Question about Crunch Maxxsonics P1000.1 1000W 1-Channel A/B Class Mono Amplifier Model P1000.1 Part No. P1000.1
Synboz cross fire - Crunch Maxxsonics P1000.1 1000W 1-Channel A/B Class Mono Amplifier Model P1000.1 Part No. P1000.1
The fire order and on ,84 cross fire corrvette please show diagram of of wire placement on both motor and distributor
1984 Chevrolet Corvette 5.7L TBI 8cyl
The Firing Order
Firing order 1-8-4-3-6-5-7-2 ---------front ' 2 4 6 8 ' of ' ' Distributor rotates clockwise vehicle ' 1 3 5 7 ' ----Here's a video on your firing order. firing order of 265 to 350 chevrolet smallblock v8 animated here's another link. The fire order and on 84 cross fire corrvette please show diagram of of...
Aug 02, 2015 | Cars & Trucks
I have a 1984 s10 with a 372 small block chevy in it and it runs fine tell you get on it then it backfires through the cub the timeing is good is it the valves or the cam??
While the timing might be right what you describe is an indication that the firing order has 2 wires crossed . Recheck the firing order . Check that the HT leads are not touching each other as low quality leads will allow cross sparking and wrong firing order.
Jul 30, 2014 | Cars & Trucks
Does heavy rains cause backfiring
No, but water on your distributor or plug wires can. If you're missing weather seals or splash guards you could be getting water in the engine compartment and that COULD be your problem. Wet wires cross-firing will often keep cross-firing after they dry out. It could also be a timing issue or other problem unrelated to the rain.
Jul 21, 2014 | Hyundai Sonata Cars & Trucks
Were can I download cross fire in the enternet for free.
Cross fire game IS free just go here and Download the game http://crossfire.z8games.com/
Hope this answers all your questions Please remember to Rate/vote for any solution that helps you out. Leave a comment if you need more help. Thanks for using Fixya
Aug 09, 2011 | Computers & Internet
How to download crossfire
Here is the link below to download the cross fire
http://www.brothersoft.com/games/cross-fire.html
Thanks.
Jun 22, 2011 | Computers & Internet
I got a cross fire cable with this system surely
Does the computer have two graphics cards?
If so i suggest you apply the crossfire cable to them, it increases the performance.
Jun 07, 2010 | Gateway FX683103 Gaming Desktop PC...
05 taurus rough idle when cold then runs fine. code P0308 was pulled. No other issues, car runs great beside that. I know 308 means multi cylinder cross fire. So it has to be something common to all...
it cant be cross fire it is misfire, cross fire ocurs in engines that use a distributor, the code is from one or more cylinders misfiring check for a bad set of cables or a faulty spark plug or coil
Dec 17, 2009 | 2005 Ford Taurus
Someone crossed spark plug wires i need fireing
It is stamped on the top of the engine, in the head. It is usually pretty easy to find, and you wont have to remove any pieces to see it.
Oct 25, 2009 | 1998 Pontiac Bonneville
Missing
Sounds like a load miss. Chk plug wires for deterioration and or cross firing. Wires should not cross over each other. Worn plugs load wires causing increase spark out put increasing cross firing potential
Apr 30, 2009 | 1986 Ford F 250
Crunch Maxxsonics  P1000.1 1000W 1-Channel A/B Class Mono Amplifier Model P1000.1 Part No. P1000.1 Logo
114 people viewed this question
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Matthew Spark
Matthew Spark
Tygh Duval
Tygh Duval
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
