Sharp al 2021
Copier not function. Just keep blinking alternately 4 and H
SOURCE: Sharp AL-1631
try this. Press C (cancel), Press Auto, Press C, press Auto
Enter 14 (code) e Press Print (green)
It´s a code to cancel H4, if it´s don´t work, send me e-mail to montgomery@brturbo.com.br
Posted on Feb 15, 2008
SOURCE: Sharp copier AL-1642CS
Here is what worked for me.
You need to alternate pressing the clear button then one of the auto buttons until the display lights turn off.
First press the clear button (red letter “C” on the unit) then the auto button. (below the word auto there are 3 buttons. Press the one on the far left that has no other markings on it. This will only take 2 or 3 times back and forth.
When the display is blank enter the number 14 (like you were making 14 copies of something) then press the Green (start?) button. Let the copier warm up about 30 seconds and try making a copy.
It worked for me. Still having trouble call Sharp USA 630-378-3590 or Canada 905-568-7140. They were quick and helpful
Posted on May 27, 2008
VonZeppelen
  • 60 Answers
SOURCE: Code CH on Sharp copier
CH code on a Sharp usually means the front door or a side door is not completely shut. Try opening and closing every exterior door until the code goes away. If the CH is flashing, it could mean either an optical or a heat roller fuse might have blown. Have you recently replaced any supplies?
Posted on Feb 27, 2009
xptareq2000
  • 1447 Answers
SOURCE: I have sharp AR-5316E copier, the indicator is
it is the problem your copier fuser unite problem thermostater or heat roller is over temparature . You press # interrupt c inturrupt then 24 press print key 00 then machine is of after on is ok
Posted on Jul 15, 2009
Sharp Tech
  • 63 Answers
SOURCE: Fixya: Sharp AL-1631 copier doesn't recognize new drum?
press the following keys in this order:
  1. Clear Key (far right key on panel)
  2. Exposure Key (far left key on panel)
  3. Clear Key (far right key on panel)
  4. Exposure Key (far left key on panel)
once the panel goes blank make your display show
  • 24 then press your start key
  • then 7 press start
  • press C one time
  • 20 press start
  • 1 press start
Then press C until the copier restarts.
Posted on Oct 16, 2009
Testimonial: "Wow! A solution to my problem with a copier was posted within a couple of hours, and the procedure worked perfectly! Thanks. OB "
Why my Sharp AL-2021 copier displaying error code f2 70 after replacing cartrige chip?
They put chips into cartridges to prevent owners from using other products in machines. If you google this for the machine you will find a work a round for it.
Sep 01, 2015 | Sharp Office Equipment & Supplies
Sharp copier al 2021 shows f2
Hi
It should have a sub code, hold down the copy key.
F2 is toner related, suggest you change it.
CHeers
Andy
Jan 28, 2015 | Sharp Office Equipment & Supplies
My sharp AL - 1457D its not responding it only blinks 4
Hi, there is no error 4 alone it is usually followed by a H that is H4. Try to key in the following C Auto C Auto then enter 14 and press Copy key. If it was power low voltage , it will not re-appear but if it comes back then replace heater lamp and reset again.
Jan 17, 2011 | Sharp AL-1457 Black and White Copier
Meaning H 4 appear alternative Sharp Al-1641 CS
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer). You please enter # interrupt-C interrupt -14-start to clear to clear the error
Jan 12, 2011 | Sharp AL-1641CS Laser Digital Copier
ALARM H and 4 keep blinking -alternating
You have a defective fuser unit. H is for HEAT
Jun 25, 2009 | Sharp AL-1642CS Copier
Green blinking light CH
That is no problem .CH is for that side door is open .just close it or check side door sensor it is dirty clean it .MIAN AKHLAQ
Dec 24, 2008 | Sharp AL 1631 Copier
Sharp al 1000 shows E and 7 and hangs off
if a number and alphabeth appears alternately The copier will not function. Turn the power
switch off, remove the power cord from the
outlet, contact any authorized service
representative for overall service maintainance
May 18, 2008 | Sharp AL-1000 Laser Printer
Sharp AL- 1540cs
On my SHARP AL-1540CS printer 4 and H blinks alternately and none of the buttons except power is working.
Oct 19, 2007 | Sharp AL 1215 Black and White Copier
k24674
jasbo
jasbo
