Question about Lenovo a780 dual sim
"call forward conditional is enabled" - Lenovo a780 dual sim
How do i block a number on my alcatel one touch pixi 3
Block Calls & Messages:
  1. Open the apps drawer and launch "Contacts"
  2. Tap the name of the contact you want to block calls and messages from
  3. Tap "Edit" > "Menu" and enable "All calls to voicemail"
Unblock Calls & Messages:
  1. Launch "Contacts"
  2. Tap the contact you want to unblock
  4. Disable "All calls to voicemail"
Forward Calls (Unconditional):
  1. Tap "Phone" on the home screen
  2. Tap "Menu" > "Settings"
  3. Tap "Call settings" > "Call forwarding"
  4. Choose to "Always forward" and if necessary, enter the phone number to forward calls to
  5. Tap "Enable"
Forward Calls (Conditional Forwarding):
  1. Open the "Phone" app
  3. Go to "Call settings" and tap "Call forwarding"
  4. Select to forward calls "When busy", "When unanswered" or "When unreachable"
  5. Enter the phone number you want to forward calls to and tap "Update" or "Enable"
Turn Off Call Forwarding:
  1. Open "Phone" and tap "Menu"
  2. Tap "Settings" > "Call settings" > "Call forwarding"
  3. Select "Always forward", "When busy", "When unanswered" or "When unreachable"
  4. Tap "Disable"
Read more: http://cellphoneforums.net/general-cell-phone-forum/t381553-alcatel-onetouch-pixi-3-block-calls-messages%3B-forward-calls.html#ixzz4TXeusLlT
Dec 22, 2016 | Alcatel Cell Phones
Tip
Apple Iphone Codes
*3001#12345# and tap Call. Enter field mode
Field mode reveals many of the inner settings of your iphone
specially up-to-date network and cell information
*#06# Displays IMEI. No need to tap call
IMEI is the unique identifier for your cell phone hardware
together with your SIM information it identifies you to the
provider network
*777# and tap Call. Account balance for prepaid iPhone
*225# and tap Call. Bill Balance. (Postpaid only)
*646# and tap Call. Check minutes. (Postpaid only)
These three are pretty self explanatory
*#21# and tap call. Setting interrogation for call forwards.
Discover the settings for your call forwarding. You'll see whether
you have voice, data, fax, sms, sync, async, packet access, and
pad access call forwarding enabled or disabled.
*#30# and tap Call. Calling line presentation check.
This displays whether you have enabled or disabled the presentation
of the calling line, presumably the number of the party placing the call.
*&76# and tap Call. Check whether the connected line presentation is enabled or not.
State whether the connected line presentation is enabled or disabled. Presumably similiar to the calling line presentation.
*#43# and tap Call. Determine if call waiting is enabled
Displays call waiting status for voice, data, fax, sms, sync data, async data,
packet access and pad access. Each item is either enabled or disabled.
*#61# and tap Call. Check the number for unanswered calls.
Sho the number for voice call forwarding when a call is answered. Also show
the options for data, fax, sms, sync, async, packet access and pad access
*#62# and tap Call. Check the number for call forwarding if no service is available.
Just like the previous, except for no-service rather than no-answer situations.
*#67# and tap Call. Check the number for call forwarding when the iPhone is busy.
And again, but for when the iPhone is busy.
*#33# and tap Call. Check for call control bars
on May 19, 2010 | Cell Phones
Tip
New secret of iphone
New secret
provider network
thank you
on Mar 19, 2010 | Cell Phones
What do you mean by forwarding on conditional on?
Forwarding on conditional, means that calls can be forwarded to a different number (or voicemail) on certain conditions.
These could be, unanswered, unobtainable or busy.
Normally you would have this set to forward to voicemail if you are unreachable, or unanswered.
But you can forward ALL calls to a different number if you wish.
Please note that different phone providers can charge for this feature.
i.e. forwarding a call to your home number, they may charge you for forwarding.
May 12, 2014 | Cell Phones
How do i enable port forwarding on my router?
Port forwarding is you need to know what address you to port fowarding. It is usually under the administration tab.
Nov 21, 2009 | Hawking HBR49 Router
Smoke sometimes out of exhaust bypass
It is not an exhaust bypass or filter.
It is a booster heater , which enables quicker warm up in cold conditions.
An electronic box and sensor only kicks heater on when subzero conditions.It burns diesel , hence the smoke from underneath passenger side.
Hope this helps.
Mar 31, 2009 | 2003 Volkswagen Passat
Want to divert calls from one Mitel Superset 4025 to another.
Under the Blue Superkey, there is an option for Call Forwarding.
Go to the call forwarding and put in the extension that you want to forward to, and then enable it.
To disable the call forwarding, you have to go back into the Blue Superkey and disable the call forwarding from there.
It's either that, or your system programmer may have given you a call forwarding button on the set to enable and disable easier.
Mar 04, 2009 | Mitel Superset 4025 Corded Phone...
Forwarding phone
This is not a phone equipment service but rather a phone service provider service.
YOU CAN FORWARD but to do this you need to have this feature enabled by your phone service provider. Then, follow their instructions on how to enable and disable this feature based on your calling plan.
Nov 12, 2007 | GE 29488GE2 Corded Phone
Lenovo a780 dual sim Logo
145 people viewed this question
Top Lenovo Cell Phones Experts
richie46
Are you a Lenovo Cell Phone Expert? Answer questions, earn points and help others
