Question about Hoover Elite Rewind Pet Bagless Upright, UH71003
Can you use a Bissel 6594 Series vacuum belt on a Hoover UH71003 vacuum?
    Sergeant:
    Champion:
  • Hoover Expert
  • 357 Answers
Yes. The hoover belt is only slightly longer but it shouldn't cause a problem.
Posted on Oct 21, 2013
5 Suggested Answers
Agent Don
  • 310 Answers
SOURCE: installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
Vac Belts
  • 701 Answers
SOURCE: Change belts on a Hoover Power Drive Wind Tunnel
Below I have listed a link to your models manual where it has step by step instructions on how to change the belt. Also there is a link for the belts you need.
Windtunnel Manual
Windtunnel Self-propelled Belts
Posted on Oct 29, 2009
Vac Belts
  • 701 Answers
SOURCE: How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Posted on Nov 19, 2009
  • 294 Answers
SOURCE: Belt for Hoover Powermax S3606 Canister Vacuum is Broken
Your belt number will be listed on the data label with the model number. Check your local Hoover / Dirt devil dealer for the part.
Posted on Apr 21, 2010
Motor shut off
Try it half an hour later, does it run? If so it's overheating. Change your filters and empty the cup.
If it does not run it's likely a problem with the cord rewind. Some of those units had a recall on the cord rewind. To find out for sure find a local hoover service center and take it in for repair many times at no cost.
Feb 10, 2013 | Hoover Elite Rewind Pet Bagless Upright,...
The belt on my Hoover Elite Rewind UH71003 keeps coming off.
Those machines come half way across the world. The belt stretches while it waits. Buy a new belt for it and you'll be good as new.. actually better.
Here's a full length description of why.
http://www.vacuummedic.com/blog/2012/10/09/my-brand-new-vacuum-doesnt-work/
Feb 06, 2013 | Hoover Elite Rewind Pet Bagless Upright,...
It is spitting dirt out instead of picking it up.
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright
Vacuum not working
heatman101
Feb 06, 2011 | Bissell 6594 PowerForce Bagless Upright...
Not picking up- the motor is running- belt is on
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Aug 18, 2010 | Hoover Vacuums
My bissel vacume was not picking up the dirt on the carpet. So I found that the hose was clogged. I unclogged it but the vacume still is not picking up the dirt. I also changed the filters.
I found out that if you remove the front filter holder, tip vacuum back and look down inside. Sometimes there is hair caught back in there and you won't get suction. I had to use something long, knife, very long type tweezers, to pull all the hair out. Worked great after that. About half way through vacuuming I will stop and remove the foam rubber filter and clean it. Oh yea, you will have to use a flashlight to look down inside to see all the hair caught behind the foam rubber filter cup.
Dec 14, 2009 | Bissell 6594 PowerForce Bagless Upright...
My bissel upright vaccum cleaner belt got damaged and i replaced it with a new one , but it got damaged immd after replacing
In the area where you replace the belt, see if you can remove the beater bar, and check that there is nothing stuck in the area that is causing the damage, like a small screw or similar item.
Sep 11, 2009 | Bissell 6594 PowerForce Bagless Upright...
Overheating
check filters and for blockage - poor air flow then will overheat
Aug 21, 2008 | Bissell 6594 PowerForce Bagless Upright...
Bissel upright vaccum model 6594
Did you check the inlet hose down by the brush roll, it may be clogged there. Your system says that that must be a clog. Did you drop something like a big marble down thru the hose and have go all the way thru?
Oct 27, 2007 | Bissell 9200 Upright Vacuum
Bissel power force
If you are having a problem, you have a years warranty on it, take to a warranty shop and have it repaired, take proof of purchase along. To get a refund or replacement, you will have to take back to where you bought it.
Sep 19, 2007 | Bissell 6594 PowerForce Bagless Upright...
It will not suck up materials on the vacuum part. the hose works just fine when it remains plugged in to the upright part
hi pop into bissel web page faq page type you querry see if there an answer http://bissell.com/Search/FAQ.asp
riz.
Hoover Elite Rewind Pet Bagless Upright, UH71003 Logo
37 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
