Question about Canon NP 6545 Copier
Canon NP6545 My Canon NP6545 is giving me an E510 error code (Switch power off and back on). I have turned the machine off and back on and it fires up. When I try to copy it gives me the same code again. I need suggestions as what to look for - THANKS!
  • 1 more comment
  • Anonymous Feb 10, 2008
    error 510
  • DalnB Feb 14, 2008
    Still getting the E510 code. Do not know where the feed motor is, I need a manual for the Canon NP6545. Anyone interested in buyng this for almost nothing? I don't know how to work on it, can not get a manual, can not get a service tech (they want $135.00 just to drive out plus $95.00 hr to work on it). If I cannot get it to work it is just in my way. It worked great when it was put in storage.
    I am still getting the E510 code when I try to copy on the Canon NP6545. It says to turn power off and back on but it goes back to the same code when I try to run a copy. Anyone interested in buying this machine at a good price. I do not know how to fix it and technicians want $135.oo to just come out to look at plus $95.00 an hur to work on it. If I thought they could fix it and I would not have problmes again I would let them do it but if I have to have them come back again I pay through the knose. Last month I ran a total of 8 copies in my other machine; I do not need this big a unit anyway.
    Problem Solver:
  • 4 Answers
IF THE SSERVICE MANUAL THAT I OFFERED TO SEND YOU VIA EMAIL AS A PDF IS NO LONGER NEEDED, AND YOU STILL HAVE THE MACHINE, WE WOULD BE HAPPY TO TAKE THAT MACHINE OFF YOUR HANDS. YOUR LOCATION WOULD BE HELPFUL FOR USE TO DETERMINE SHIPPING COSTS.....YOU CAN ANSWER VIA MY EMAIL BOHICARRL@COMCAST.NET. I'M LOCATED IN SLC, UT.
Posted on Aug 10, 2008
  • 86 Answers
JUST UNPLUG THE SORTER
E510 = feed moter fails to rotate/sorter
Posted on Feb 15, 2008
  • 24 Answers
E 510 is the paper feed motor error.Inspect the paper feed drives and gears.If nothing feels wrong change the paper feed motor.you can try to get the motor repaired
Posted on Sep 27, 2007
  • Swaroop js Sep 27, 2007
    Sorry ihave mistaken.E 510 is feeder motor error. Feeder means the unit which comes just under the drum unit.Check the feeder drives for any mechanical damage.if no check the feeder motor
  • Swaroop js Sep 28, 2007
    There is a motor control board also behind the machine. you can check that also
Error C3452
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly
if the code comes back replace the fuser, continue to reset can cause fires.and that would ruin a perfectly good day
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 29, 2014 | Konica Minolta Bizhub C300 All-In-One...
Error code e000 canon np6545
You have a problem with the fuser unit.... You can try to reset it in service mode, but you may need one or all of the following parts > the fuser lamps or the thermister or the thermal fuse.... For some reason the fuser is not turn on or warming up correctly.... Good Luck
May 30, 2011 | Canon Office Equipment & Supplies
I can not do anything on my printer. When I turn it orn the Error Code B200 is flashing on the printer screen. I need to know how to get rid of this code.
That error code is not listed on the known error codes for that model. Something to try is to turn off the machine, unplug the power cord from the power supply for five minutes. Plug the cord back in and turn on the machine. Give that a try and see if that fixes your problem. Otherwise I would suggest contacting Canon customer support at 1-800-OKCANON. Take care & good luck!
Mar 03, 2011 | Canon PIXMA MX850 Multifunction Printer
Hi every one.i have canon copier ir105 gives me error code e602-102. I replaced hard disk ,after that the machine gives me error code e000744-2000 please if any help thank you
maybe the dc controller is also need to replace or try to reset the error first to reset the error code press * 2&8 simultaniously,* then select copier, then select function, then select clear, then select error, then press ok & turn off & on the power switch
Nov 21, 2010 | Canon imageRUNNER 105 Copier
My Canon NP6545 gives me the error "close the upper right door". I have closed all doors several times but the error does not reset. Thanks for your answer in advance. AC.
This issue is most likely related to a switch that is activated by the plastic tab protruding on the "upper right door," I would inspect for this plastic tab and trace it back to the copier end. The tab should rest inside of a hold on the copier; attempt to manually trigger the switch by sticking a screw driver or similar inside the hole and depressing the switch (it's possible there is more than one switch.) If this does not resolve the issue, you either have multiple switches that need to be activated, or one of the switches is faulty and must be reseated or replaced.
-David.
Nov 02, 2010 | Canon NP 6545 Copier
I have a canon copier ir 3035, its giving error code E000002-0000, whars the problem?
this error is power related. reset the fixing error by pressing * 2 & 8 then * Go to function, clear, error switch off the machine then switch on
Aug 21, 2010 | Office Equipment & Supplies
Canon Imagerunner 2200 with error code e000000-0000
Try to enter service mode, and from function clear the error.
Switch off and on. If the problem persists you have a problem with your fixing unit...
Sep 02, 2009 | Canon imageRUNNER C3220 Color Copier
Error code 001. On/off switch trips off after 10 seconds
when you open the front door you,ll find under the disply a smal hole put eny nail in it a doller sign will apeer in the upper left corner of the disply pres
star , 4,star you will see another disply press the right arrow till you find error word press on it and then press star (astresk. the disply will turn off and on again theis error might be from the heater lamp if
it comes again change the hamps
May 08, 2009 | Canon NP 6545 Copier
Np6545- erroe code e522
Hello Good Day amazingfirst! you problem for Canon NP-6545 error code E522 according to my Service Manual the problem is the Sorter push bar motor. try to check the sorter motor, add grease if needed so. just focus on the sorter motor ok! there is no need to reset the error code just on and off the machine and it will automatic reset the error code but make sure that the sorter motor will works ok!
Christopher
Jul 15, 2008 | Canon NP 6545 Copier
Canon NP 6545 Copier Logo
278 people viewed this question
Clive
Clive
old marine
old marine
