only printing code, not actual document
Try downloading and installing a PCL language driver from the Xerox.com site for the phaser 3200. It looks like that could be a PostScript issue. Installing the right driver is very important anyway. If that does not help, try and copy paste the document in a new document and save first as the old document could be corrupted. If this does not help either lemme know and I think of something else.
Nov 11, 2008 | Xerox Phaser 3200MFP/N Laser Printer
My Xerox DocuPrint M750 printer will not print black text but will print colour
This is just a suggestion. I recently bought a Staples refilled cartridge and had to return it because it did not work. When returning it the Staples Rep said that 50% of the cartridges do not work and get returned. This was an astounding amount I told the rep. Means nothing to him but to you, you may need to return the black cartridge if it is or is not a refill and try it out again. Let me know if that works.
Cynthia Charczenko
Jan 15, 2008 | Xerox DocuPrint M750 InkJet Printer
26 people viewed this question
jasbo
jasbo
