Question about Refrigerators
Fridgemaster mtbl140ng integrated undercounter fridge - white
Has turned itself off, thought it was just the light bulb at first. Cant find its on and off switch but after looking i realise it doesnt have one. do you have any suggestions
SOURCE: I have a fridgemaster fridge freezer that gas a
For outside cold areas should be 1.
Posted on Jan 14, 2010
  • 5 Answers
SOURCE: fridgemaster fridge freezer has just stopped
Out of coolant? Got a leak? May just be liquid in the radiator, switch off, turn it all upside down (emptied) for 30 minutes, then right way up, leave for an hour, then plug it in and switch on to see if it has helped to get fluid in the compressor. Cant hurt, sounds pretty bad really, sorry!
Posted on Mar 12, 2010
  • 4793 Answers
SOURCE: Hi I have a fridgemaster mftr280r and it doesnt
whatever,it cant not help,as long as you do a COMPLETE defrost(leave it for at least 24 hours.then dry out thoroughly.clean any drains/vents then restart as new.let it settle for at least 24 hours then check/refill.fridge is +5C...freezer is -18C,optimum temps...
Posted on Nov 01, 2010
SOURCE: Fridgemaster drain hole blocked. Fridge
either it needs a good vacumning the coil area or it is low on freon.
Posted on Jan 17, 2011
Yamaha xjr 1300 electrical fault oil light comes on with headlight
Just sorted my problem with oil light coming on when lights are switched on. Removed the back off the clocks and realised there was a missing oil light bulb, and the holder was out of place. It was the light from the dash light coming through the hole for the oil light which made it look like the oil light was lit. put new bulb into oil light holder and all back in place everything now working 100%. Happy days !!! Hope this helps
A.
Jan 02, 2013 | Yamaha Motorcycles
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
I pushed the switch on my work light , it was on for a second then off, as if the light bulb burned out, the light bulb doesnt look bad, what could it be?
Take the bulb out and if you have a multi tester give it a continuity test by hold the red test probe on the base and the black probe on side where the threads are.if you get a beep then the bulb is good.Next unplug the machine and look in the socket.If there is a metal tang in the bottom of the socket try bending it up with a paper clip with a L bent on the bottom so that it will make contact once again.I hope this will solve your problem.One other thought you can try es a small clamp on light.Thank for choosing FixYa.com and good luck.
May 16, 2011 | Makita 18 V 1/2" Driver Drill Kit With...
The light bulbs aren't burned out the tail lights work, it isn't the fuse. The brake light in the back window works thought.
Year ?model? so what doesnt work? the brake lights? If the light in the window works, then maybe the turn signal switch is bad???
Dec 02, 2010 | Chevrolet Lumina Cars & Trucks
Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Jan 31, 2010 | Optoma HD65 DLP Projector
I have no dash lights on my 4runner and cant find any burnt out fuses. Is it likely that the light itself is burnt out?
There are several bulbs in the dash that come on with the headlight switch so it is unlikely that they all burnt out at the same time.I would check the instrument light dimmer switch for power in and out of it before blameing dash bulbs.You should check the plug to the light switch to check for power out of it and to look for burnt wire ends.
Nov 13, 2009 | 1990 Toyota 4Runner
Xbox screw up!
are u getting red lights round the power button??
if so send it back( the red ring ov death)
May 04, 2009 | Video Game Consoles & Games
Signal switch doesnt work
check fuses first if not the fuses there are 2 under dash and in engine compartment/ If its not the fuses then it is the signal switch itself/ Please rate my response thank you very much
Feb 01, 2009 | 1993 Buick Regal
Dash lights ?
they are on the same circuit but they are wired in parallel not series so having a missing bulb will not effect the circuit..
you need to test for power.. the switch sends power to th fuse and for the dash lamps goes through the dimmer switch if there is one fitted, then to the instrument cluster circuit board..
Aug 23, 2008 | 1994 Hyundai Excel
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
