On the pcl drivers they are in the advanced tab then printing defaults and it should be in the lower left corner of the first page. Some of the newer pcl 6 drivers you go to the advanced then printing defaults next click on detailed settings under the basic tab you will find the ACS you also need to check the same spots under the general tab and printing preferences and confirm the settings are the same as some software uses advanced settings verses the preferences settings
SOURCE: colors dont match screen
can u tell me how old this printer is,when u got it service maintance last time,u better try to calibrate it
SOURCE: Ricoh CL7300 not printing the colors corrrectly
Look at the transfer unit. If the clear belt has alot of wear lines the belt needs to be replaced pn# B180 3780
The machine builds the alignment image on this belt and then reads it if the belt is cloudy it will fail.
