Question about Canon ImageRunner C-3170U Copier
Canon lbp 7200 error E070 - Canon ImageRunner C-3170U Copier
4 Suggested Answers
muleskinner2
  • 270 Answers
SOURCE: error E070 0002
I don't know which model you're having problems with but if it's an IR-C2058 the error has to do with the Transfer Belt. The 0002 says the transfer belt sensor ( S51 ) continues to detect the home postion for transfer belt. I don't know what kind of work you've done to the copier, if any, but the error will have to be cleared up first. Let me know what model and I can help alot more. Good luck.
Posted on Feb 12, 2008
  • 1894 Answers
SOURCE: Canon Printed LBP 5200 Error Code E000
This error indicates fuser error, its not heating up.
Posted on Aug 10, 2008
pineworks
  • 4041 Answers
SOURCE: IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Posted on Feb 16, 2010
How to fix error lights.
we are reading this blog http://www.canonprintersupportnumbers.com/blog/how-to-solve-canon-printer-e02-error/ here define some steps if you are free read this Steps To solve Canon Printer E02 Error
Jul 26, 2016 | Canon imageCLASS LBP-7200CDN Color Laser...
How to solve the problem of canon it 7200 error code E000246-0001
Canon Ir 7200 Service Manual Pdf - WordPress.com
https://crocynsuti.files.wordpress.com/.../canon-ir-7200-service-manual-...service is one manual of the 7200 free most the impending hazards canon due to 7200free imagerunner ... Error Codes _ Canon _ iR7200 _ Code E121-0001.
Jul 16, 2015 | Canon Office Equipment & Supplies
Canon printer lbp 3310 paper sensor error flashing red when full of paper
my canon LBP printer 3310 the error is alarm light on what the problem
Apr 03, 2013 | Canon i-SENSYS LBP-3310 Laser Printer -...
I have find the error in printer canon lbp 2900 scanner error
First of all you are not sure about your product and problem
When LBP-2900 is only a printer.
No any other combination is present
No scanner OR Copier
May 12, 2011 | Canon LASER SHOT LBP-2900 Printer
E070
getfile.asp?rid=1258 April 12, 2007 getfile.asp?rid=3215 Product : iR6800
iR6870 Title : E070 Problem :
E070 error code.
Sensor reflectors on the inside of the ITB become dirty and do not reflect the light properly from the home position sensors.
Note* - If the equipment is not properly serviced, in regard to filters, the equipment filters can clog up and cause stray toner to build up in the ventilation area. If this occurs, there is a chance that HVT2 can become contaminated and copy quality issues will occur.
Additionally, soiling the white ITB patch may also occur causing E070 error code.
Solution :
Clean the reflective surface inside the ITB or replace ITB.
In regards to filters - Be sure ALL 6 Filters are replaced and/or cleaned at it's proper intervals. If ALL 6 filters are not addressed, poor ventilation will occur and toner can contaminate HVT2. If contamination of HVT2 happens replace HVT2.
HVT2 = FM2-0528-000
ITB = FC5-1658-000 Canon USA, Inc. Systems & Technical Support Division
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
Canon 3170u error E000070-0002 how to fix this problem
E070 ITB HP detection error
0001 HP of the ITB fails to be detected even
after the specific period of time.
Abnormality of the HP sensor,
Deviation of the belt from its position to
either edge, or soiling of the seal
Clean the HP detection seal, Clean/Replace the HP
sensor
0002 The next HP fails to be detected within
the specific period of time after the HP
of the ITB is detected.
Clean the ITB back side and the drive roller
BE CAREFULL TO REACH THE WHOLE ITB UNIT YOU NEED TO REMOVE FIXING UNIT TOP COVERS IN PAPER DELIVERY SECTION, IT NOT WOULD BE BAD TO REMOVE RIGHT DOORS OF COPY MACHINE, REMOVE ITB CLEANING BLADE UNIT,...
Jan 10, 2010 | Canon ImageRunner C-3170U Copier
E070-003
when i open the printer the unit will int.rot. and then the error will appear. tnx...From Canon Support Product : imageRUNNER C3100 / C3170 Title : E00351-0000 Problem
May 05, 2009 | Canon iRC3100 Printer
Error E070 0002
Feb 11, 2008 | Canon imageRUNNER 400S Copier
old marine
old marine
