Ricoh 2000 mp
Gray background on copy
Cogz
  • 1326 Answers
SOURCE: Copies have gray background.
Have you had the optics cleaned resently? If not Iwould start with that and make sure you have the copier unpluged and don't forget to clean the two mirrors under the Black Box/cover. It could also,mean that you need a new OPC drum and blade.. It depends on how maiy copies are on the copier and drum...
Posted on Sep 10, 2008
Touch2Heaven
  • 145 Answers
SOURCE: RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
Posted on Oct 15, 2008
wheatlandsvc
  • 1110 Answers
SOURCE: My Ricoh Aficio MP 161 said to add toner but still won't copy
Check your old toner bottle and make sure the plastic "cap" is still in the bottle. These machines have an occaisional problem with the caps coming off (not the black screw off cap but the semi clear cap under the black screw off cap) and staying inside the black plastic "cup" that you insert the toner into. If the cap is missing it may be stuck inside this cup. If the cap is still in your old cartridge then try opening/closing the front door and letting the machine cycle to see if the toner light goes out. May have to do this several times. Had one customer just yesrday have to do this to clear the toner light after adding toner.
Good Luck.
Posted on Jan 28, 2010
  • 114 Answers
SOURCE: The RICOH Aficio 2000 MP 2000 Le is connected to
what version is your mac O/S ? if it is the new 10.6 snow leopard you need to download the driver from mac site and install it, not all are out for that version. As a work around you may be able to use an HP laserjet 5 driver.
Posted on Mar 17, 2010
  • 15 Answers
SOURCE: I need to copy and print a booklet from my Ricoh
Definitely, you need to download the RPCS driver.
Posted on Apr 16, 2010
Pages printing with a gray background
could be waste toner in printer inside the printer it may need a clean.
Apr 27, 2015 | Ricoh Aficio CL7100 Printer
Mp 2000 sc 982
i'm guessing == Scan, Color
Jan 03, 2015 | Ricoh Aficio Mp 2000 Copy Machine
How to clean Ricoh Aficio MP 2000
sounds like either drum blade has fail or drum is bad. try printing the counter report and see if it is doing this. Then photo conductor unit needs to be rebuilt or replace. open right side door and look at drum make sure you don't touch it and see if toner is on it. If so drum blade has fail. call a tech or buy new photo conductor unit. this are good for approx 60,000 copies but sometimes will go longer age also play with drum blade life. were you might have 20,000 copies but unit is 5 years old
Jan 31, 2012 | Ricoh Aficio MP 2000 Black and White...
I have ricoh aficio mp 2000, it's photocopy print black lining
if it background like faint toner all over copy need to replace developer powder/drum/blade/gears
Oct 08, 2011 | Ricoh Aficio MP 2000 Black and White...
My ricoh MP 2000 is printing blank documents when a print job is sent
is the copying ok? if yes then reload the print driver .it is causing the problem.if copying is also blankthen check the processing unit. the charge roller might be facing some problem or the developer gears might be worn out .
Sep 28, 2011 | Ricoh Aficio MP 2000 Black and White...
My copier ricoh aficio mp 2000 makes a continuous creaking like an broken or consumed gear. what's the problem?
MP2000s often have creaking and squeaking issues. Typically it's the brass bushings that ride on roller shafts, so if you can isolate it to an area and clean and lube the bushings, you might be able to fix the noise.
Aug 12, 2010 | Ricoh Aficio MP 2000 Black and White...
Oct 15, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
19 people viewed this question
k24674
