Question about Icon Epic T60 Treadmill
Jazfit txo my treadmill goes up & down, ligths on display all work.but the walk/running bit wont move??
    Top Expert:
  • Icon Master
  • 12,223 Answers
See the video and proceed according. Lube the rollers bearing front+back with silicon or wax( depend of your mark, model) read your owner manual.
God bless you
Posted on Oct 18, 2013
I have a Jazfit 5333 treadmill - the speed and time are not working - led is fine but does not show time or speed just random numbers flash...how do I fix this??
Sounds llike you may have problem with your speed control module which will also be linked to yr time display . Call a treadmill tech for quote & availability of parts cost labour & service
Mar 02, 2015 | Exercise & Fitness
I have it all set up..programmed a work out...it starts to work..but the tread itself that you walk on wont run..what do I do?
From the User manual....here
http://servicedocuments.com/pdfs/_0005_SOLE/_0005_SOLE_01_Treadmills/003_OwnersManuals/2010_2011_SOLE/F63_F65_OM_810.pdf
'1.If the belt moves, but stops after a short time and
thedisplay shows "LS", run calibration. (on next page)
2.If you press start and the belt never moves, then
the display shows LS, contact service.
Sep 14, 2014 | Sole Fitness F63 Treadmill
Jazfit Running Machine
reset the machine, follow this steps and fix it. God bless you
However RUN the software calibration for easy diagnostic goes under the HOOD motor and follow the steps.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 06, 2013 | Exercise & Fitness
Precor 927 stuck in incline position
How long have you let it run for after turning it back on ? Some treadmills have a re calibration test built in and will incline to the max and work its way down. During this time you should simply walk away and not touch anything as it trys to calibrate its self. If not i will need more information on it
Oct 10, 2012 | Precor 927 Treadmill
Incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
May 08, 2012 | Exercise & Fitness
My proform 590 treadmill has these problems ; belt slips when running or walking ,speed goes up and down does not stay constant and you can hear motor noise increasing and decreasing in motor what should...
simple(maybe). go to the rear of treadmill,get the allen wrench that came with it,run at med-slow speed and adjust the rear roller with allen wrench. 1 turn per side 2 or 3 time then walk on belt until wont slip. all the problem is belt tension. also. make sure if it need lubrication under board and belt(some are lubless others dont).
good luck to you.
Feb 08, 2011 | Treadmill Doctor Proform 590Qs Treadmill...
I have a NordicTrack EXP 1000 X. Just bought it froma guy on craigslist, and it was working fine at his house. Messed with the belt tensioner bolts a bit when I brought it home, and now when I walk/run on...
It sounds like the belt is bogging down, this condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
The only certain way to test for a worn walking belt is to take a DC amp draw . Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test.
The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
May 23, 2010 | Nordic Track NordicTrack Treadmill, A2550
Weslo cadence treadmill wont work
I centered the belt on my tredmill and now it wont move at all. I tighted and loosened the belt. motor runs belt wont move
Feb 05, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Jazfit treadmill wont work
hai, please check control board transformer output
Jul 03, 2009 | Spirit Esprit ET4 Treadmill
Icon Epic T60 Treadmill Logo
65 people viewed this question
Top Icon Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Alienware X51
Alienware X51
Level 1 Expert
Are you an Icon Exercise and Fitnes Expert? Answer questions, earn points and help others
