Lg Dvd Manual
How do I change the regional code setting to play USA DVD? On DP930H DVD PLAYER.
bluegreenash
  • 661 Answers
SOURCE: dvd region codes
Try this (for a LH-T360SE)
Open disk tray and press 0000, a two line menu appears with "Edit Region _" and "Region Code:x" put in required region (presumably 0) and press enter. Region Code:0 appears. power off and enjoy.
region code 0 is No region restrictions.
Posted on Nov 03, 2007
SOURCE: LG DVD player LG276
I picked up a LG DV276 DVD Player here in Australia but I am from the United States so I own region 1 DVDs. I unlocked my new player by instead 1. Open the tray. 2. Press 0 0 0 0 on the remote and a Menu will appear. 3. Press 0 for region free. 4. Press pause and power off.
I can play everything now, Aussie and US DVDs. Thanks LJ66.
Posted on Jan 01, 2008
guru_dev
  • 315 Answers
SOURCE: DR 389 DVD player
Try one of these:
1) Press 'setup' on remote control
2) Move down to the 'lock' picture
3) Press '0000000'
4) Select region code as '0'
Or
1) Power on player with no disc in tray
2) Press PAUSE
3) Key in 314159
5) For multi-region, select 0
6) Press PAUSE again
7) Power off player
8) Wait a minute turn it on.
Posted on Apr 22, 2009
SOURCE: LG Blu-Ray BD-370 unlock codes
http://www.multi-region.net/lg_5931
Posted on May 01, 2009
SOURCE: Changing region code to all on a LG DV550 DVD player?
icon_minipost.gifRegion code hack posted by hackaroto, December 27 2010:
1. Switch off the DVD player in to Stand By mode
2. Open the DVD tray using the remote control
3. Press "pause" in the remote
4. Enter 0, 0, 0, 0 (zero 4 times)
5. The display should indicate the regional code set in the DVD and prompts for the new regional code.
6. Enter the new regional code
7. Press Pause to exit the setup
8. Switch off the DVD using the remote and wait for a while before switching it on again.
works for other LG DV55X players
Posted on Jan 14, 2011
How do I set to play all regions on LG RH1777 DVD Recorder?
enter "setup" from the remote
Scroll down to the lock symbol
Press the "0" button 7 times
You'll get a confirmation message and then your DVD player is region free :-)
Feb 18, 2015 | LG RH1777 DVD Recorder
Lg DVD player blu ray BP240
You will need to look in the owner's manual for the answer to this one.
Or look in the setup menu on the DVD player.
And on DVD players, it's not usually zip code. It's region.
If you are in the USA now, and the DVD player was set up for somewhere else in the world, good luck trying to change that.
The USA is Region 1. If the player is set to somewhere else, I don't know if you can change that.
If in the USA, try for Region !.
Aug 19, 2014 | Televison & Video
I have an lg dvd player combo model v190 my friend has sent me a set of dvds from the usa none of the dvds will play how can i set the rc to play these discs
You will have to change the regional settings to play US DVDs. Your manual should be able to help you.
Hope this helps.
Apr 13, 2011 | Televison & Video
What does check regional code mean?
It means your DVD player has a different region code to the disc you are attemting to play.
DVD's and most DVD players have a region code corresponding to the country/region in which they were purchased. The region code printed on the disc must match the region code of the player, usualy found on the rear of the unit or in the manual. Only players set to code 0 or 9 are able to play all regions, a setting of 1- 6 is most common. 1 = USA 2 = Europe etc.
It is often possible to set your player to code 0 or 9 enabeling you view all region DVD's.
May 16, 2010 | LGDVB418 DVD Player
What does it mean when my dvd player says wrong region??
DVD's are coded to play in different parts of the world. Each DVD player is set up to recognise these codes. Most are set up to recognise only the region code of the area it was made for. For example Region 1 is for the USA and Region 2 is UK and parts of Europe. A DVD player made for the USA market would not be able to play any other discs with a Region code other than 1. And so on... This was done for the film industry benefit so that films can be released at later dates in different parts of the world without everybody seeing it on DVD issued in the USA.
However most DVD players can be "hacked" by a combination of keys allowing the user of say a Region 2 player to change it to another region. Some can also be changed to Region 0 which means it should play any disc.
How to change the Region code can be found by putting the model number of the DVD into a search engine and the words 'region code'. Some can be found on this site too.
Dec 04, 2009 | Electronics - Others
Cant play dvd baught in england. player baught in the usa
There are different region codes for dvds and the player may only be able to play dvds with a north american region code.
Sep 08, 2009 | Radio Shack Accurian LMD-5108A Portable...
Trying to play dvd but says wrong region soneynhv-dx350ab?
Hi, if its saying wrong region. then either your player or disk is incompatable. region 1 ntsc ( USA ) Region 2 ( UK ) et,c. check your players region coding is compatable for your country, and that you are also playing a dvd with the same region coding as the player. alternatively is to try and find a region free or multi-region solution. Mike @ Compurepair.
Jun 12, 2009 | LG RC897T DVD Recorder/VCR Combo
How do I unlock my LG RC388 to play other region disks
YES, it can be changed to view all regions. I've just done my new RC388 (bought it 4 hours ago) and it works.
To start the hack:
Click the home button on the remote, go to the Setup page, highlight the 16X9 TV aspect ratio and enter in this coded sequence: 1 3 9 7 1 3 9
A new factory menu now comes up on the screen.
To change the values of these options hit the enter button and scroll with arrow keys until you get to the option you want to change. For the region code hack replace the value of "option 5" with the value of: ff
Press enter.
(Changing this value will set unit to region code 0 which should allow any region to be played on the player.)
Now, hit the "return" button to save and exit.
Switch off the machine - switch on - all is well now.
Good Luck,
Will
Mar 31, 2009 | Televison & Video
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Aug 27, 2008 | Audiovox D1710 Portable DVD Player with...
Area code for LG HT502TH home theatre
No Disk----Remote(Open/Close Button)-----Press "000"-----Change Regional Code----press PAUSE to confirm-----Shut down DVD----Power UP!!!!!! :-)
Mar 30, 2008 | Video Game Consoles & Games
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
