My touchpad is not detecting as well as not working after the installation of window
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 57 Answers
It might be happen because the touch pad drive is not installed properly or might be because of the Windows files are not installed completely, You can try to install Touch Pad drives from Manufacturer website if it will not work so you can also try to install Operating system again.
Posted on Oct 18, 2013
Touch screen not working
The touchpad on the Acer Aspire is built into the notebook itself, which makes the device much harder to troubleshoot or replace. While you can connect a universal serial bus mouse to the notebook if the touchpad becomes unresponsive, attaching any external device reduces the notebook's portability. Although hardware failure can cause the touchpad to stop working, most device-related problems are due to software settings or other conflicts.
Hardware Conflict
Peripheral devices connected to the Aspire can interfere with the integrated touchpad. Disconnect all of the external devices, except for the power adapter, that are connected to the Aspire; then restart the computer. Test the touchpad after booting into Windows. If the touchpad responds, a hardware device is interfering with the pointing device. Reconnect each device one by one to the notebook, testing the touchpad throughout. If the pointing device stops responding after connecting a particular device, the component is interfering with the touchpad. Go to the device manufacturer's website and look up the product model. Check the bulletin board to see if the manufacturer has posted a notice or update addressing issues with device conflicts. If no such update is available, download the latest driver for the component and install it on the computer. b> Disabled Touchpad b> The Acer Aspire 5516 comes with a preset group of keyboard combinations, called hotkeys, that are used to enable or disable devices, configure sound volume and screen brightness, and control the notebook mode. The hotkeys "Fn" and "F7" turn the touchpad on and off. If the integrated mouse is unresponsive, hold down "Fn" and press "F7"; then test the touchpad to see if the device reactivates. If the touchpad still doesn't work, open Device Manager from within the Control Panel. Expand "Mice and Other Pointing Devices," then right-click the touchpad device. If the touchpad is disabled in Device Manager, you'll see the "Enable" option in the context menu. Click it to turn the touchpad back on; then restart the computer. Corrupt Driver b> Windows Vista talks to the touchpad through a program called a device driver. The driver enables Windows Vista to "see" the touchpad and send it instructions. Once the driver communicates these instructions to the touchpad, the touchpad informs the processor that it needs to perform a task, and a specific set of code is performed. If the driver for the touchpad is outdated or corrupt, or if the driver isn't compatible with the OS -- Acer offers touchpad drivers for Windows XP and Windows 7, but these drivers won't work with Windows Vista -- the touchpad becomes unresponsive. Expand the "Mouse and Other Pointing Devices" section from within Device Manager; if Windows detects a problem with the driver, it places a yellow exclamation point or red "X" next to the device. Double-click the touchpad driver to see the error message; then look up the message on the Microsoft Support website for further assistance. b> Touchpad Settings b> Mouse Properties, accessed through the Control Panel, contains several different configuration settings that can alter how the touchpad behaves on the Aspire 5516. On the "Device Settings" tab is the option "Disable Internal Pointing Device When External USB Pointing Device Is Attached." As the option states, if an external mouse is connected to the Aspire 5516, the touchpad will stop working; disable this option if you're using an external pointing device. Clicking the "Settings" button opens the "Properties for Synaptics Touchpad" window. On this screen are the "PalmCheck" and "Touch Sensitivity" options. If PalmCheck is set too high, or Touch Sensitivity too low, the touchpad won't respond to normal touch, making the device seem unresponsive. Hope this helps.
b>
Dec 31, 2012 | Acer Aspire Z3801 All-In-One Desktop Pc...
Toshiba Satellite A355-S6935 touchpad problem
That is normal, because the touchpad requires a driver. Windows 7, fortunately, comes with driver installation through the Windows Update.
Simply launch Windows update (Start Menu> type "Windows Update" > hit 'enter'), and select all the updates and hit update. You could also manually do it, by going to Toshiba's website, finding your computer model in the "support" category, and finding the appropriate touch-pad driver. (I believe it would be called "Synaptic Touchpad Driver").
Dec 09, 2012 | Computers & Internet
Dell N5040 touchpad
Is there the option to uninstall? If so, try this, although it may only be a temporary fix because if you're using windows 7, it will automatically detect and install upon restart, although you may disable the automatic installation in CP
Aug 07, 2012 | Dell Inspiron N5040 Black New
My touchpad works but not its multi gesture its emachines D730
most touchpad drivers will work on windows 7 but the program which control the functionality of the touchpad "Synaptics" or ALPS" pointing device may not be compatible in win7 this is an issue with most computer manufacturers but not their fault since win7 is a new operating system and possibly in the near future who knows when windows will come with a windows update to make touchpads work in windows having all it's functionality available.
try calling your computers maker and ask if they have work arounds for your touchpad some may have options to make all your touchpads functionality work but some may not try calling them and have them check it for you, they should know better since they are trained for the specifics of your system.^_^
Jun 15, 2010 | eMachines eMD620-5133 Notebook
My touchpad scroll not working
Problem with touchpad driver. Download and install latest driver from the manufacture's website (synaptics, alps...) if you know the driver name.
Else try the software DriverMAX
(downloadable at http://www.innovative-sol.com/drivermax/)
Im using DriverMAX. Its a good software that can automatically detect versions of drivers in our computer and update them if you have internet connection.
Also ensure that in startup programs (RUN>MSCONFIG) the touchpad driver entry is enabled!!
Oct 26, 2009 | BenQ Joybook 5100U Notebook
I have a Toshiba Tecra M8 and the touchpad stopped working. I can still use a USB mouse, but i've tried the FN F9 key to make sure that the touchpad is enabled but it still isn't working. Are there drivers...
Check in the device manager and see if the touchpad is listed under pointing devices.If it is not there try add hardware and see if it detects the hardware. If it is there check to see if it says device is working properly. Sometimes touchpads require software to operate properly so check and see if software was uninstalled. You can also download the drivers/software from Toshiba, try removing the touchpad in the device manager and then re-booting the computer. When windows re-boots it should start installing new hardware found. Use the driver/software you downloaded from Toshiba. If none of these work your touchpad may be bad.
Sep 05, 2009 | Toshiba Tecra® M8-ST3093 PC Notebook
Touch pad stopped working
I recommend you to uninstall and reinstall touchpad drivers to isolate the issue.
Press Windows key and R. Type devmgmt.msc in Run window and click on OK. Click on "+" sign beside Mice and other pointing devices in Device Manager.
Right click on Touchpad and select Uninstall.
You will be prompted to restart the computer.
Windows detects touchpad and the touchpad drivers will be reinstalled automatically.
You can also install touchpad drivers from your notebook support website.
You can reinstall the drivers from the below links:
http://support.acer-euro.com/drivers/notebook/as_5920.html
http://www.laptops-drivers.com/acer-notebooks/download-drivers-acer-aspire-5920-notebooks.html
However I suggest you to install the drivers by visiting the acer support website.
Also perform windows update.
Jun 29, 2009 | Acer Aspire 5920-6727 Notebook
Mouse and Keyboard no longer work
Your laptop probably disables your touchpad when any USB mouse is detected. This is pretty reasonable, since your palms can easily stray over the touchpad during touch-typing. I'm not sure how to go about disabling that, but I'm 95% sure there's a way (even if it involves some command-line stuff).
Jun 06, 2009 | Micro Innovations PD7250LSR Wireless RF...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
