Question about Pool & Spa
How can false alarms be prevented? - Pool & Spa
    Problem Solver:
  • 4 Answers
Make sure that all the doors and windows are locked properly before you leave. Be careful with those things which can possibly trigger off the home alarm system like moving of the curtain, plants etc.
Posted on Oct 21, 2013
  • Hugh Neblett
    Hugh Neblett Oct 21, 2013
  • 4 Answers
Hay
Posted on Oct 18, 2013
My detector start to beep once a while, seem to react to the fat the electric plate is starting.
It's possible that your smoke alarm is mounted too close to the kitchen, which can cause false alarms. Most household smoke alarms are the ionization type, which respond to the presence of gases in the air which are caused by combustion, as opposed to visible smoke, but kitchens are better protected using heat sensors to prevent false alarms. Many companies now make heat sensors that can tie into the existing smoke alarm system...check with the manufacturer, an electrician, or your local hardware store.
Jan 12, 2016 | Home
Ademco motion detector false alarms
Aside from any sensitivity adjustments, after all a false alarm caused by falling objects, pets or juicy bugs is not a false alarm..it's an environmental mismatch of sensor to the area, some motion detector false alarms are caused by circuit faults, possibly during the install, where the wire terminals were turned too hard and twisted slightly and are not as solid as the manufacturer intended. This twisted terminal mount could cause false alarms when either the power circuit or the sensor circuit loses continuity. Intermittent power (caused by weak/loose/nicked/damaged wiring, a weak terminal on the board or power supply problems could cause annoying faults that are hard to trace. Diligence and a good eye to spot these problems and correct them will help you determine the cause of false alarms.
In the case of wireless devices, troubleshooting is usually limited to spotless battery contacts, good batteries and proper placement.
Aug 23, 2011 | Ademco 998 Pir 50x50 Motion Detector W/...
Are there any reported problems with the Firez 21007624 carbon monoxide detector false alarms?
I do not know of any reported problems specific to the Kidde CO/smoke alarm, but I spent a significant part of my career servicing toxic gas sensors and can give you some general advice:
1- Most important: treat an alarm as a REAL alarm and DO NOT suspect that your alarm is a "false alarm". My experience has been that most "false alarms" ARE REAL and the source needs to be identified! With Carbon Monoxide detectors, it is usually a blocked vent for a gas fired appliance- a hot water heater, furnace, or oven. Call your fire department or a service professional to make sure that there is no carbon monoxide. They have portable detectors that will be able to double check your alarm.
My advice to you at this moment is to act as if you have a real alarm condition and do not place you or others in a life threatening situation. Ventilate the room/ apartment/house IMMEDIATELY!
I will post more after I send this because you may be in a life threatening situation!
Mar 22, 2011 | Kidde Firex 21007624 Ac Carbon Monoxide...
My 350hv just shuts off randomly. I can arm it and come back later and it is off and my doors are unlocked!
Sorry, but it is my opinion that car alarms are really, really foolish.
Cars are extremely hostile environments for delicate electronics.
Adding alarms is begging for problems that will leave you without a car.
If you lock any valuables in the trunk, out of sight, there is no reason for an alarm. All an alarm will do is either fail and prevent you from driving, or fail and get you a ticket for a false alarm.
Jun 20, 2010 | 350 HV ESP Security System 350HV ESP
My Viper alarm for my Ford Ranger has been disconnected
Yes the viper alarm needs to be serviced to prevent false alarms. Go to the nearest Ford Dealership. You could ruin the system permanently if you mess with it yourself
GOOD LUCK.
CNBY
Jun 03, 2010 | Viper Security and Remote Start System...
How do i disable alarm system????
under the rf floor board in the front you will see a false panel after removing carpet. remove false panel by loosening 10 mm plastic nuts your alarm module is 1 of the 2 modules on that false floor-it should have a 820 number in the part number-if it is not obvious call parts dept. and cross reference numbers-unplug module and you won't have worry about that annoying alarm anymore-hopefully i have been helpful
Mar 24, 2009 | 1987 Mercedes-Benz 300-Class
Getting false alarm from laser. Laser alarm keeps
If the laser continuously falses even with the car's ignition turned off, then your radar detector has an internal electronics problem. If your radar detector frequently or nearly continuously falses for laser while you are driving even in the middle of nowhere, then most likely the cause of the problem is either poor power and ground connections or electrical noise within your vehicle's electrical system. Jump over to radardetector.net for help in resolving these issues.
Mar 15, 2009 | Passport 8500 X50 Radar Detector
2006 Honda odyssey. Security alarm activates randomly. How do I prevent it?
I am assuming that your Odyssey has a factory installed alarm system. If yes, then it is a basic door and ignition sensor to trigger and therefore should have no false trigerring. If it activates (with no) randomly even when not triggerred, then it can only be further assumed that door locking/sensor mechanism is getting false readings. Any thing out of the ordinary with the doors? (especially driver's side passenger doors).
You may want to check the electrical connection of the power sliding doors (Junction Switches). Like most door switches, they may be misaligned, worn out, corroded or simply deteriorated. Being an electrical device, moisture, rust, dust, grime and dirt may affect its performance.
If that does not correct the problem, you may want to check fuse #13 (the manual says #5) for continuity. There are some instances that remove and reinstall resets the alarm.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 19, 2008 | Honda Odyssey Cars & Trucks
Pool & Spa Logo
212 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
