Question about Panasonic NI-R73NR Iron
Panasonic iron model ni-22awtxj. I opened the adjustment screw and a small wire u saped like a spring below the screw fell down. I don't know which way it could be fixed. If I could see a picture inside the iron then may i could fix it.
oscarn
  • 109 Answers
SOURCE: My panasonic NI-R73NR iron went off and is not coming back on.
Check fuse in plug, check wire in plug for loose connection. Turn the thermostat a little higher to 'freeup' the contact mechanism. Check continuity with a ohm meter on the irom conacts, check lamp on iron
Posted on Sep 21, 2007
SOURCE: Wiring digram for Panasonic NI-A57SR Iron
Same issue i believe
with metal part laying flat (ironing position) and looking at bottom side, from the left to the right - white & blue leads, lamp(resistor lead), red then both black leads and other end of lamp.
im guessing the themal fuse is the lamp? what is the PN where can i get it.
i had a small shere fall out of the unit, besides the positioning switch where else would this be located?
Thanks
Posted on Apr 06, 2009
jmgldsmth
  • 1869 Answers
SOURCE: Panasonic Iron won't heat
most iron cases can not be seperated from the iron plate but, if you can take off the bottom plate you will see a heating element and attached to that a small cylinder it has a point on one side and a flat end on the other it is called a thermal fuse and radioshack sells them
they are made in different versions so take the fuse in to get the right one clip it back in and your iron should work again
Posted on Apr 24, 2009
  • 13 Answers
SOURCE: Panasonic Iron NI-R73NR will not heat up
Either a bad thermostat or a bad heating element or an open connection somewhere in the power cord. My advice, toss it!
Posted on Aug 27, 2009
heatman101
  • 43501 Answers
SOURCE: Panasonic NIA56NR NI-A56NR Iron shut off and wont
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
How do you open the back plate to access the power connection. On a shark model G1568 iron??
We have a Euro Pro GI472, which kept going off and on, and the problem seemed to be an intermittent connection in the power circuit. If we "fiddled" with the cord, the power light would go off and on. To get the back off, I removed the two screws below the rubber feet, near the identification tag. Then I had to pop the red plastic light lens off the top of the iron. The lens is held by two plastic "claws" one at the top and at the bottom of the lens. Once the lens is out, there is a small Phillips-head screw visible between two light sources. I removed the screw, and that freed the cover, and made it possible to access the wiring. Testing continuity from the wall plug to the two wires inside the iron, and flexing the cord, quickly led to a spot in the cord that was slightly kinked, and that was the location of the fault. Both wires under the insulation were broken. In fact there were small balls of melted copper near the breaks. Then it is a matter of making sure you know which wire of the power cord goes to which spot in the iron (a photo or a sketch will save mistakes when reassembling) cutting out the faulty wire, getting a suitable crimp connector and a wire nut and rewiring the iron.
Jun 08, 2014 | Euro-Pro Irons
Panaonic NI-R73NR Iron suddenly stopped working. Uses a small PCB with OEG PCD-124D2M relay which produces a sound when shaken as if some metal item is moving inside. Can this PCB be entirely replaced? Is...
Okay, here's what fixed mine. But first, understand this is a $23 iron and it may not be worth your effort. I'm an engineer and like fixing things, and I hate throwing stuff into the landfill, so I took the time to repair mine. If you can use a screwdriver and are good at taking things apart (and putting them back together) this will take less than an hour. NOTE: I often make use of a digital camera while taking things apart. Take a picture of things as you go, so you can see how to put them back together later.
The problem is the switch is corroded, from oxidation or carbon buildup, or both. Getting to it is most of the trouble. Follow these instructions:
1. Unplug the iron (helpful hint for the simple-minded. Can't iron if you're dead.) Dump out any water that's in it.
2. Remove two phillips-head screws from bottom of cord winder at base of iron.
3. Pull cord winder housing away from iron to expose electrical wiring.
4. Remove the small gray insulator card from it's slot to expose the screws that attach all the wires.
5. A red, blue, and black wire go up into the handle and attach to the shut-off circuit board. Tug on them gently to slide the circuit board out of the handle, remembering which side is up.
6. There's a screw inside the handle. Look where the circuit card came out and you'll see it in there. Use a screwdriver to remove it. Now you can lift up on the back of the small curved cover where the steam and squirt buttons are, and it will come off. Don't lose the steam setting button, it may fall off.
7. Now you can see the water jet nozzle. Lift it out of the way to find a screw under there. Take that screw out. I call this screw #1 for a reason.
8. There are three screws in the back of the iron, near the wires. They hold the iron together. Left and right are like screw #1. Take them out. The other one is a machine screw that's in the center, going down into the base. Take it out.
9. You can now lift the plastic part of the iron up off the metal part and set it aside. On top of the black plastic where screw #1 went through, near the pointy end of the iron, there should be a small washer. Locate it and set it aside. You'll want to make sure it gets back where it belongs when you reassemble.
10. There is a lamp that turns on when the iron is heating. It has two fine bare wires, a copper one (on the right if the iron is lying flat and you're looking at the base), and a silver one to the left. Find the screw where the silver one attaches and loosen that screw. Gently pull that wire off the screw. Note the routing of that silver wire around the black plastic, including where the tube insulator on the wire lays-- you will need to put this back right later. Lift the lamp out and the silver wire so it's more or less sticking up in line with the screw where the copper wire attaches. This will facilitate the next step.
11. Separate the black plastic cover from the brass-colored metal iron base by lifting at the pointy end of the iron. The wires will try to hang you up in the back, but if you wiggle things just right you'll be able to get them mostly separated. The lamp will need to descend down through the black plastic where the wires go as you lift the plastic cover off. As you lift it off, look inside. You can see where the rotary switch is inside there.
12. So here's the deal: the rotary switch controls a thermostatic set of contacts. This means there's metal in there that bends as it gets hot; the hotter, the more it bends. This controls your iron's temperature. When it bends enough, it opens a set of "points", which are tiny cylindrical contacts at the bottom of the rotary switch mechanism. Put on your glasses and look under the mechanism as you rotate the rotary control and you'll see them click open and closed. You need to clean them.
13. Get a small strip of fine sandpaper (400 grit or finer), about 1/4" wide and 2" long. Turn the control until the points are open and slip the sandpaper in between them. Now turn the switch the other way to get the points to close on the sandpaper. Pull the sandpaper back and forth between the points; that'll clean the contact on the gritty side of the paper. Now open the points again, pull the sandpaper out, flip it over, put it back in, and close the points. Now another few pulls on the paper to clean the other contact.
14.Remove the sandpaper. Put the iron back together in reverse order. Some things to watch out for: When you put the black plastic part back down onto the metal iron base, you'll need to make sure the wires and the lamp go the right way. You also need to make sure that the grey rubber grommet that lets water from the plastic tank down into the heated elements is properly pushed up through the hole in the black plastic. If you have trouble seating the black plastic onto the metal iron base, it's probably because that grommet is stuck halfway through the hole. Make sure you put the steam selector button back where it goes before you put the curved cover onto the top of the plastic tank. Getting the screw up through the hollow handle and into the hole it goes into can be tricky. I held the phillips screwdriver point-up and set the screw on top. Then I held the iron point-up and slowly put the screw up through the handle and into the hole. This might take a couple of tries; be patient-- you'll get it. Be sure to put the circuit card back into the handle the right way. Finally, be VERY SURE to route the lamp wires through the plastic parts correctly, and also make sure that you have correctly routed the red, blue, and black wires from the circuit card correctly before you re-install the cord winder housing.
Nov 22, 2010 | Panasonic NI-R73NR Iron
It not turn on.
If u could open the internal part and check the THERMOSTAT and the THERMAL.
That usually the problem w/ FLAT iRONS!
Might as well check ur power cord too, it might have some internal cut wires in it, use ur multi tester to test the current continuty!
If u don't know how to OPEN it, u might as well, bring that to the nearest service center!
Nov 08, 2010 | Panasonic NIA56NR NI-A56NR Iron
Tefal iron - security auto stop has locked me out, have switched off for some time but lock out still in place - help!
If you know how to open it, it's just a mechanical lock, check for anything that stuck or broken
Aug 18, 2009 | Panasonic NI-R73NR Iron
Apr 24, 2009 | Panasonic NIA56NR NI-A56NR Iron
Panasonic iron NI-A56NR wont turn on
first test your heating element to see if it is working.
You can by pass the control module by removing it from the line. Just disconnect all wires that goes to the module and put aside, then, connect back lead to the far right connection and white wire to the third connection from the left. Be careful playing with electricity is hazardous to yout health if you don't know what you are doing.
Jan 17, 2009 | Panasonic NI-A57SR Iron with Auto Shut-off
NI-A57SR steam Iron suddenly not functioning
I had the same problem, when I took it apart, I noticed the theromstat points needed sanding. Just a reminder, make sure to write down the order of wire leads before disconnecting. By the way to test if the heating element is working connect white lead to the second connection from the left and black lead to the far right. Place your iron flat down on a wet cloth ( so that you won't burn your surface). You can also use an electrical tester. If heating element does not work though, it is time to buy a new iron.
Dec 31, 2008 | Panasonic NI-A57SR Iron with Auto Shut-off
Thanks
Dec 13, 2008 | Panasonic NI-A57SR Iron with Auto Shut-off
My iron won't work
you have to check the cable you can use multi tester in ohm position to make sure the connection no problem, and turn the adjustment temperature and watch on multitester the resistance will change if nothing happen you have to change cord with new one.
May 24, 2008 | Panasonic NI-R73NR Iron
Aug 11, 2007 | Panasonic NI-R73NR Iron
Panasonic NI-R73NR Iron Logo
Top Panasonic Irons Experts
Bill Boyd
Rani wadia
Rani wadia
iranna
iranna
Are you a Panasonic Iron Expert? Answer questions, earn points and help others
