Question about Ricoh Office Equipment & Supplies
My Machine MPC 2030 is showing continiously paper jam in A after the machine is powered on. Physically no paper is there.
    Problem Solver:
  • 18 Answers
Remove the paper from the paper tray and reset the jam by opening the right hand side door. If the machine turns over, replace the paper in the tray and check that the guides, in particular the green guide, is nice and tight around the paper.
Posted on Oct 21, 2013
  • 35 Answers
SOURCE: Machine shows "Paper Jam" error
There is a paper senser present in the paper lifting area. That part of your printer is not working properly. Replace that part and then try
Posted on Sep 20, 2007
Soulvisitor
  • 1113 Answers
SOURCE: paper jam 202 with no paper in printer
This jam is refering to back door, jam in fuser (hot bit) Double check no paper is wraped around fuser rollers.
These machines have a fuser at rear if you look at he fuser from the back, on it you will see, two thick fuser rollers (ones rubber), paper runs threw these then it hits a little black switch (your machine thinks this switch is activated) and then a series(3,4) of small rubber exit rollers, this switch (between middle and left) can get damaged it also likely that a piece of paper is concertinaed in fuser.
Also remove print cartridge and look behind it, if this machine has duplex unit installed you will need to lift it off that first to axcess all areas.
Check all doors are shut.
Posted on Nov 13, 2007
SOURCE: Paper Jam showing but no paper in machine
kxhost.com
Posted on Dec 15, 2007
SOURCE: Paper jam with Brother HL-2030 laser printer
Being a retired electronics technician, I located and downloaded a copy of the service manual. Then proceeded to hunt for the reason why the Paper LED was staying on. I put the printer into the Production diagnoses mode, then by process of alimination opened and closed each panel and cheack each sensor switch one at a time. At which time it was apparent the problem was the rear door sensor. So I started to disassemble the printer getting instructions from the Service manaul, as most electronic equipement there is a sequence process to accompliah this. and once I found that the method of the rear door sensor operated I found the bracket was not in the right position. I put the sensor bar back into it's proper position and put the printer back to normal opperateing mode, I found my problem was solved. So I reassembled the unit and plugged it back into the compter ran a couple of test sheets and cleaned and aligned the printer head(s) made a few adjustment and everything was back to normal.
I must say that locating the Service Manual was a feat, but worth every cent I paid for it which was $9 USD. Personally i think all service manuals should be available for all Brother products for a fee, then a large number of problems can be fixed by the owners without much bother to Brother.
I ahve two of these printers and would still purchase a Brother colour printers, my next purchase is going to be a Brother color laser printer. Out of all the printers i've used on my computers I like the brother the best.
Posted on Mar 22, 2008
  • 13433 Answers
SOURCE: Paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
Paper jam error
could be a stuck, failed, or out of place sensor. recheck all sensors in paper path(s) carefully
Sep 19, 2013 | Kyocera Office Equipment & Supplies
Paper jam removed but machine still shows paper jam
Maybe there are paper stuck inside the printer or maybe out of ink
Apr 03, 2013 | Panasonic KX-FL511 Plain Paper Laser Fax
Printer light is on even when paper is in machine and wont print
Did you check the back cover for paper jam?
Still have some paper jam in your machine.
Be sure you openned all cover, paper tray and pull out the drum to check.
May 29, 2009 | Brother HL-2030 Laser Printer
Message shows paper jam even though there is no jam
take all the paper out make sure there is no dirt or dust in the corners,then unplugg the machine for 30 sec. power back up and reload the paper
Feb 26, 2009 | Office Equipment & Supplies
Fax will shows a Paper jam but no paper found in machine.
Are the all sensor flappers whole?Or it may be an PCB problem
Jan 26, 2009 | Canon LaserClass 9000L Plain Paper Fax
MINOLTA EP 2030 Photocopier
if it powers up and goes into rotation then the fuser is good. So check the machine for paper jams, toner,
does it give an error? is there a symbol light on?
Sep 09, 2008 | Minolta EP1030/1030F CS/PRO Copier
Paper misfeed
hi im jules_09.have you check the inside of the copier?open the front door then see if there a paper in the transfer the transfer is in front of you if the door is open.the check the fusing unit many paper jams happen in the fusing unit.then at the paper tray if you cannot locate the paper jam inside the machine look at the paper tray from 1 to 3.then at the side most copier have opening at the side look for the door so you can see if theres any paper stock
Nov 22, 2007 | Toshiba 2060 Copier
Meaning of code C04 ( EP 2030)
minolta cspro1054 turns off once you turn it on and code is c
Nov 15, 2007 | Minolta EP1030/1030F CS/PRO Copier
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
Kyocera CS 2030 fax jams
Hi,check settings for fax.Try to check paper attributes for fax.Maybe You have different paper format adjusted for fax printing.
Oct 19, 2007 | Copystar CS-2030 Copier
44 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
