Question about HP LaserJet Pro 400 M401DN Laser Printer
HP LaserJet Pro 400 M401DN Laser Printer firmware
Ready 2 download
ginko
  • 19396 Answers
SOURCE: ''HOW TO DOWNLOAD FREE INSTALLATION OF HP LASER JET 1200 SERIES''
Download the drivers from the page below and follow the instructions:
HP LaserJet 1200 Printer series - Download drivers and software
Posted on Mar 28, 2009
  • 24 Answers
SOURCE: Free HP LaserJet 1300 Printer Driver
Friend,
All HP drivers can be found on www.hp.com and with a few (VERY few) exeptions they're all for free. You didn't state what operating system You have, so I'll give you a link for the download "start page" for Your printer: LJ 1300 download page
Skip the "CD-ROM order page" and go for the "Driver" section. You can chose between three printer driver types, but for "everyday" printing I'd go for the PCL6 driver.
Hopefully this solves Your problem. If not, or you have further questions regarding installing this printer, feel free to ask.
//Al
Posted on Apr 16, 2009
  • 123 Answers
SOURCE: HP laser jet 1522nf mfp ( firm ware corrupt ready 2 download)
Perform the following troubleshooting in the order listed:
  1. Turn off the printer, with the communication cable still attached.
  2. Clear the print spooler by doing the following:
    1. Go to Start then choose Run .
    2. Type net stop spooler , and press Enter .
    3. The Windows XP spool directory is located at: C:\WINDOWS\SYSTEM32\SPOOL\PRINTER ; Delete every file within this folder.
    4. Go to Start , then Run , and type net start spooler , and press Enter .
  3. Manually delete and reinstall the driver:
  4. To uninstall printer driver, refer to the following steps:
    1. Open Printers folder and right click the driver that you wish to delete.
    2. Within the menu, select Remove .
    3. For the confirmation message displayed, click Yes .
    4. Right click the Printer Folder and select Server Property .
    5. Click Drivers tab, and select the driver for deletion. Click Remove .
    6. For the confirmation message for the deletion, click Yes .
  5. Install the printer driver manually as follows:
    1. Select the Printers and Faxes option from the Start menu.
    2. Click "Add a printer" then, on the resulting "Add Printer Wizard" dialog, click Next.
    3. Ensure the option "Local printer attached to this computer" is selected. Untick the checkbox "Automatically detect and install my Plug and Play printer". Click Next.
    4. Ensure that the option "Use the following port:" is selected then select the appropriate port from the drop-down choice box. When choosing port, use one of Virtual Printer Ports for USB to which is your printer connected to. Click Next.
    5. Click the "Have Disk..." button. On the "Install From Disk" dialog, click Browse... then navigate to the appropriate directory to which the software/driver extracted.
    6. Select an inf file then click the "Open" button. Click OK on the "Install From Disk" dialog.
    The Add Printer Wizard will start to copy driver files to the PC.
  6. Run the firmware upgrade with the printer turned off so that the printer accepts the firmware only after the entire file is spooled.
  7. In the firmware update program's window, choose your printer (manually installed) and press Send Firmware button, and wait for the firmware to be spooled completely.
  8. Power-on the printer.
  9. During the printer firmware update, the liquid crystal display (LCD) on the printer control panel will display Printing Document and will change to Erasing . After a short while, the LCD display will change to Programming . After a short while, the LCD will display complete The Ready LED on the printer will start flashing. The printer will automatically power off and then back on to reboot, and will make noises similar to that of a power-on operation.
Posted on Jul 14, 2010
seeker5211
  • 1089 Answers
SOURCE: Hi, I have an HP LaserJet
Not good.
Will it let you download the firmware again? If yes, hold your breath and reinstall firmware.
If no, replace the formatter.
Posted on Feb 10, 2011
BaronVonNuke
  • 1915 Answers
SOURCE: My hp laserjet M1522nf is
You need to connect the unit via USB and then run the HP firmware update utility so that the current firmware can be installed. This error is usually caused when a firmware update is interrupted. Current firmware for this unit is 20100902.
Posted on Mar 05, 2011
What is 59.A0 Error in hp laserjet pro 400 printer?
This is usually a motor code, turn off, unplug wait 2 to 3 minutes plug in and try, may work good luck
Mar 28, 2017 | HP LaserJet Pro 400 M401DN Laser Printer
HP laserjet pro m401 dne does not print
you replace toner cartridge 80 a then ask questions
Feb 20, 2017 | HP LaserJet Pro 400 M401DN Laser Printer
HP LaserJet Pro 400 M401DN Laser Printer keeps jamming at cartridge.
Is the paper stopping just at the cartridge or is it in the fuser. We have had a few of these fail with bad fusers. The only time we have had a cartridge issue is if the drive shaft on the right side of the cartridge falls off.
Sep 14, 2016 | HP LaserJet Pro 400 M401DN Laser Printer
Hp laserjet pro 400 m401dn keeps going offline.
I would upgrade the driver first. You can also do a factory refresh which brings the printer back to the original condition. Make sure that you get the ip address off the config page just in case you need to reset the settings.
May 09, 2016 | HP LaserJet Pro 400 M401DN Laser Printer
Printer printing crazy symbols
just delete all print from printer and restart printer and computer then try again
happen because some cancellation of print during priting
Mar 31, 2014 | HP LaserJet Pro 400 M401DN Laser Printer
HP LaserJet Pro 400 M401DN Laser Printer Logo
810 people viewed this question
Seeker5211
Seeker5211
