Question about Digital Peripheral Solutions Q-See QT426-818-1R DVR and Cameras Security System - 16-CH, H.264, Netwok DVR, 1TB, 8 CCD Cameras
How do I restore my Q-See QT426 to factory setting? I dont have the password I purchased this unit from craigslist
My acer tablet screen froze after I accidentally deleted apps that I don't need. How can I fix other than buying a new tablet
First, try rebooting. If that doesn't fix it you may consider restoring the device to the original factory settings. A word of warning...restoring to factory settings will take the tablet back to the way it was when originally purchased. All passwords, updates, music, photos, videos, audio recordings, apps and so on added after it was purchased will be deleted. So don't do this if you are concerned about losing the aforementioned data and files. To do a factory reset go to settings and look for a restore option. It may be under something like system restore, device settings, back up and restore or something similar. Once you find it, it should warn you that your device will be restored to factory settings and that all post factory apps, passwords, data and files will be deleted. If you still want to restore your device follow the instructions. You will then have to set everything up from scratch as if it was just purchased. I did this with a Kindle Fire. After the factory restore I reinstalled my apps, added all my accounts (email and so on), downloaded all my books, music, etcetera, and it has worked great since.
Jun 18, 2017 | Acer Tablets & eReaders
How can i restore factory settings without password
You can only restore the BIOS settings by selecting F2 on reboot. You need the password to restore operating system settings. Geek squad can break password.
Jul 20, 2014 | Dell Inspiron 560 PC Desktop
How to reset password for q-see dvr model qt426
try to remove the cmos back up battery inside the DVR and install back the battery in invert position to short the polarity. Leave it overnight and install back the battery in the proper position and turn on. tyr to log in USERNAME: admin PASSWORD: 123456
Oct 27, 2012 | QPS Q see QT426 Video Surveillance System
I forgot my pattern password. i have try it a lot of time already n now its stuck on log in on google. i dont have a google account so how can i break this password.
The only way your going to get rid of that password is with a factory reset. I havent been able to find much info on this tablet but generally it involves, with the device off, hold the power and up volume until you get a menu. There should be an option to factory restore the device. This is your only opption if you dont kniw the password.
Secondly all android devices do require a gmail account, so if you have purchased any apps you should contact google to get your gmail because all your purchases are linked to it. If you havent purchased anything tthen just create a new gmail account when prompted after the restore.
Commnt if you need additional assistance.
Aug 04, 2011 | Coco Epad - -10.2 Inch Touch Screen Google...
I want restore code of spice mobil m-4580
i have no remembered Restore Factory settings input password, i want Restore Factory settings input password
Mar 17, 2011 | Cell Phones
Nokia N95(black) restore factory settings
the default code is 12345. if you have entered a security code in your phone, use it to restore to factory settings
Aug 04, 2009 | Nokia N95 Cellular Phone
Reset DWL 2700AP to factory defaults
Hi dear try to flow this tips it will help you
Administrator Settings
Administrator settings allow you to customize User Name and Passwords as an Administrator of DWL-2700AP. The default value of the Username is "admin" with no password entered.
Password
Enter a password in the Access Point Password field. Type the password again in the next field to confirm it. The Password is case-sensitive ("A" is a different character than "a",) and must be between 0 and 12 characters in length
System Settings
You may reset the DWL-2700AP back to factory settings by clicking on Restore Default settings.
Restore Default Settings
Choose Yes and click Apply to restore all Access Point settings to the factory default settings.
Thank you
Imran
Pls rank as possible
Apr 20, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
Forgot password to acess< and or its still default setting. could you tell me what the wireless 700 routers default password is
Restore Factory Default Settings When you restore factory default settings to the base station, you clear your Internet connection settings and any special base station configurations that you have established. After the restore is complete, you will need to reconfigure your base station settings or restore these settings from a backup file. You should restore the original factory default settings only under the following circumstances: O You are experiencing serious problems with your base station, and resetting the base station does not fix the problem. O You cannot remember your base station password. In this situation, you must restore the factory default settings by using the Restore button on the base station, and then use the default password admin to log on to the Base Station Management Tool. To restore factory default settings 1. Open the Base Station Management Tool, and then click Management. 2. On the Management menu, click Back Up and Restore Settings. 3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory default settings are being restored to the base station, the Power light on the base station turns orange. When the light is solid green, the settings have been restored. If you want to open the Base Station Management Tool after the settings have been restored, type admin as the password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the Power light on the base station is solid green. After you restore the factory default settings to the base station, you should navigate to each page of the Base Station Management Tool and reestablish the network settings you want, or restore the base station settings by using a backup file. For information about creating a backup file of your settings, see the following section. Be sure to establish your unique base station password as soon as possible after restoring the factory default settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station Password.” please rate this answer, thanks
Jan 30, 2009 | Microsoft MN-700 Wireless Router
Need to restore acer to factory settings
contact acer you can get there number from the website and they will let you purchase a restore disc for 15bucks
Aug 20, 2008 | Acer Aspireā„¢ T180 PC Desktop
Digital Peripheral Solutions Q-See QT426-818-1R DVR and Cameras Security System - 16-CH, H.264, Netwok DVR, 1TB, 8 CCD Cameras Logo
134 people viewed this question
Top Digital Peripheral Solutions Home Security Experts
Lawrence Oravetz
Are you a Digital Peripheral Solutions Home Security Expert? Answer questions, earn points and help others
