Question about HP Office Equipment & Supplies
Wis Pap.str press OK - HP Office Equipment & Supplies
PAP FD DRVR CIR
My P7005 displays PAP FD DRVR CIR error
Sep 06, 2012 | Printronix Matrix Office Equipment &...
Brother HL 3070CW says the toner is low and won't print. It has toner and I have to get something printed for a client
I done on my brother lh3070cw printer cartridge on Message "Low Toner"
First I take off toner cartridge
second - Covered the both Glass Buttons of Cartridge situated right and left side of cartridge (all cartrideg) for Black Electric Tape.
thent install the cartridge in the printer again.
after install the cartridge press SECURE PRINT AND CANCEL BUTTON SAME TIME AND CLEAR THE STR AND STD FOR PRESSING ok BUTTON FOR 2 TIME.
ERASE EACH STR AND STD
THEN PRESS CANCEL
YOU CAN USE YOUR PRINTER FOR END OF THE TONER
Mar 28, 2011 | Brother MFC-9440CN Laser Printer
Universal remote programming code for str de697 reciever I am trying to program my ATT uverse remote to operate this reciever.
Here are the list of Sony remote codes :
5017, 5023, 5028, 5029, 5030, 5031, 5032, 5033, 5095, 5096, 5097, 5113, 5117, 5121, 5125, 5129, 5133, 5134, 5136, 5146, 5162, 5163, 5169, 5170, 5171, 5172
Here is how to program the remote.
  1. Turn on the Receiver.
  2. Press and hold AUX and OK at the same time.
  3. Release both the AUX key and the OK key at the same time. All the Mode keys should flash twice.
  4. Enter the four digit setup code and the AUX key will flash three times indicating correct entry and return to normal operation.
  5. Point the remote at the Receiver and press the power button. If it turns off the receiver it is now programmed. If not Repeat steps 2-5 until the remote turns off the unit.
Good Luck,
Robert
Feb 27, 2011 | Sony STR-DE697 Receiver
How to lock a PAP device ....? i want to lock a pap device to make my voip account secure..
  • Open a web browser on your computer and navigate to the IP address of your router. This address is typically "192.168.1.1" or something similar.
  • Type in your current password and press the "Enter" key or click on the ok button
  • Click "Administration" to access the password alteration screen.Type the new router password two times and then click on the "Save Settings" button to immediately change your router's password.
  • Hope this helps, thanks for using fixya.
    Correct? vote wouldnt go a miss good or bad.
    Dec 06, 2010 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
    No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
    Hello
    Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
    If any further assistance you needs, get me through Fixya. Ok.
    Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
    Netopia 2247NWG for smarttelecom
    Sorry if my writing is not clear I dont have best english.
    If you move your router from eircom to smartelecom you have to change security protocol from "chap" eircom to "pap" smarttelecom.
    Now Do this few steps.
    Go to start menu on windows find and click run.
    type: cmd and press ok
    When you will see black screen that will be command prompt.
    Now you have to type your defaul ip adress. To check your defaul ip adress type ipconfig in command prompt and press enter.
    Default Gateway is your default ip adress. Now when you know your ip type in command prompt:
    telnet yourip 23 and press enter, for example:
    telnet 192.168.1.254 23
    If you didnt setup any password to login to the router you will be loged automaticly and you will see "Netopia-2000/18861188>
    But if you have setuped login and password to your router you have to first type your login and press enter,then password and press enter to have acces.
    next is easy type:
    configure and press enter
    ppp and press enter
    set and press enter
    now you have to pressing enter about till you will see line:
    option <chap-only> [ off : on : pap-only : chap-only ]:
    on this line type pap-only and press enter
    now start pressing enter till you see:
    Netopia-2000/18861188 <ppp>>>
    then type save and press enter.
    When you see line:
    Configuration data saved you can close command prompt window.
    From this moment your router will be work with smarttelecom.
    Dec 13, 2008 | Netopia 2247NWG-VGx Wireless Router...
    LG Viewty email set up
    1 Find "Access points"
    • Press the menu icon.
    • Press the fourth tab.
    • Press Phone settings.
    • Press Connectivity.
    • Press Access points.
    2 Create new or edit existing data connection
    • To create a new data connection:
    • Press Add.
    • To edit an existing data connection:
    • Press the required data connection.
    • Press the icon to the bottom left.
    • Press Edit.
    • Press the Connection title input field.
    • Press C to clear the input field.
    • Key in EMAIL GPRS and press OK.
    3 Select data bearer
    • Press the Bearer drop down list.
    • Press UMTS or GPRS.
    • Press OK.
    4 Select authentication
    • Press the Authentication drop down list.
    • Press PAP or CHAP.
    • Press OK.
    5 Enter username
    • Press the Username input field.
    • Key in user and press OK.
    6 Enter password
    • Press the Password input field.
    boxAdd('info6', cBoxClosed); The APN name must be in lower case letters. 7 Enter APN name
    • Press the APN input field.
    • APN same as your internet settings
    8 Save and exit
    • Press Save.
    • Press Disconnect to return to stand-by mode.
    Please note: You now need to select settings for an email profile.
    Nov 17, 2008 | LG KU990 Viewty
    Sony STR DB-930 Receiver jumping into protector mode
    I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
    Re Assembled unit and it worked OK.
    I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
    Thanks for the technical help, sure solved my problem.
    Regards
    Darryl.
    Mar 07, 2008 | Sony STR-DB930 Receiver
    About flash 8
    Here is the small sample code. This will convert the lower case letter to upper case letter from left to right character by character.
    TextField.prototype.caseAnimation = function(str) {
        var tf = this;
        tf.upperIx = 0;
        tf.str = str;
        var id = setInterval(moveUppercaseLetter, 100);
        function moveUppercaseLetter() {
            var str1 = tf.str.slice(0, tf.upperIx);
            var str2 = tf.str.charAt(tf.upperIx).toUpperCase();
            var str3 = tf.str.slice(tf.upperIx+1, tf.str.length);
            tf.str = str1+str2+str3;
            tf.text = tf.str;
            tf.str = tf.str.toLowerCase();
            tf.upperIx++;
            if (tf.upperIx>tf.str.length-1) {
                tf.upperIx = 0;
    this.createTextField("animated_txt", 1000, 0, 0, 500, 25);
    animated_txt.setNewTextFormat(new TextFormat("_typewriter", 16));
    animated_txt.caseAnimation("pack my box with five dozen liquor jugs");
    Oct 18, 2007 | Macromedia Flash MX
    204 people viewed this question
    Seeker5211
    Seeker5211
