Question about Coffee Makers & Espresso Machines
Gaggia syncrony self test - Coffee Makers & Espresso Machines
  • 109 Answers
SOURCE: gaggia syncrony manual
http://www.partsguru.com/GaggiaSyncronyCompactDigitalEspresso.html
Have a look at this site it should have what you need.
Posted on Jan 31, 2008
SOURCE: screen says decalcify - Gaggia Syncrony digital
Fill watertank with descaler solution, place a large bowl underneath the steam wand, locate the button that looks like a sideways 8 or oo or similar, press it for five seconds and the machine will begin auto descaling. Follow further instructions on scree.
Posted on Apr 15, 2009
EsWorld
  • 1618 Answers
SOURCE: gaggia syncrony compact leaking water where
If you remove the tank, does it leak? If yes then check the spring loaded valve under the tank, also check the O-ring for damage.
Posted on Jun 06, 2009
EsWorld
  • 1618 Answers
SOURCE: GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Posted on Jun 09, 2009
SOURCE: No power to Gaggia Syncrony Logic
Re the Gaggia no power problem, the machine does have a re set button, 2 in fact the boiler unit must be removed and the two reset switches are between the sender units (brown in colour).
After disconecting the power source open the machine (top off)The three alan head screws that retain the boiler (front of the machine) unit must be removed it can be lifted clear to gain access to the bottom of the unit where the reset buttons are.
This will save hundreds of dollars in shipping and service fees.
DIY takes about 10-20 min well worth it.
Take care when doing this opperation 240 volts can kill.
Posted on Feb 12, 2010
Gaggia syncrony digital DECALCIFY, I done the prosess but i have the worning about DECALCIFY
You must use the correct tablets for this, gaggia make special decalcifying tablets.
The machine must be cold when running the program.
It takes about an hour to run the solution through the machine.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | Gaggia Syncrony Compact Digital Espresso...
I have a Gaggia syncrony compact coffee machine and the coffee grinder has jammed for the second time. The repair agent employed by Gaggia inform me that they have been waiting for spare parts from Gaggia...
If the grinder jammed it might have been because the grind was too fine, try adjusting coarser then using the + or - lever to add more coffee for proper extraction. To clear jam remove brew unit and locate door to grinder chamber on left, vac out grounds, also beans in hopper. When clean run grinder and set to coarser, then add small amount of beans and test.
Aug 25, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony "ventilate"
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 04, 2010 | Gaggia Syncrony Espresso Machine
Jun 07, 2009 | Gaggia Syncrony Compact Coffee...
Hi! Can you help me with a Gaggia Syncrony Compact Digital please?
gaggia syncrony ,The unit that goes into the side of the machine is jammed , can you help ?
Jan 17, 2009 | Gaggia Syncrony Compact Digital Espresso...
Gaggia Syncrony Compact Rote LED 28 blinkt
Try to prime your machine, if you only get a half cup of water then you have to replace the flow meter in the machine.
Jul 20, 2008 | Gaggia Syncrony Espresso Machine
Gaggia Syncrony no longer rinses during the selftest
Rinse option is in the menu. Click on Rinsing and turn it on.
That should be it.
Saeco and Gaggia Service Center
Coffee Beans, Espresso Machines, and Cleaning Supplies
www.cerinicoffee.com
Nov 03, 2007 | Gaggia Syncrony Espresso Machine
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
