Question about Watches
I have a diesel dz7125 watch. the black adjustment knob just fell off. this is the 2nd one that this happened to. how do i reattach?
Diesel watch dz7125 the digital display for TIME 2 has gone blank. Analog times (1,3 & 4) still run, and keep time.
probably needs a new battery there will be two batteries one for digital and one for analog,,
Aug 11, 2013 | Watches
My Diesel DZ4119 fell on the ground and broke the glass. Where can I replace it?
I suggest that you take it to the nearest Deisel store and ask them to send it away for repair.
If you don't know where your nearest store is, go to Deilsel.com and click on "store locator".
Jan 11, 2011 | Diesel DZ4119 Watch for Men
HI, I have a dz7069 can you please help me how to set the minutes in time two, we can set the hour for time two but not the minutes Thanks,
The best advice I can offer you is this.
Setting the Watch
  • Pull on the watch's knob, located on the right side of the face. It will pop out to a wider setting, one notch outward. This notch is the hour and minute setting for your watch. Turn the knob to move the hour hand, and set the proper time. Press in on the knob, against the spring, until you feel it hit the base. Wait to verify that your second hand begins moving, indicating that your watch is keeping the correct time.
    On digital watches, press and hold the top button until the time begins flashing. Use the bottom button to move the hour and minute. Press the top button again to replace the new time and set your watch.
  • Repairs and Service
  • Keep your receipt and warranty paperwork in a safe location. This documentation will be important for repairs, resale and service. Visit your closest Diesel store for repairs requiring mechanical adjustments--or a trusted jeweler can handle the maintenance such as wristband alterations. Note that your Diesel watch may use links, held in place by small pins. These pins are best removed and adjusted by a jeweler or watch technician, so as not to damage the quality and value of your watch.
  • Aug 17, 2010 | Diesel Digital Dz7069 watch
    I have an omega speedmaster and the bezel fell off I want to r
    Any good quality SUPER GLUE will do the job. Apply to the case only and push the ring straight away onto it. Make it precise first time, as there will be no aligning possible afterwards. Rate me, please.
    Apr 08, 2010 | Rolex Daytona 116528 Wrist Watch
    Screws fell out of band
    All the screws used in watchmaking are very specialized and usually custom made for every specific watch model. You will not be able to by them anywhere, so, the only solution is to find your nearest watchmaker shop and ask for the new screws. Expect to pay around $5-$7 for each screw (based on prices in U.K.)
    Do not forget to rate, please.
    Mar 06, 2009 | Diesel Chronograph DZ4112 Watch
    Tag Heuer watch
    The knob is a screw-cap seal. When closed (screwed in) it closes the chamber to prevent water from entering the watch.
    You will need to unscrew it. It should snap out. In this position, you can wind the watch. Pull the knob out one click, and you can adjust the date. Pull the knob another one more click, and you can adjust the time.
    Push the knob back in. In order to seal the watch back up, you will need to push the knob in while turning the knob. You will know you did it correctly when the knob will not turn any further.
    Good luck.
    Dec 25, 2008 | Tag Heuer AquaracerWAF1110.BA0800 watch
    Dz7045 diesel watch how do you adjust the time?
    Contact Diesel by email or phone.
    Diesel Time Frames Customer Service
    2280 N. Greenville Ave.
    Richardson, TX 75082
    TEL: 800-699-2556
    customerservice@dieseltimeframes.com
    Dec 22, 2008 | Diesel Audio Diesel Watch
    Cracked glass
    Hello Albert,
    You won't be sorry...
    There's only one thing to do... unless you are an
    accomplished watchmaker...
    Send it in for an AUTHORIZED repair...
    Being in the USA .... (see below... (call them ... regardless).
    I'm going to assume you are not in Switzerland...
    Look for "AUTHORIZED" repair on the internet.
    The PLACE I found appears to be having license issues w/DIESEL... with some encouragement I'm sure
    you can convince them to "HANDLE" your situation.
    ELSE
    Search locally... on: Diesel DZ-4126 authorized repair
    Happy hunting...!!
    http://www.watchrepairsusa.com/diesel/watch-repair
    Carnac the Magnificent
    Jun 17, 2017 | Diesel Chronograph Dz4126 Watch for Men
    Watches Logo
    15 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
