Question about Garden
Fuel Mixture please - Garden
    Sergeant:
  • 322 Answers
Usually 40:1 or 50:1
Posted on Oct 18, 2013
2004 Honda VT 1100 C2 Shadow Sabre carburetor adjustment
Hi, Anonymous it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
1. The mixture screw may be sealed at the factory with a Welch Plug please review the following video for removal.
https://www.youtube.com/watch?v=wAXcksgvDkM
2. The mixture screw manages a range of 3 complete 360-degree counterclockwise turns from the bottom/closed position.
3. The mixture screw should have a spring and o-ring for tension and sealing integrity.
4. Turn the mixture screw clockwise until it gently bottoms out, this makes the fuel charge very lean and the engine should not idle if it does then the pilot/idle jet is too big and needs to be replaced with the next size smaller.
5. Turn the mixture screw 1 and 1/2 turns counterclockwise to establish a baseline for starting the engine.
6. To fine-tune the idle circuit, adjust the mixture screw 1/4 turn in or out to achieve maximum idle RPM, wait 15 seconds between each adjustment for the idle to settle.
7. Never go past 3 full turns out this will make the fuel charge rich, foul plugs, and produce black smoke out of the exhaust, if the engine RPM keeps increasing past 3 turns the pilot/idle jet is too small and needs to be replaced with the next size larger.
8. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
9. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1995 VT1100C2 Air Fuel Mixture Pilot adjust
VT1100 Mixture Screw Location
Honda Shadow VT1100 Owner Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda shadow vt1100 Owners Workshop Manual
Apr 27, 2014 | 2004 Honda VT 1100 C2 Shadow Sabre
Leonardo 125 mixture screw settings please
all motorcycles and cars the fuel mixture settings are
1 1/2 to 1 3/4 turns out
some carburetors are pre set and cannot be adjusted
if this is the case then you will have to replace your carburetor
Apr 14, 2014 | Aprilia Leonardo 125 Motorcycles
Fuel mixture cbr600fs
Air fuel mixture screw question CBR Forum Enthusiast forums for Honda CBR...
99 Honda CBR 900rr carburetor removal and air fuel adjustment
Honda CBR600F4I 2001 Service Manual
Honda CBR600F4i Owner Manual
Mar 29, 2014 | 1992 Honda CBR 600 F(2)N
2005 Honda Activa air-fuel mixture adjustment
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Adjusting air fuel mixture screw
Honda Activa Fuel Mixture screw Actual Adjustment and RPM Adjustment
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Honda activa 2009 Owner Manual
Feb 14, 2014 | 2005 Honda Activa
Fuel mixture screw adjustment on 1985 honda xr600r
86 xl600 air fuel mixture question
1986 Honda XL600R Carb Service
1985 2000 Honda XR600R Dirt Bike Service Manual Moto Data Project
http://mybikemanuals.com/honda/227
Jan 27, 2014 | 1985 Honda XR 600 R
Adjust air fuel mixture
Fuel Mixture Screw
Basic how to on air fuel adjustment on 1300 VTX
Honda VTX1300S Service Manual
Honda VTX1300C VTX 2004 Owner Manual
Jun 01, 2013 | 2003 Honda VTX 1300 Retro
2009 Honda CRF450X how to adjust fuel mixture
Throttle Response Fuel Screw adjustments
How To 4 Stroke MX Fuel Screw Adjustment YZF CRF KXF RMZ FCR Part 1 of 2
Honda CRF450X 2005 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda 2009 CRF450X Owner Manual Competition Handbook
Mar 08, 2013 | 2009 Honda CRF450R
1978 Honda CX 500 A air/fuel mixture adjustment
Hi, Shado it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
Mixture adjustment
Total Motorcycle Forums
Honda CX500 Service Manual right click the chapter you want and save as
http://mybikemanuals.com/honda/honda-cx-owners-manuals
Jul 18, 2012 | 1978 Honda CX 500 A
2004 Honda CBR 125 R fuel mixture too rich?
Hi, Kye it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
7. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
8. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
Honda CBR 125 few minor problems
Life On 2 Wheels
Honda CBR125R Owner Manual service
Honda CBR125RW Owner Manual
Feb 02, 2012 | 2004 Honda CBR 125 R
98-99 Yamaha royal star, air fuel mixture screw settings, thanks
Hi, Rbmotorsport it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
Royal Star Airbox Modifications
Setting carb fuel mixture screws
Yamaha XVZ13TFL Service Manual
OEM parts for Yamaha
Yamaha Royal Star XVZ13CTV Owner Manual
Nov 02, 2010 | 2005 Yamaha Royal Star Tour Deluxe
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
