Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch shx46a06uc/40 wont start - Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
The water supply line to my Bosch dishwasher (model # shx46a06uc/21) froze. We didn't realize this and tried to run the dishwasher. Now the line is unfrozen, but the dishwasher still won&#
Check for water supply to the valve. Check for 120vac at the valve during fill cycle. If you have both, the water inlet valve is bad, part number 00425458.
Jan 12, 2015 | Bosch Dishwashers
BOSCH SHX46A06UC DISHWASHER WATER IS COLD, DISHES ARE FILTHY
We had this a while back - it was something to do with a blocked filter right inside, which meant the hot wasn't coming on. The repair man had to put in a new filter, which had been blocked possibly cos we had been doing quick washes with environmentally friendly detergent, and that solved the problem.
Jan 21, 2013 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher shx46a06uc-30
the unit will try to complete the last command it was engage in before it went in the overfill safety mode. you must perform a cancel drain cycle to reset unit to default setting. Remember the drain cycle is 2 min and must be completed to reset main control. however if it went into a overfill status you have a leak and it generally comes from the pressure chamber on the lefthand side of unit where the water enters tub
Apr 17, 2012 | Bosch 24 in. SHX46A05UC Built-In...
My bosch clasixx wont start fills and drains ok but just clicks
Possible motor brushes, worst case scenario..motor fault. Put the dial to off, hold the start button whilst turning selector one click left to 30 easy care, turn the dial to 40 cotton (without going thru the off ie all the way round anti clockwise) press start. This will activate the motor test, if you get two lights flashing separated by a led that is off this is a motor fault. (Not necessarily the motor complete, also will indicate loss of contact in the brushes). If it is a model with a display it may show F05. Happy hunting.
Nov 21, 2011 | Bosch Washing Machines
Will not start on some wash programs, such as 40 or 60 fast spin, but will work when 40 woolens program selected, and other delicate programs too.
Check that the hot water tap is on or if the valve filter is blocked. If both these are ok, it may need a new hot water valve.
Hope this helps.
Use link item 171295 on page 4
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WFK2401UC%2f01&ESHOPTYPE=S
Aug 21, 2010 | Bosch WFK 2401
Bosch 25e water heater wont ignite
combi or standard if combi pressure too high and will be blowing off your high pressure release valve which would stop your boiler from igniting best of luck
Oct 27, 2009 | Bosch Water Heaters
My Bosch SHX46A06UC just runs and runs and wont stop.
The control board is not turning on the water heater due to bad control board, heater or limiting fuse.
May 10, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
19 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
