Question about Morphy Richards 9-In-1 Upright And Handheld Steam Mop, 1500 Watt
Instructions for the 9 in 1 steam cleaner - Morphy Richards 9-In-1 Upright And Handheld Steam Mop, 1500 Watt
Quest Steam 9 in 1. How do I fill with water and use it?
You'll need a very small funnel. only fill with distilled water or you will clog it up after a few uses and it cannot be fixed once this happens. The fill cap may seem loose, the is because it doubles as a pressure safety device. It's fine to seem loose just close it as best you can.
Sep 06, 2015 | Quest Mop Steam Cleaner, 900 Watt
Steam cleaner
it's likely that mineral build up is causing this. Put some white vinegar in the reservoir with your water.Allow it to sit a bit, working the trigger. Then put your mop in the bath tub or somewhere that you can allow it to steam without concern. Steam the entire contents of vinegar/water through. The vinegar should clear out the mineral deposits.
Aug 12, 2014 | Morphy Richards 9-In-1 Upright And...
Why is there no steam coming out???
It is very likely the water reservoir is clogged with calcium build. Follow instructions on cleaning the water compartment.
http://s3.amazonaws.com/images.anvid.com/ssm-3006.pdf
Jul 07, 2014 | Sienna Luna Plus Steam Cleaner and Steam...
How do i register my steam cleaner
If it's new, register online with manufacturer and keep your receipt, serial numbers and product numbers handy as you will need.
Mar 28, 2014 | Morphy Richards 9-In-1 Upright And...
Instruction manual for Little Yello Steam Cleaner
what brand name is the model BISSELLL/ SHARK/HOOVER/?
Nov 20, 2012 | Vacuums
Have lost the instructions of use for steam cleaner are they online?
Hi
Please see this website
http://www.ehow.com/how_7877025_hand-steam-cleaner-instructions.html
thanks
May 11, 2011 | Vacuums
I purchased a Bissell steam cleaner demo, and I have no working instruction.
Go to www.bissell.com and click on the customer service link and have them send you a copy. If you purchased the cleaner brand new and it had no instructions with it, they SHOULD NOT charge you.
Mar 05, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
I bought my euro-pro steam cleaner
I have the manual in a pdf file. Email me and I'll forward it to you
Rich
Jan 23, 2009 | Euro-Pro S3325 Handheld Steam Vacuum
Morphy Richards 9-In-1 Upright And Handheld Steam Mop, 1500 Watt Logo
51 people viewed this question
Top Morphy Richards Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Morphy Richards Heating and Cooling Expert? Answer questions, earn points and help others
