Question about Sunpak (SDPF-070AW-0US) Digital Picture Frame
Though my sunpark SF-150-420001SL intially when purchased was showing photongs/vedios clear. but for about 6 months i have not used the product and today i plugged it in and started but to my surprise there was no photographs appeared on the screen but only one can hear the songs. please help me how the picture/photo will appear on the screen as was seen previously. i have restarted it many a times.
I purchased a pet fountain. It worked for 6 months and died. I have my receipt as proof of purchase from Pet Smart. Is there any support or good will to replace my fountain?
Have you contacted the manufacturer? The product could still be under warranty. If you want PetSmart to respond though, I recommend trying to get their attention on Twitter.
Oct 02, 2017 | Cats
Hi.. I purchased a demo car from Subaru in WA. There was supposed to be an initial 6 months no payment with their finance. I Confirmed this with them upon sign up. This didnt happen. I purchased due to...
If your signed paperwork clearly shows that you are being charged differently than the paperwork states, tell the dealer that either they fix it or they can take the car back. You may have to seek legal redress to get this fixed. If your paperwork does not show it clearly then you might have a problem getting them to fix it as they might dig in their heels and say you just did not read what you signed. Unfortunately, just because you "thought" you were getting six months of no payments means nothing if your paperwork does not indicate that. They might very well say you bought a demo and only new products qualified for that promotion. Good luck.
Dec 10, 2014 | Computers & Internet
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Scanner not detected
I have the same problem with my Canoscan LiDE 25 scanner used sparingly since purchase in 2008. Last used 3 days back after a gap of a few months when it scanned a few pages and then stopped working. On connecting the scanner to my laptop on Vista Home Premium 32-bit it shows "USB device not recognized". No change in status after uninstalling drivers, cleaning my system, and reinstalling drivers from the Canon CD, or Canon US site, or Canon UK site. Even tried VueScan but this also does not recognize the scanner. I find it hard to believe that a Canon product stops working in barely 5-6 years even though it is very sparingly used and stored in the original packing when not in use.
Jul 03, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Sharp SF 2030: How do I clear code 115?
we don`t have code 115 in 2030 model .maybi it is H5 but your led doesn`t show.
May 18, 2010 | Office Equipment & Supplies
Cant view vedio log on GeoVision GV-600
Okay - try going into the software directory and delete the files maked .db there should be one for each camera. Then start the software and try it again.
May 14, 2009 | Geovision GV-800-16 Video Capture
Misfiring
There are some common things that causes a misfire, one of them could be a faulty spark plug or a bad spark plug wire, another could be a clogged fuel filter, if both of those solutions fail try having the timing checked. Good luck.
Mar 11, 2009 | 2001 Audi TT
How do i clear the memory on my phone so that it doesn't show any used number that are not saved as contact?
do a master reset of the phone
MENU/SETTINGS/INTIAL SETUP/master clear/reset - 000000
Jun 28, 2008 | Motorola Mobility V220
Job waiting message appears on screen.
You can selectively clear information stored in your machine’s memory.
1. Press Setup on the control panel. The display shows the first menu;
FAX NUMBER/NAME.
2. Press ➛ or ❿ until ‘MEMORY CLEAR’ appears, then press
Start/Enter. The display shows the items you can choose to clear.
• FAX NUMBER/NAME : your fax number and name are cleared from
the machine’s memory.
• DIAL/SCHEDULE : clears the one-touch, speed dial, or group dial
numbers stored in the memory. In addition, all
the Schedule Job operations you have reserved
are also cancelled.
• JOURNAL : clears all records of transmissions & receptions.
• DEFAULT SETUP : restores all the option settings to factory default.
Only clear de Journal, don't clear the other.
Try this if it resolve the problem.
Nov 20, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Sunpak (SDPF-070AW-0US) Digital Picture Frame Logo
383 people viewed this question
Top Sunpak Photography Experts
Andrew Taylor
Andrew Taylor
richie46
Jay Plesset
Are you a Sunpak Photography Expert? Answer questions, earn points and help others
