Question about Hotpoint Dryers
Hotpoint aquarius tvm570 dryer
The dryer comes on but the drum doesn't spin
  • 25 Answers
Either the belt is broken or possibly the motor starter has failed. Very often the belt. Be warned though, modern day tumble dryers use stretch belts that can be very difficult to fit.
Posted on Oct 18, 2013
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
SOURCE: HOW DO I ?
You probably need to thread the new belt over the drum by removing the circular rubber front seal temporarily. After putting the seal back on, ease the belt into the correct position and thread over the pulley on the motor. You will probably find it easier to put it over the pulley wheel of the motor first, with the belt partially off the drum. Then rotate the drum manually whilst easing the belt over it.
Posted on Mar 25, 2008
barkencoa
  • 3463 Answers
SOURCE: Thermostat keeps blowing on Hotpoint Aquarius dryer
Remove the filter completely from the bottom left of m/c
Wash out thoroughly under running water.
Reach in with your hand and clear any fluff and gunge you can find there.
At the rear of the filter housing there is a small drainage hole that blocks up.get a plastic bag tie or similar and poke it clear. Also there is a float chamber and some times the float sticks, this being the case , then it involves a complete strip down to clear prob.
Hope this helps
Plz rate solution
.Thanks.
Posted on Dec 29, 2008
barkencoa
  • 3463 Answers
SOURCE: tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
  • 686 Answers
SOURCE: drum not turning
no brushes in those motors you need new one or different dryer
Posted on Mar 12, 2009
My hotpoint Aquarius tumble dryer isn't heating, model tvm570
heating elements do burn out . call a repair service locally
Dec 02, 2016 | Hotpoint Dryers
Hi, My Hotpoint TVM570 Aquarius is making a loud screeching noise occasionally. It isn't doing it every time my partner just used it for an hour with no issues. However I used it for 5 minutes this...
wonder if you are overloading the machine and the noise is the drive belt screeching. if it sounds similar to a loose fanbelt on a car, it could be drum bearings that are seizing up (check by manaually rotating the drum. if it spins freely its ok) or the drive belt is getting worn and needs replacing
May 09, 2014 | Washing Machines
Spinning drum
yes it does have belt can you turn drum in side by hand if yes and belt hasent broke must have come of pully belt should be tight on drum
Sep 13, 2013 | Hotpoint TDC32 Electric Dryer
Dryer drum doesn't spin
If the motor runs and the drum doesn't turn then most likely the belt is broken.
Oct 23, 2012 | GE DBVH512EFWW Dryer
My hotpoint aquarius ctd00 dryer won t spin when turned on but makes noise and heats up
We have made a few videos on these dryers and there are some very good repair guides on these.
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair
Jun 26, 2012 | Hotpoint Aquarius WD63 Front Load...
Doesn't spin but it heats and blows air
probably the belt snapped that spins the drum
Feb 01, 2012 | Roper RES7646KQ Electric Dryer
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Dryers Logo
300 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
