Question about TallyGenicom Office Equipment & Supplies
Tally genicon 6605 is printing from top to bottom of the page...what could be the problem
    Novelist:
  • 169 Answers
I think it depends on what you mean by printing from top to bottom of the page.
If you are describing the print being rotated by 90 degrees so rather than a line of print going across the page from left to right, the print goes up and down the length of the page.
The most common cause of this is that you are printing from a Windows application and you have set the page orientation to LANDSCAPE rather than PORTRAIT.
With in the application you are printing from look for the PAGE SETUP options ensue you select PORTRAIT.
This should rotate the print.
Posted on Oct 30, 2013
hashchathy
  • 246 Answers
SOURCE: poor print quality - top half page okay, bottom print faded and skips
check the wright cartridge model you installed and well pluged to the printer
if it is ok
try to change printer properties and fix it correct options with there tabs ( ex: paper, print quality etc)
all are well try to reinstall the printer driver
Posted on Aug 01, 2008
  • 55 Answers
SOURCE: top of page printing fine, bottom of page not
needs printer alinment
Posted on Mar 29, 2009
  • 169 Answers
SOURCE: how do i adjust the print head gap on a tally
The 2280+ does NOT have a head gap leaver you can adjust the gap from with the menu on the printer.
The printer has an automatic gap adjust which should set the correct gap for most types of paper.
The print head gap can be changed in the following way;
  1. Put the printer OFFLINE
  2. Press SETUP
  3. Press the button under ADJUST on the display
  4. Press the button under HEAD
  5. You can now change the print head gap, if the Automatic Gap Agjust is working the gap setting should go from -10 to +10.
    If the Automatic Gap Adjust is not working this value will go to values smaller than -10 to larger than +10
If the Head gap will go to values less than -10 and greater than +10, first check the AGA is enabled. This can be done in the following way;
  1. Power the printer OFF
  2. Hold down the ONLINE button and power the printer ON, keep the ONLINE button held down untill the pritner has finished initializing.
  3. Press NEXT repeatedly untill you see AGA
  4. Select AGA
  5. Channge this to ALWAY or ON (cant remember!)
  6. Press SET
  7. Power the pritner OFF and back ON to exit the menu.
If the AGA option does not apear in the TEST menu above the Automatic Gap Adjust is not working and will need to be checked out.
Posted on Sep 30, 2009
  • 29 Answers
SOURCE: ms word does not print properly on tally 2250 printer
you need to create a forms for your specified paper size.
1.open printer and faxes in win xp.
2.file...server properties...create a new form(check)
3.type a name for forms
4.type a size in below boxes...(like 10 x 12 paper , width is 10 inch, height is 12 inch)
5.save it
6.close
7.rht click the printer...device setting tab... select a form name in the tray .
8.it will work
Posted on Nov 17, 2010
  • 3 Answers
SOURCE: our printer is diplaying the following message:
This problem is related to the BTR = Bias Transfer Roller. You'll need to replace it soon or just clean it up (if no fisical damage). The clean up proccess is very simple but dusty.
Posted on May 02, 2011
Lipi printer 6605 driver
how can i instal tallygenicom 6605 driver in windows7
Apr 06, 2013 | Tally 6306 Matrix Printer
Landscape printing on t2340
printers>properties>general tab>printing preferences change print mode to landscape from portrait..........
Jan 23, 2013 | Tally T2340/24 Matrix Printer
Sir the bottom half part of 2nd page left blank and the data is printed on 3rd page.
HI, The usual issue with this problem is the settings on the document. Try adjusting the margin on the document then try to print again.
Cheers!!
Sep 01, 2010 | Tally 6306 Matrix Printer
Our printer is diplaying the following message: BTR EOL near What does this mean? Our printer is a tally genicon 8026DN
Apr 19, 2010 | TallyGenicom 8026DN Laser Printer
How to set fanfold 8.5 x 12 page in Tally 9
when you giving print command choose the printer and go to printer option and choose the paper type then give the print command .
Jan 20, 2010 | Tally T2245 Matrix Printer
Printed 12 inches
check the page setup for header and footer margin sizes and top or bottom margin sizes .
May 13, 2017 | Tally LA650 Matrix Printer
Print stops after 2 pages !
Hi my tally printer 6218 giving Ribbon motion fault, what could be done to remedy this error message ?
Jan 19, 2008 | Tally T6218 Matrix Printer
Tally t2280 does not recognise the page breaks.
self test not printing & printer is offline mode
May 30, 2007 | Tally Matrix T2280 Printer
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
