FixYa.com
Tags:
Galaxy Remote Control
Auto start
posted by hurls11 on Sep 26, 2007
After market Galaxy remote for auto start/door opener for my 04 Chevy Silverado, suddenly will not open my doors. Auto start function and door lock functions still work. Please advise.
Comment by hurls11, posted on Sep 27, 2007
everything on remote works...it just wont open doors. It still causes the brake lights to light up when pushed, but doors do not unlock.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 29, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
It was installed ata shop.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Mar 15, 2008
Not Rated (0)
birdieman
Rating: 85%, 3 votes
did you install yourself and what module did you use for the doorlocks or did you have it installed at a shop
Comment by birdieman, posted on Mar 29, 2008
did you tap the white and blue wires at bcm under sterring column
if you are comfortable tearing your vehicle apart go to bulldog security.com look up your vehicle it will show you the bcm it is the 3rd picture down it has 3 plugs white, brown ,blue you can get the door locks the colors are white and blue in the blue plug but most shops use a bypass module that controls everything including your factory security it connects to the dianostic plug bottom left of your dash right above your feet this connection should be at leat 6-7 inches before plug connecting to the purple with white wire as far as tearing apart the dash comes out then panel above your feet comes out then you will see a metal protection plate has 4 nuts holding it on then it will be easy to see bcm or look for the connection to the purple with white wire let me know it might be as simply as reprogramming module
Comment by birdieman, posted on Mar 31, 2008
also look for small green and blue wires out of the remote start giong to a liitle black box it should be green to green which is lock and blue to blue for unlock
Can you Help with these Remote Controls problems?
Remote Controls
Need Universal Remote Code
I have a 25" Orion CCD TV... Answer This...
Remote Controls
Need TV codes
Have an One For All... Answer This...
Remote Controls
viewsat tv reciever remote...
bought 46 in. viore tv hook to... Answer This...
Remote Controls
powakaddy golf trolley remote
lost remote and aerial are... Answer This...
Galaxy (2000RS) Remote Control
lock doors after certain rpm is...
how do you get doors to lock... Answer This...
Repair Service
Find Remote Control Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
