Light on dash - Office Equipment & Supplies
    Champion:
  • 219 Answers
Check the trouble code. Or is the light not working? If so check the fuse
Posted on Oct 18, 2013
WHY DOSE MY DASH NOT LIGHT UP WHEN HEAD LIGHTS ON
There is usually a dimmer switch for the dash lights near the left side of the dash behind the steering wheel. Sometimes that can get bumped when you get in the car and turn the dash lights completely off.
Oct 26, 2015 | 1991 Nissan Maxima
Dash light flicker and tail lights don't work.brake liters and turn signals work
dash lights flickering due to loose ground under dash-check fuses on the parking lamps cheers Denny
Oct 31, 2013 | Cars & Trucks
My dash bored wont stay lite at night with my lights on in my 1992 Buick
There are few help links provided to resolve this issue of dash board light not working.Click the link below to go through its procedure:-----Dash board lights not working? http://repairhelpcenter.blogspot.in/2012/02/dash-board-lights-not-working-on-gmc.html
----------- light in the dash blinks? http://repairhelpcenter.blogspot.com/2012/01/overdrive-light-in-dash-blinks.html
-----------Orange O/D warning light flashing on dash? http://repairhelpcenter.blogspot.com/2012/01/orange-od-warning-light-flashing-on.html
---------gauge on the dash quit working on? http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html---------No 4x4 light on dash? http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
----------Digital Dash Display not working? http://schematicsdiagram.blogspot.com/2011/12/cadillac-seville-digital-dash-display.html
---------warning on dash and alarm sounds? http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
---------Light Stays On dash of car? http://schematicsdiagram.blogspot.com/2011/06/brake-indicator-light-stays-on-dash-of.html
----------The ABS and Traction Control Lights stays ON dash of car? http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
----------warning lights remains steady on dash? http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
---------light bulb under dash replacement?
http://schematicsdiagram.blogspot.com/2011/12/heating-knob-light-bulb-under-dash.html
Parking lights, tail lights and dash lights not working? http://technoanswers.blogspot.com/2012/01/parking-lightstail-lights-and-dash.html
How to replace Instrument panel and dashboard?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-instrument-panel-and.html
Tail lights and dash light fuse keeps blowing? http://technoanswers.blogspot.in/2012/02/tail-lights-and-dash-light-fuse-keeps.html
This will help.
Thanks.
Feb 19, 2012 | 1992 Buick Century
Dash and interior lights do not work
Dash lights are on the same fuse as the tail lights. Dash lights not working is an indication that the tail lights are not working. The first thing to check is that the tail light fuse is not blown. Most of the time replacing the tail light fuse will restore both the tail lights and the dash/interior lights. If this is not the case you may have to trace the wires and look for a broken or unplugged wire in the harness.
Nov 18, 2011 | 1994 Nissan Quest
Insturment lights do not turn on
CHECK TAIL LIGHT FUSE, THAT FUSE SUPPLIES VOLTAGE TO THE DASH LIGHTS FUSE. IF THE TAIL LIGHTS ARE WORKING, CHECK THE INSTRUMENT FUSE. IF BOTH FUSES ARE GOOD, TURN THE DASH LIGHT ADJ. BACK & FORTH, IF STILL NO LIGHTS, I WOULD REPLACE THE DASH LIGHT CONTROL. WHILE CHECKING THE DASH LIGHTS YOU MAY HAVE TO COVER YOU & THE DASH WITH A BLANKET TO MAKE IT DARK AROUND THE DASH.
Nov 25, 2010 | Chevrolet Camaro Cars & Trucks
My dash light dont work at night
what dash light.? if the entire illumination of the dash does not work the dash light dimmer is probably bad.i think it only has two wires take it out and jump accross the two terminals after unplugging it.lights work bad switch.
Feb 19, 2010 | 2001 Chevrolet Impala
When I turn on the headlamps the dash lights go out. Guages all work, radio display disappears also. fuse is good and tried changing headlight switch
Get a test light,and ground the clip,put the tip of the test light on the dash light fuse.Turn the knob to dim,and brighten the dash lights,see if the test light reacts with the dimmer switch.If it does not,then there is a wire jumped to by pass the dash lights somewhere.If the test light dims,and brightens,then there is a wire of going to the dash,or bad connection where the harness clips into the dash.
Oct 28, 2009 | 1989 Ford F 150
Dash light will not come on. I figure bulb needs replacing. where located and how to get to?
there is more than one bulb that lights the dash. very rare that all burn out at the same time. Check to make sure the dash light dimmer control is not turned all the way down. check all the fuses. If those are all ok it is most likley the dimmer control has went out. The dash light dimmer control on these modles have had alot of problems. I have replaced several for the problem you are having.
Oct 25, 2009 | 1995 Nissan Pickup
11 people viewed this question
jasbo
jasbo
