Question about Velodyne CHT-12 Subwoofer
Sub-woofer does not turn itself on in 'Auto' mode (signal driven)
I constantly have to switch it off then on again, and when I turn it on again the next day, it will often not turn itself on although it is still in 'auto' mode. Also, The sub-woofer will start humming at a very low frequency at any time sporatically after I have shut down my home theater system. I manually have to shut down the Sub to stop the humming. Thanks, Claude Hamel claude.hamel@pwgsc.gc.ca or landbaron13@295.ca Qu?bec, Canada 1-819-457-4985 Model CHT-12
  • 124 Answers
For the "auto on" problem.
These will sound very basic, please go with it.
On your signal source, make sure you have the sub set to on.
If you can adjust the output setting on your source, turn this up.
Adjust the volume setting on the sub lower to mach the volume of the main speakers.
You may need to make these adjustments a few times to get them working.
On the hum and noise problem
Check your power outlet for the sub, make sure the polarity is correct. I have found this to not always be right. Also what is on that same circuit. Things like the fridge can cause a lot of noise on the power line. Next check your connecting cables, are they of good quality? Are they running next to anything that may cause interference? Also check you connections to the signal source. Cable and dishes are known for ground problems.
Posted on Jan 04, 2009
    Problem Solver:
  • 9 Answers
Expert Technician is required: -you have a problem at the signal detector section that needs to be Fixed. Good Luck Toufic Malek
Posted on Sep 28, 2007
How to splice a sub-woofer to speakers
Normally the sub woofer is driven by a separate amplifier, unless the main speakers, such as in a pro audio setup have a special LF out set of terminals on the back of the speaker cabinet, in this case there is a hi powered low pass filter, fitted in side the speaker to route the LF energy to a sub woofer. Else you need a line lever LF signal spliter and a power amplifier to connect a sub woofer.
Jan 26, 2017 | Audio Players & Recorders
My subwoofer keep showing a red light when i switch it on, could it be a fuse fault?
Probably not. The red light indicate idle mode. The woofer might have an auto-sense switch. When activated the subwoofer turns on when an audio signal is sensed at the subwoofer input.
Such switches often have three positions:
Idle (Somewhat off, but not quite)
Auto (Turns on the woofer when audio signal is detected)
Allways on. (The woofer is allways on - you might hear humm in the woofer when no audio signal is present)
Apr 24, 2016 | Audio Players & Recorders
My wireless subwoofer keep cutting off and coming back on when the music or movie is playing
Some/most Sub Woofers have a Switch that turns them Off/On/ or Auto. On Auto, the Sub only turns on when there is a signal present. ( sound coming into the Sub ) When there is no signal, the sub goes into standby mode. Wireless subs may be made to be in standby mode as the default.
Dec 21, 2014 | Audio Players & Recorders
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
Do i have to have the sub-woofer in order for my logitech X-230 speakers to work with my computer?
Certainly any large speaker itself cant be used with
very weak computer out signal
The signal should have power amplification in addition to
voltage amplification to energise large speakers
Oct 09, 2012 | Audio Players & Recorders
Htddw7600, brand new, sub amp is not working, only way to get any bass sound is to unplug the sub cable from back of main amp and touch it on side of sub out port.
H?,
You have a very good system...one of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2)..in order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
BASS-OUT
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
sources.
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
SML).
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Audio Players & Recorders
I have a sony HTDDW7600, i cannot get the dedicated subwoofer amp to work. The fan is running on it, but for some reason the only way i can get it to do anything is to unplug the cable that goes from the...
H?,
Hope this helps!
BASS-OUT
sources.
SML).
Jun 23, 2011 | Sony MUTEKI HTDDW1600 Theater System
I lost my remote control and I want to turn on my sub woofer manually through my receiver. How do I turn on my sub woofer.
Perhaps I misunderstand the question.
Depends on the Sub. Most powered subs will go into standby mode in the prolonged absence of a signal. Then they wake up when you play something.
Or are you saying you need to Enable the Sub, as in setup? Remote probably required for anything like that.
Dec 02, 2009 | Aiwa AV-D58 Receiver
No signal from sub connected to NAD T760 in test mode.
Try using front pre out to the sub from the receiver. the crossover is in the sub anyway. If this works change your settings on the receiver and test again. If sub is still inop, could be an internal issue with the sub amp. Does your sub amp have an on/auto/off switch or light? check that as well. Hope this helps, if you need further assistance, send a reply and I'll help some more
May 24, 2009 | NAD T760
Sub-woofer Malfunction
sub can be detecting signal from your amp. maybe your amp has some small output when in standby mode. some amps throughput signal from satellite boxes when they are supposed to be off.
try shutting off that signal source as well.
good luck
mark
Dec 28, 2007 | Sony SA-FT1H TV Speakers
Velodyne CHT-12 Subwoofer Logo
649 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
