7*7* how to stop - Computers & Internet
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
Reboot in safemode
Posted on Oct 24, 2013
2004 chevy impala brake light isses switch has been replaced and so have fuses and bulbs still no lights
Do you know how to test using a DVOM - digital volt ohm meter ? Is there B+ voltage going into the brake light switch ? An coming out when the brake pedal is pressed ? What fuse's ? There is only one fuse for the brake lights !
The BRAKE SW fuse in the RH I/P fuse block supplies battery positive voltage to the normally-open stop lamp switch. When you press the brake pedal the switch contacts close and battery positive voltage is supplied to the left and right stop lamp assemblies and to the center high mounted stop lamp (CHMSL). The left and right stop lamp along with the CHMSL are grounded at G302.
Do you know about the right insturment panel fuse box ?
Stop Lamps Inoperative
Step
Action
Yes
No
Schematic Reference: Exterior Lights Schematics
Did you perform the Lighting System Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Lighting Systems
Press the brake pedal.
Do all of the stop lamps illuminate?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
Are all the stop lamps inoperative?
YES - Go to Step 4
NO - Go to Step 7
Inspect the BRK SW fuse.
Is the fuse open?
YES - Go to Step 14
NO - Go to Step 5
5
Disconnect the stop lamp switch.
Using a test lamp connected to ground, probe the battery supply voltage circuit of the stop lamp switch connector.
Does the test lamp illuminate?
YES - Go to Step 6
NO - Go to Step 13
6
Install a fused jumper between the battery supply voltage circuit and the stop lamp switch signal circuit of the stop lamp switch connector.
Do the stop lamps illuminate?
YES - Go to Step 12
NO - Go to Step 17
7
Determine if the center high mounted stop lamp is inoperative or the stop/turn lamps are inoperative.
Are the stop/turn lamps inoperative?
YES - Go to Step 8
NO - Go to Step 9
8
Do the turn lamps operate normally?
YES - Go to Step 17
NO - Go to Turn Signal Lamps and/or Indicators Inoperative
9
Disconnect the center high mounted stop lamp.
Using a test lamp connected to ground, probe the stop lamp switch signal circuit of the center high mounted stop lamp at the harness connector.
YES - Go to Step 10
NO - Go to Step 15
10
Using a test lamp, probe between the stop lamp switch signal circuit and the ground circuit of the center high mounted stop lamp with a test lamp.
Go to Step 11
Go to Step 16
11
Inspect for poor connections at the harness connector of the center high mounted stop lamp. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 20
Go to Step 19
12
Inspect for poor connections at the harness connector of the stop lamp switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 20
Go to Step 18
13
Repair a open or high resistance in the battery supply voltage circuit of the stop lamp switch. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 20
14
Repair a short to ground in one of the following circuits:
• The battery supply voltage circuit of the stop lamp switch
• The stop lamp switch signal circuit of the stop lamp switch
Go to Step 20
15
Repair a open or high resistance in the stop lamp switch signal circuit of the center high mounted stop lamp. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
16
Repair an open or high resistance in the ground circuit of the center high mounted stop lamp. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
17
Repair an open or high resistance in the stop lamp switch signal circuit of the stop lamp switch. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
18
Verify the stop lamp switch adjustment. Refer to Stop Lamp Switch Adjustment . If OK, replace the stop lamp switch. Refer to Stop Lamp Switch Replacement .
Go to Step 20
19
Replace the center high mounted stop lamps. Refer to High Mount Stop Lamp Replacement .
Go to Step 20
20
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Jun 23, 2017 | Cars & Trucks
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    I am receiving the message "Unfortunately the launcher has stopped working". How do I fix it?
    Google is your friend in such cases :>)
  • Unfortunately, Launcher has stopped - Android Forums at ... forums.androidcentral.com/...unfortunately-launcher-has-stopped.html
    • 27 POSTS
    • FIRST POST: 2014-01-25
    2015-12-30 · On powering up my tablet I get a message "Unfortunately, Launcher has stopped" & I ... up says unfortunately launcher3 has stop. i ... the launcher stop working ...
  • "Unfortunately, Launcher has stopped" error after 4.0.4 ... android.stackexchange.com/questions/23842 Tap OK on the "Unfortunately Launcher has stopped" window. ... Android launcher not working. ... unfortunately settings has stopped when adding widgets to nova launcher.
  • Steps to fix the Error message 'Unfortunately, launcher ... androidtipguys.com/forum/steps-fix-error-message-unfortunately...
    • 9 POSTS
    • FIRST POST: 2013-02-20
    2013-09-18 · Steps to fix the Error message 'Unfortunately, launcher has ... Steps to fix the Error message 'Unfortunately, launcher has stopped ... settings stopped working ...
  • Android Device Emulator- Error Message: 'Unfortunately ... https://software.intel.com/en-us/forums/android-applications-on... I wonder if somebodyhad experienced an error message 'Unfortunately, Launcher Has Stopped ... message 'Unfortunately, Launcher Has Stopped ... has stopped working ...
  • What does it mean "Unfortunately, Launcher has stopped ... https://www.ifixit.com/Answers/View/263569/What+does+it+mean+... whenever I try to go to a website, I get the message, "Unfortunately launcher has stopped working." Any fix?
  • "unfortunately Lenovo Launcher has stopped working ... https://www.ifixit.com/Answers/View/218973/"unfortunately+Lenovo... My A3300 tablet was put on charging. it showed "lenovo launcher has stopped working" and then it turned off.now it does not turn on. please help!!
  • Homescreen Launcher problems - Android Forums at ... forums.androidcentral.com/.../312587-homescreen-launcher-problems.html
    • 17 POSTS
    • FIRST POST: 2013-09-07
    2014-02-25 · Homescreen Launcher problems Hello ... but working with Android for 2 years now ... "Unfortunately, Launcher has stopped" and I get chucked back to ...
  • Android 4.0 emulator always has a crashing Launcher ... stackoverflow.com/questions/9155417
    • 10 POSTS
    • FIRST POST: 2012-02-06
    2013-10-17 · Android 4.0 emulator always has a crashing Launcher? ... problem is "unfortunately, launcher has stopped". ... the size and tested again and things were working ...
  • How To Fix: 'Unfortunately The Android Process Media Has ... www.youtube.com/watch?v=arKBbSUt-_Q
    • BY THEFRESHGAMEPLAYS
    • 6 MIN
    • 550K VIEWS
    2012-12-08 · How To Fix: 'Unfortunately The Android Process Media ... Unfortunately (app name) has stopped ... Unfortunately google play store has stopped working ...
  • May 08, 2016 | ZTE Cell Phones
    What does 'unfortunately com.google.android.gms has stopped' mean?
    This is a known fault
  • Google Play Services process com.google.android.gms has ... www.youtube.com/watch?v=FtzSuzmckxw
    • BY TROUBLESHOOTERRORS
    • 19 SEC
    • 22K VIEWS
    2014-08-31 · Sometimes, i am seeing this Sorry message 'The application Google Play Services (process com.google.android.gms) has stopped unexpectedly...
    • 6 MIN
    • 547K VIEWS
    2012-12-08 · ... 'Unfortunately The Android Process Media Has Stopped' ... Unfortunately app stopped android ... Unfortunately google play store has stopped ...
  • android - Unfortunately google maps has stopped - Stack ... stackoverflow.com/.../25640697/unfortunately-google-maps-has-stopped ... Unfortunately DemoGoogleMapsV2 has stopped. ... Unfortunately google maps has stopped. ... And in place of com.google.android.gms.maps.MapFragment use com.google ...
  • How to fix the process com.google.process.gapps has ... www.androidpit.com > Overview Ive seen a few people ask how to fix "the process com.google.process.gapps has stopped ... google.process.gapps has stopped" on Google, ... android.gms has stopped ...
  • "Unfortunately, Android Wear has stopped." - Google ... productforums.google.com/d/topic/android-wear/fqDZFs24e0A 2015-04-09 · ... but the watch always pop "unfortunately android wear has stopped ... android "unfortunately,MYQR has stopped" on my ... Google "Android clear ...
  • Apr 16, 2016 | Tablets & eReaders
    Unable to clear "Unfortunately, Google Search has stopped."
    unfortunately google search has stopped working-cant text ...
    https://www.ifixit.com/.../unfortunately+google+search+has+stopped+wo... Oct 1, 2015 - suddenly got message-sorry! unfortunately google search has stopped. can no longer text - LG Optimus Dynamic II L39C.
    pop up that says google search has stopped - ZTE Phone ...
    https://www.ifixit.com/.../pop+up+that+says+google+search+has+stopped Sep 20, 2015 - I have a ZTE majesty i keep getting a pop up that says Unfortunately, google search has stopped. Now I have now keyboard. - ZTE Phone.
    Unfortunately Google Search has Stopped Working - Google Product ...
    https://productforums.google.com/forum/#!msg/websearch/0ZM.../d... Google Groups allows you to create and participate in online forums and email-based groups with a rich ... Unfortunately Google Search has Stopped Working.
    How to Fix "Unfortunately, Google Search has stopped ...
    www.twotricks.com > Android Sep 30, 2015 - How to Fix "Unfortunately, Google Search has stopped" Error in Android : you can get rid from this error very simple method we share on ...
    How to fix unfortunately Google Search has stopped ...
    wikitechsolutions.com/.../how-to-fix-unfortunately-google-search-has-st... Apr 18, 2015 - To fix google search has stopped , what to do is the following: Go to the menu and select Settings / Applications. Select the "All" tab. Select the ...
    Feb 06, 2016 | Google Cell Phones
    Why has launcher stopped working?
    launcher stopped working Tablets & eReaders Questions ...
    www.fixya.com > Forum > Tags > launcher stopped working
    Tablets & eReaders launcher stopped working questions and answers. Ask your ... is not working. Error message 'Unfortunately, Launcher has stopped'. Tried to ...
    forums.androidcentral.com/.../357082-unfortunately-launcher-has-stopp...
    Jan 26, 2014 - 22 posts - ‎17 authors
    ... up my tablet I get a message "Unfortunately, Launcher has stopped" ... or Korean and then help me to solve the launcher stop working error ...
    [Q] Unfortunately Launcher has stopped and o... ' Asus Transformer ...
    forum.xda-developers.com/showthread.php?t=2069137
    Dec 27, 2012 - 9 posts - ‎2 authors
    Third-Generation Kindle Fire HD Gets Bootloader Unlock Tool ... Currently stuck with a "Unfortunately, Launcher has stopped" on my ... It has been working very well since then, but in the last days, ... I do have a build.prop editor installed on my tablet, but since I can't launch app, I don't know how to do it.
    Error 'Launcher Has Stopped Working' ' Android Tablet Forum
    Dec 12, 2015 | Tablets & eReaders
    How do i go to no stop mode on bizhub c450/
    Utility-Meter count-Check details-Stop 00-Stop 01- Stop 0 C select IU life stop setting-NO STOP
    Jul 12, 2014 | Konica Minolta bizhub C450P Laser Printer
    Skytec Astra alarm system just quit working unexpectedly
    STOP STOP STOP STOP STOP STOP OK OK OK OK OK OK OK OK OK OK OK OK
    Oct 01, 2013 | Scytek Electronics ASTRA200 Car Alarm 1...
    How to reset the counters of the dev unit of konica minolta c360
    The developer unit has been reset automattically,after change the old unit another new.You can change the developer unit life STOP after 45000 copies or NOT STOP more 400000 copies.To change the unit life press:
    Utility - Meter count - Check details - Stop - 0 - 0 - Stop - 0 - 1 -Stop - 0 - C - select IU life stop setting touch NO STOP.
    Aug 06, 2013 | Office Equipment & Supplies
    Computers & Internet Logo
    12 people viewed this question
    David Payne
    David Payne
