Question about Philips SpeechExec Transcription Set 7177 (LFH7177)
After installation I tried to setup foot pedle and got this error Internal error occurred (exception has been thrown by the target of invocation)
Restaurant Pro Express: I am trying to set-up my credit card section with ...
You have your business setup as a quick serve. For some reason, First Data requires that your setup be retail or restaurant. You will need to reconfigure your setup. Or if you still have tech support time, PCAmerica has a patch that helps this issue. For some reason, First Data knows nothing about this. If you haven't locked into a contract with them, I suggest going with Mercury. Usually better rates, easier to setup, and their tech support will work with you to get issue resolved. If you need help getting reconfigured, send me an email. sysadmin@ccybernet.com
May 06, 2010 | Pc America Restaurant Pro Express
Can not start at a slow speed with foot pedal need to now how to adjust start speed
THE FOOT PEDLE IS NOTHING BUT A REASTAT. A REASTAT IS A WIRE WRAPPED AROUND A CONDUCTOR THE WINDINGS START OUT FAR APART AND GET CLOSER TOGETHER THE FARTHER YOU PUSH THE PEDLE DOWN . THE FAR APART WIRES ARE THE SLOW SPEED THE CLOSER ONES ARE FASTER SPEED
THESE WIRES WILL WEAR OUT OVER TIME OR CORRODE OVER TIME AND CAUSE THIS PROBLEM. TRY SOME ELECTRICAL CONTACT CLEANER AND SPRAY THE FOOT PEDLE INSIDE ANY WHERE YOU CAN AND LET DRY. MOST CONTACT CLEANERS ARE NONE CONDUCTIVE AND DRY IN MINUTES
Aug 15, 2009 | Consew 206RB
Error message when trying to go wireless!!
For the technical mumbo jumbo on this error go here: http://support.microsoft.com/kb/328560
to fix it, go to windows update (update.microsoft.com) and download the .net framework service packs
Jul 05, 2009 | Computers & Internet
Trouble setting up router
Make sure it is not a cross-over cable, and unplug the Ethernet cord at both ends and then re-connect. Also try a different cord. If you are doing this wireless I would recommend you using an Ethernet cord. You could also push in the little reset button on the back of the router for 45 seconds and then unplug the router then plug it back in and start over with the CD.
Jun 26, 2009 | Linksys WRT160N Wireless Router
Elevation has gone too high. foot rollers are hitting front plate
Precor Error E4, Incomplete Initialization Probable Cause Indicates that an incomplete upper PCA to lower PCA initialization occurred. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Run the initialization program. Caution: The treadmill's running belt will accelerate to the treadmill's maximum speed (12mph). DO NOT stand on the treadmill's running belt during the procedure.
  1. Set the on/off switch to the OFF position. Wait a minimum of 10 seconds to allow the internal power supply to discharge.
  2. Remove the safety key from the console and set the on/off switch to the ON position.
  3. Press INCLINE UP and SPEED DOWN keys together. While pressing these keys, replace the safety switch on the console. Continue holding the INCLINE UP and SPEED DOWN keys until the display goes blank. INIT will appear in the time window of the display. The EEPROM is now clear and reset. After a second, 1.25 will appear in the distance/calories window, 15.0 (the maximum incline) will appear in the incline window, and 12.0 (the maximum speed) will flash in the speed/pace window.
  4. Press QUICKSTART to begin the speed calibration process. Power bits will appear in the incline window, the target speed will appear in the time window and the actual speed will appear in the speed/pace window. At the beginning of the process, the target speed will be .5mph. The running belt will start. Once the actual speed reaches .5mph, the target speed will then change to 12mph and the running belt will accelerate until it reaches 12mph, then it will stop.
  5. When the running belt stops, the display will return to the user mode and the initialization process is complete.
Precor Error Code E4
Apr 30, 2009 | Precor EFX 546i Elliptical Version 4
Dlink WBR 1310 error 109 internal error
Remove the CD setup. Try calling your Dlink Manufacturer to help you install the WBR-1310 manaully.
Jan 03, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Print Workshop 2008
Describe Your Problem:Please describe the problem to get it solved
I bought this print workshop 2007 since around November 2006. It work wonderful until January or February of this year. I rely deeply on this programme in which i used every week until this message below stop me.
I did reinstall this programme.Still will not work.
Same message.I did click the continue button but the programme will freeze.I will go crazy if this does not work for i need the programme for work.
The message is below.
An unhandled exception has occured in your application. If you click Continue, the application will ignore this error and attempt to continue.
If you click Quit, the application will be shut down immediately.
Exception has been thrown by the target of an invocation.
Aug 14, 2008 | ValuSoft Print Workshop 2003 for PC
Philips SpeechExec Transcription Set 7177 (LFH7177) Logo
35 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
