Question about Hardware & Accessories
HOW DO I SET AN ET7-MP TIMER - Hardware & Accessories
How do I reset the hourly timer display on my rug dr. pro?
The timer does not have a reset. It is to tell how many hours it has ran for maintenance purposes.
Jan 07, 2017 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
I have two Delta 7 day programmable timers which I cannot programme ET7-AL
These are scans of the original packaging. Hope this helps. FYI mine packed up after a couple of years but is now working after I unsoldered and replaced the Troily 1.2v 40mAh (5.5mm x 12mm) button cell
Nov 16, 2011 | Hardware & Accessories
Manual feed isnt working. once tray 1 is open i thought it would automatically know i want to use manual feed.
Not necesarily so, it depends on how you have the printer configured. To test the MP tray, use the arrow keys to get to troubleshooting menu, press check, use arrow keys to get to paper path test, press check, set tray option to tray 1, then print test page. Printer should feed from MP tray. If it does, then the problem is that you do not have the printer set to print from MP tray first or you have the tray options set to exclusive which means that if your print job asks for tray 2 then printer will not print from MP tray unless you specify MP tray in the print options.
Mar 18, 2011 | HP LaserJet P4015 Printer
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
I NEED TO RESET THE TIMER ON THE AFICIO MP C2000
Is the main power switch on? (not the one on copier operation panel)
Jan 29, 2010 | Ricoh Aficio 1018 Printer
3m mp8795 turns off after about 2 hours no warning just turns off what could cause this? I had is checked by a tv repair shop and they said nothing looked wrong. took it home still same problem?
may be overheating or the power off timer is set (if it has one) to turn off after a specific amout of time of inactivity. this can be disabled in the menu. otherwise, you have a power supply problem.
Jan 12, 2010 | 3M MP 8795 Multimedia Projector
I can't figure out how to set the self timer from the manual on a canon powershot sx 110
For the SX 110 IS 9 mp camera: With the camera in picture taking mode, Hold the bottom of the roller dial down at the point closet to the timer icon. Hold it for a couple seconds, then the screen will display the timer settings. Select the setting you want and start taking pictures.
Jul 17, 2009 | Canon PowerShot SX110 IS Digital Camera
Air Filter and reset the timer settings
go into the menu. it should be in the same menu as the lamp timer. as for cleaning the filter, use canned air.
May 18, 2009 | 3M MP 7750 Multimedia Projector
IBM infoprint 1422 won't feed through paper tray, only works with mp loader
Ok.... I have these printers at work...and i think i have figured this one out :
Under setup menu , goto configure mp , then switch the settings from cassette to manual. You see these printers are used at Hotels where the bottom tray is for legal size paper used to make key packets and the mp is used for regular sized paper printing reciepts....Hilton family hotels use them for example....the next thing I'm trying to figure out is how to set it so I won't have to push the go button every time I print something
Oct 22, 2008 | IBM Infoprint 1422 Laser Printer
Hardware & Accessories Logo
155 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
