Question about Adam Audio A7 Powered Studio Monitor (Each) ¹
Adam a7 fuse - Adam Audio A7 Powered Studio Monitor (Each) ¹
Marshall JCM 2000 cracking hissing noise only when I plug into it. INPUT Jack ? Or FX jacks. ?
Balmahb preferred to specialist
http://www.buyket.org/%D8%B4%D8%B1%D9%83%D8%A9-%D8%AA%D9%86%D8%B8%D9%8A%D9%81-%D8%A8%D8%A7%D9%84%D8%AE%D8%B1%D8%AC/
Dec 12, 2016 | Marshall Music
Adam a7 rattle
"Rattle" can be a couple of different things- a blown driver, a loose screw, a loose component on the board, etc. Best get it looked at by a serviceman.
Feb 08, 2013 | Adam Audio A7 Powered Studio Monitor...
Adam a7x same box with defferent fuse,why?
do you mean you got a new one and it just has a different fuse? if so you may have already got a newer model or older model where the pc board inside has differnt "Revisions". just meaning the designers changed a thing here or there such as rev. a or rev. b. shouldn't be a big deal but it does state you do not have identical speakers hence they may also filter sound differently.
Oct 20, 2011 | Adam Audio ADAM A7X
My fuse keeps blowing in the speaker ????
Take it in for repair... unless you are electronically adept this is not DIY fix.
Aug 14, 2011 | Adam Audio ADAM A7X
I've got a Adam A5X studio monitor. the problem is that fuse blows after about 15 sec. it works but you can hear background hum and the transformer gets very hot in 15 sec. then fuse blows. i wonder...
Transformers RARELY fail. It is likely that either one side of the amplifier has shorted or there is a failure in the rectifier/filter circuit of the power supply. Take it for repair unless you are adept at electronic repair. Do NOT continue to replace the fuse as you MAY cause futher damage. Use a 25 or 40 watt lamp in series with your power cord to limit current while troubleshooting.
Jul 05, 2011 | Adam Audio A5X Pair 2-way 5.5 inch...
One of my Adam A5X speakers suddenly started making an annoying sound. it can be described as a hum in the middle freqquencies. I would guess it has something to do with the wiring? I will contact the...
Unplug the audio cable to it... IF hum persists, possibly a filter capacitor in the power supply has failed.. If it is quiet with no audio connected, look for bad cable or improper grounding such as running these from different receptacles in your facility.
Jun 23, 2011 | Adam Audio A5X Pair 2-way 5.5 inch...
My adam A3X is suddently having the power switch stuck. I can no longer turn it on.
As loon as the power switch is not also a circuit breaker, just change the switch. If it is also a circuit breaker then there probably is some problem with the amp.
May 27, 2011 | Adam Audio A3X 2Way Studio Monitor...
Hi, I ordered my Adam a7x from america to Australia. When receiving them, i plugged in australian adapters (300/500volts). But when powering them up, unfortunately the light went on and then a...
Did you just use adapters or actual step-down transformers?
A lot of equipment today is 110/220 auto-switching, but if you get something built for 110V (120V, 100V, markings may vary) only, then you need more than an adapter, you need a transformer!
Mar 14, 2011 | Adam Audio A7X Powered Studio Monitor (7...
Adam Audio A7 Powered Studio Monitor (Each) ¹ Logo
150 people viewed this question
Top Adam Audio Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an Adam Audio Music Expert? Answer questions, earn points and help others
