Question about TuneUp Software Computers & Internet
My ford telster 2L 1993 l ten the key is not tening the engin
    Habit-Forming:
    New Friend:
  • 171 Answers
Maybe have problem,you can go to this Engine Repair Orland Park
Posted on Feb 23, 2015
Where is the imrc located on a 2002 ford f-150 xl?
P1518 - Intake Manifold Runner Control Malfunction (Stuck Open) The IMRC system is monitored for failure during continuous, key ON engine OFF or key ON engine running self-test. The test fails when the signal on the monitor pin is less than an expected calibrated range at closed throttle.
  • IMRC monitor signal circuit shorted to PWR GND or SIG RTN
  • Damaged IMRC actuator
  • Damaged PCM
An IMRCM PID reading approximately near 1 volt at closed throttle may indicate a fault
It's part of the intake manifold . View P1518 on youtube .
2000 150 4 2L V6 Fault Code P1518 IMRC
Sep 14, 2017 | Ford Cars & Trucks
I just had my car serviced and the service vehicle warning keeps alarming me how do I resetting thi? I have a vauxhall insignia 2l ecoflex on a 2010 plate
TAKE BATTERY LEAD OF THE BATTERY ,LEAVE FOR TEN MINS,GO BACK PUT LEADS ON .THEN PUT KEY IN DONT TURN ON JUST TURN TO POSTION BEFORE ENGINE TURNS ON , THEN 2 MINS TURN ON ENGINE ,BUT HAVE YOUR RADIO CODE AVAILABLE AS WILL NEED RESET ,THAT SHOULD DO IT,
Apr 09, 2015 | Vauxhall Cars & Trucks
L have got ford telster v6 ,everytime the engine starts to heat theres a hold light reflect on the dashboard and it cut itself everytime l get to th stop sign what may b the cause
it is a safety fixture for people like you, who do not respect gauges, if the lite come on is for a reason, too hot or nor oil pressure, well do that in some engine, obviously you did not respect the signs. that this make sense to you !!
Apr 14, 2014 | Cars & Trucks
Workshop manual for mazda v6 dohc 2L
could be fuel pump or filter,weak spark,dirty air filter.
Dec 04, 2013 | 1993 Mazda 626
Supinten belt on a 2002 ford escourt zx2 2L
Sorry for the delay. I am personally going back to answer your unanswered question.
I do not know if you still need the answer, but I am going to answer it in case you still do.
Click on the following direct Link. It has the Serpentine Belt Diagrams that you will need for your specific engine size and options (AC/No AC...etc).
http://www.2carpros.com/car_repair_information/year/2002/make/ford/model/zx2/2002_ford_zx2_drive_belt_routing_diagram.htm
Nov 10, 2009 | 2002 Ford ZX2
I need a diagram for a 1993 ford escort serpentine belt (1.9) w/air
FORD ESCORT - 1993 - L4 1.9L 116ci GAS FI N J
Belt Routing Diagram Alt., P.S., Comp., Idler & Tens.
5060535 Alt., P.S., Comp., Idler & Tens. Additional Info: Metric No : 6PK1360 Effective Length : 53.50 in. Top Width : 0.82 No. of Ribs : 6
I hope help you with this (remember rated this help) Good luck.
Sep 18, 2009 | 1993 Ford Escort 4 Door
I need the security code for 95 ford telster head
Remove the radio from the dashboard and quote the SERIAL NUMBER found on a label on the casing.
It should begin with L ,C or M or just plain digits
Sep 08, 2009 | Car Audio & Video
Problemas con la bateria,puedo auxiliarlo con otro carro y como puedo probar si es la bateria o el alternador el del problema
Tenes que checkiar la bateria con un metro. Si el auto esta andando y hay menos que 13.5 volts, es el alternator. Si cambias el alternator. Tenes que checkiar el batteria, porque si el bateria esta mal,puede fallar el alternator nuevo.
Jul 26, 2009 | 2008 Ford Fusion
Computers & Internet Logo
74 people viewed this question
Top TuneUp Software Computers & Internet Experts
castletech
castletech
Carlos L. Burgos
Carlos L. Burgos
Julie Clark
Julie Clark
Are you a TuneUp Software Computer and Internet Expert? Answer questions, earn points and help others
