Question about Brother MFC 210C All-In-One InkJet Printer
How To Refill?
Hey everyone, need some help here. I've refilled other cartridges before, however I have another printer I'm using Brother MFC 210C and I'm wondering if there is any refilling kit for it? I guess the main thing I need is the syringe. The one I have used for all other cartridges is a thin pointy one, however it doesn't seem to work with these brother cartidges.. maybe someone can point me to some tutorial or place where I can buy a kit.. I've looked for a while now.. and can't find anything releated..=(
  • 1 more comment
  • Harryt Sep 27, 2007
    well I tried to fill it up today for an emergency print.. I basically pushed it through the ink hole.. and it seemed to work.. though some air must have got through it..
    I remember a tutorial long ago, where someone did it the same way and he didn't drill any holes at all...
    hmm well i just got it refilled using no hole at all.. I just pushed the ink through the original ink hole and it worked... I remember a tutorial, where someone did the same.. and didnt need to drill at all...
  • Harryt Oct 03, 2007
    #1 as I posted above.. has anyone tried it that way? by just pushing the ink through the hole it comes out from? It seems to have worked for me.
    #2, would drilling a hole cause the ink to dry faster if you don't use it too often?
  • 832 Answers
Harry, you can use every DYE ink for brother printers. DO NOT use pigmented ink due to clogged filters inside the printhead!!!! The carts for mfc210 are filled with 20ml for BK and 11ml for C/Y/M. I use to refill 20ml only ink for bk and 10ml ink + 1ml printhead cleaner for C/Y/M. See here how to do that (LC900 refill): http://www.hstt.net/refill-faq/brother.html#LC-900 Refillen (Simply drill a hole into the brother brandname and leave it open!) I use a 20ml syringe and 3 12(10+2)ml syringes from the drugstore (ask your doc! It may be cheaper ;-)
Posted on Sep 26, 2007
  • Mix-it-up
    Mix-it-up Sep 27, 2007
    brother carts are completly sealed (totally plastic, no foil). Thats the advantage of the original carts: they wont leak when taking them out of the ink assy.
    You cant refill without drilling a hole into the cart body.
  • Mix-it-up
    Mix-it-up Oct 05, 2007
    Harry,
    I like your idea. Unfortunetly the suggested solution is quite dangerous because parts of the cartridge will be damaged. At the end ink will flow into the cartridge assy and stain important parts of the machine or mix with other plain ink colors!
    See here how the cartridge looks like from the inside: (Choose LC-900 Doku) http://www.hstt.net/refill-faq/brother.h...
    You can see the valve parts where the ink comes out. They wont be save anymore after you have tried to refill with in a needle :(
    The advantage of a cart with a drilling hole is on the hand: You can leave the cart inside the machine when it shows EMPTY (and stops/pauses printing) Simply refill it by help of a syringe and close cover afterwards :)
    ..and no, the ink wont dry faster.
    BTW this is the reason why brother industries has designed the inkjets to clean themselfes. Always keep the printer plugged in (power)! Set date and time, too. Otherwise the printhead will dry out!
    If you dont use the printer that often, it should be better to use the original brother ink carts instead of refilling or useing thridparty carts. You wont save money because thirdparty ink wont meet the chemical mixture that the originals have (and what the printhead needs!). This mixture somehow keeps the printhead clean. Otherwise you have to do the cleaning procedure quite often which leads straight into the error 46 (unable to clean) because the wistinktank has to be replaced! Under normal coditions the waistinktank volume will last around 2,5 - 3 years) The worst case will be a damaged printhead with error 41 or missing colors or bad printout quality.
I have a canon cartridge and need to refill it,i lost the booklet that comes with the refill kit. so my problem is i dont know where to make the holes on the color cartridge
Posted on Feb 04, 2008
SOURCE:
I have also problem with the magenta
Check your ink cartridge if they are properly installed.
Check your cartridge if they are empty.
Make sure you are using original cartridge and not just a refill cartridge.
If still nothing happens replace your cartridge.
Sep 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
I use the refill ink cart, its still shown empty
reefing a ink cartridge is some time much complicate more than you think. there is a programable chip inside ink cartridge. after refill you have to reset that chip also. to reset the chip you have to build small hardware to communicate with that chip. also simple software to reset the chip. :) send me the printer model number you want to fill and cartridge number. i'll show you the steps you have to follow.
Jul 04, 2009 | Brother MFC 210C All-In-One InkJet Printer
Oh brother
I don't think there is a reset procedure for resetting MFC 3240c cartridges.
Professional refill facilities use a code reset device on cartridges.
Users that want to refill their own cartridges often use a piece of cellotape or plastic bag to cover cartridge sensor. This can damage printers head if ink goes too low and printer keeps printing.
My suggestion: stay away from troubles and buy original cartridges.
Here is a link on howto:
Reset ink sensor for Brother MFC 3100C - fixyourownprinter.com
Aug 17, 2008 | Brother MFC-3240C All-In-One InkJet...
I've used refillabl ink.
You can only use refillable once and sometimes not at all. The gasket on the cartridge has to fit snug or the printer won't recognize that you have put one in. Buy a new cartridge and that should fix the problem. I had the same problem.
Jun 12, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc210c
two ways to refill lc41:
drill a 2 mm hole into the brandname (e.g. O of brother ) on top of the cart. You can leave the hole open and leave the carts in the printer in future for further refilling ;-)
The cart can be refilled by inserting a syringe without a needle into the ink Outlet(!) at the bottom, too. Carefully press a 12ml for C/Y/M and ca. 15ml - 18ml for BK into the carts.
Anyway:
Do use DYE-ink only!
Important: You must mix the dye-ink with some 85%-glycerin alc. to keep the print head nozzels alive = 10ml ink with 2ml glycerin alc (drugstore).
For BK: 15ml ink + 1,5ml glycerin alc!
Feb 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
How to refill the cartridge of brother MFC240c
Hey its very simple, you'll need a syringe and an exacto knife. You just need to pop the case in half use the exacto knife to cut the seem very carfully and to pry the cartridge apart carfully. On the back of the cartridge you'll see a little indintation were it was filled in the factory just fill the cartridge with a syringe push in the indintation fill cartridge remember to leave a little air in there and seal the hole up so it's air tight again this can be done by using a little hot glue to seal the hole. I hope I was helpful. As well you can by a continous ink system for the brother 240c which is pretty need too
Sep 08, 2007 | Brother MFC 240C All-In-One InkJet Printer
How can I refill my ink cartridges myself?
Be brave and have a go, buy the correct ink refill for your selection of cartridges, the packaging on the refill kits will tell you if your printer is included. Once you find one for yours, instructions come with it. I think your cartridges have plastic ones don't they? Make sure when you fill with syringe you follow instructions very closely to avoid air bubbles and always run a clean when you put it back in. I refill all the time, and each time i refill (i get 7-8 refills each cartridge now the way i do it) i am saving $80.00 both cartridges. This can be most of a thousand dollars a year for me.
Aug 17, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
267 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
