Question about Sony Playstation 3 (PS3) Console
Hi everyone i have problem with my ps3 cech-3004b 320go it shuts off by it's self after a few min of playing i watched many videos on youtube and it's semes that the power supply is doing this i tryed to fix it by turning the ocp and pfc screwos cw and ccw but that didn't help it just make it worst
  • 3 Answers
Have you tried runnning it with the top off ?
is the fan working ?
if it is, is it fast and making a noise?
that would be overheating and shutting down to prevent heating
OR
as you said Faulty power supply, if a power supply is faulty I would just replace the whole power supply as they are cheap on ebay.
Good Luck
Posted on Oct 25, 2013
SOURCE: ps3 shuts off during gameplay
My PS3 shuts off 15 minutes after I play can I fix the problem in system settings
Posted on Jul 06, 2009
flacooo1
  • 172 Answers
SOURCE: ps3 3 blinking lights
Hi my name is Juan and unfortunately your ps3 is dead what happen is that for some reason it got so hot and the processor stop working when you turn on the ps3 it does a self test and if something is not working right it turns off immediately with a green yellow red light so don't spend your money in another power supply I can guaranty to you is not the power supply I do sell and fix playstations and this is why I know this this problem is common on the 60Gb and 80Gb also in 40Gb but not like on the 60and 80Gb
Posted on Mar 13, 2009
SOURCE: ps3 yellow light then red flashing light
its a overheated hd.
Posted on May 18, 2009
Big Hev
  • 64 Answers
SOURCE: help it freezes
Does this freeze up occur around the time the fan kicks on? I've seen several other contributors to FIXYA mention this as a "heat sink" issue. I guess the HD is getting over-heated & melting a soldered connection. This is definitely a problem that a tech should look at. Hopefully your console is still under warranty. If not, PSR has very decent rates for "out-of-warranty" work. You can contact them at www.psr1.com. Hope this helped.
Posted on May 19, 2009
  • 7 Answers
SOURCE: My PS3 hdmi cable does not work
First off, if you want to use the hdmi remove the supplied composite cable from the back of the ps3.
You don't need both plugged in at the same time, and I'm not sure with the ps3 but some video devices will not enable both at once.
Have your tv selected for whatever hdmi input you have it plugged into. They should be labeled where you plug them in.
With the unit in standby, switch off and red light in front, hold the power button by the disc tray for 3-5 second. You will hear it beep, after the initial turn on beep, then you should see a display set up screen.
If you switch back to the composite, you will have to do this over again.
How to take a ps3 slim CECH-4002C apart?
The are 2 problems questions.
Answer 1: Search on YouTube.
Answer 2: Make sure the HDMI/video cable is connected properly from your PS3 to your TV.
Jul 19, 2013 | Video Game Consoles & Games
My ps3 keeps frezzing through games
if its freezing while reading, it maybe your rsx chip is beginning to spread apart from your motherboard.. how old is your unit.. first try cleaning your lens before purchasing one.. if you have to purchase a lens check ebay against CECH model(CECH-2501A, CECH-K01) then see what the return policy is.. NO RETURN, 3 DAYS, 10 DAYS.. if that lens doesnt work for you return it quickly, chances are your lens is still good.. then you will have to look into the heat gun 4 penny trick.. if its under warranty($150).. out of warranty the cost to fix is roughly $50.. if you dont have the tools already around..
home depot- has a heat gun in the paint department for $22..radio shack- ceramic thermo paste $8 or artic silver thermo paste $12..
radio shack- home depot- percision screw kit $12and last but not least $.04 from your change and an hour of your time..
find a you tube video to help you disassemble your unit
http://www.youtube.com/watch?v=BhagHRSTd5I&feature=related
i copy this guy, movement for movement.. each time i fix freezing/ ylod/ rlod/ glod/ black screen units.. i use a painters Wagner yellow heat gun unit on high..
http://www.ps3iso.com/ps3-tutorials/77803-play-station-3-green-light.html
spreading thermo paste- should be a little thicker than a sheet of paper covering entire video chip and cpu chip..
place the four pennies touching side by side forming a square in center of the video/RSX chip only.. i dab thermo paste in the center of pennies, dont bother spreading..
MY KIT: Power drill for case only/ unscrew only.. empty ceramic package is perfect for a screw container.. piece of wood i drilled a hole thru wood for the power prongs to fit thru from motherboard.. wood is to protect other surfaces from heat.. $8 ceramic2 from radio shack.. 7_7_2012_9_16_13_pm.jpg
Jul 07, 2012 | Sony Playstation 3 (PS3) Console
My ps3 turns off by its self after 5 to 10 mins
Probably overheating, use a vacuum first of all to **** out any dust dragged into your vents, if that doesnt sort it, theres a guide on opening up you ps3 on youtube (you need a special screwdriver) follow this
http://www.youtube.com/watch?v=3LlvjGS1xUA
Apr 21, 2011 | Sony Playstation 3 (PS3) Console
When I try to watch a video it will play a few seconds then stop then will play again for a few seconds what can i do
this happens if you have a slow internet connection...
There is a high demand for the video
your video card is not up to snuff...
cheap fix... pause the video and wait till the red bar is all the way to the right or full...
then play...
if that still doesn't work then
upgrade memory... and do the pause trick
still doesn't work... upgrade video card and try pause trick...
still doesn't work... get a new computer...
Feb 06, 2010 | YouTube Videos
Ps3 plys movies but no games?
i have posted some videos below i reccomend following them - only if warrentee is gone.
http://www.youtube.com/watch?v=Q6A6V7LlReI&feature=related
http://www.youtube.com/watch?v=7O-8NzYHr80&feature=related
Thanks CBZ123
Dec 19, 2009 | Sony PlayStation 3 40GB System
Will not read disc
open your PS3 up and use a dust cleaner to blow the dust off!it could be overheating. and if that works next time you play pull it out of a confined place and when youre done wrap it in a towel and put if where it should be to prevent dust getting in
Aug 12, 2009 | Sony Playstation 3 (PS3) Console
Ps 3 wont load games cd or dvd
Hi mate
Call sony in this case as long as you do not open your console yet. before speak to them tell then that your ps3 is no longer reading discs they have been know to repair it for free.
It the laser gone most probably the KEM400aaa you can tell by the CECH**** code on the end of the serial number
If they will not repair for free it will be a cost of £99.00 or you can repair your self by replaceing the laser around £65.00
Jul 14, 2009 | Sony Playstation 3 (PS3) Console
PS3 Refuses To Play Certain Games
do we really need the Sony PS3 2.43 update to fix the current 2.42?
Sep 19, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
263 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
