Question about Health & Beauty
How To Adjust blades on andis superliner - Health & Beauty
  • 61 Answers
SOURCE: My GTO model Andis clippers
The problem with Andis clippers is that you are not told how to get the most effective job out of you're clippers,i can attest to that because i've repaired and adjusted hundreds of them,every user wants a crisp cut,nothing less, you want find the answer to that in the instructions,so you're encouraged to send the clipper back to Andis company,i did that once just to see if they really understand their own tool,the clipper cut no better upon it's return,it was then that i discoverer the ultimate solution,blades has to be precise,only then will you get a crisp cut,for any type of hair ,so before you get rid of blades,remember 85% of the time the problem is with the adjustment of the blade.
Posted on Jan 26, 2009
  • 61 Answers
SOURCE: andis adjustment
blades has to be set precisely,only then will you get a crisp cut.
YOU HAVE TO OPEN DEM UP. TAKE OUT THE SCREWS ON THE TOP DEN TAKE OFF THE BLADE. ONCE YOU HAVE THE BLADE OUT THERE ARE TWO MORE LIL SCREWS UNSCREW THOSE (NOT ALL THE WAY OFF, JUST ENOUGH SO THAT THE BLADE WILL MOVE) ADJUST THE BLADE HOWEVER YOU WANT. IF YOU WANT IT CLOSE FOR A MORE DETAILED CLOSE LINE (NOT TO CLOSE AS DEY WILL CUT YOUR OR THE CLIENTS SKIN). YOU MUST TRY THEM OUT ON YOURSELF SEE IF THEY ARE TOO SHARP, IF THEY ARE TAKE THEM OFF AND ADJUST THEM AGAIN. EASIEST THING TOO DO IS USE A MIRROR, HOLD THE BLADE AGAINST THE MIRROR DEN MOVE IT AT AN 45 ANGLE DEN TIGHTEN THE SCREWS DER (BARBER TRICK).
Posted on Jul 21, 2009
  • 8 Answers
SOURCE: adjust blade
On the Andis T-Outliner or Outliner if you have use the trimmer for more than 3 hair cuts or 3 time or more I do not recommend moving the blade, reason why is that you have all ready start or have a sit in or a grooved, I have found that by moving the blade it won't cut at all.You need to resharpen the blade with a professional sharpener and have them reset the blade for the type of hair cut you want. The blade can be set to shave or do line ups, and Fades. This type of trimmer is for that kind of hair cut the professional barber use them all the time. Call Mannys Sharpening 323 263-4697 They have a good rating on Yahoo Local.
I have try many sharpener and had no luck, until a friend of mind told me about Mannys Sharpening, They know what they are talking about highly Professional in thier work.
Posted on Aug 01, 2009
  • 61 Answers
SOURCE: how di adjust blades to make andis clippers
Take blades off clipper,loosen screws on blade, place on mirror, rest teeth against mirror, angle clipper at 1 oclock position, slowly titen screws
Posted on Jan 05, 2010
I wanna know how to fix Andis superliner clippers.mine just simply dont cut anymore??someone please help
If the clippers stopped cutting, they are probably clogged with hair on the inside of the clippers. I had two pairs of clippers where this happened. I took them to be serviced at a beauty supply store and they cleaned the hair from the inside of both pairs of clippers for me and they now work just fine.
Jul 12, 2014 | Andis SuperLiner Trimmer 04810
Andis superliner
Try some oil and see if that makes it go any smoother, or see if you can find an indivisual part
Nov 24, 2013 | Toys
Want to adjust trimmer so i give a better outline i just bought new blades, not sharp enough
Sometimes the new blades are not sharpen enough, You need to have it resharpen by a professional and adjust to the type of work you want it to do. Also sometimes even if you have the blade resharpen it will not cut, because the trimmer motor needs more power to move the blade side to side faster. On and the Andis GTO T-outliner trimmer this the most comm problem. Try Mannys Sharpening
Jun 15, 2009 | Andis Outliner II Hair Trimmer
How di adjust blades to make andis clippers sharper
My GTO model Andis clippers blade is not properly aligning..how do I adjust it? I BOUGHT NEW BLADES FOR MY ANDIS LINER BUT IT STILL DOES NOT CUT SMOOTH AND SHARP. WHAT IS THE PROBLEM.
Jan 22, 2009 | Andis T-Outliner Hair Trimmer
Andis adjustment
Aug 22, 2008 | Andis 01690 Hair Trimmer
Andis T-Outliner
adjust the brown plastic on the blade all the way up.remov the blade and the brow plastic is held with screws
Apr 23, 2008 | Andis 04603 Hair Trimmer
Andis masters are chewing my guards
Stop using speedo guards and get yourself an oster 76 and all the blades.
Aug 16, 2007 | Andis 01690 Hair Trimmer
Health & Beauty Logo
65 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
