Question about Vehicle Parts & Accessories
Astra faults i have idle problem when engine is cold,have changed the maf sensor already still problem is there,i have holden astra 2001 automatic
    Sergeant:
  • 310 Answers
Do you have rmp meter in the car.automatic have higher rpm,
then regular.it chould some 1000 a 1200 rpm
Posted on Oct 18, 2013
2 Suggested Answers
  • 271 Answers
SOURCE: how to put a code in a holden astra for the stereo for car 2001
If,for example,your code is 2345 press button 1 twice,2tree times and ect.Finnish with button 5 to enter code
Posted on Dec 02, 2009
I have a 2000 Holden Astra Ts sedan automatic. It keeps stalling. Won't idle. Like it has a problem with either the fuel or a sensor. Engine light comes on. I've cleaned throttle body, no help. Some days...
Hi Dawn not sure if this fault has been solved yet? It sounds like two separate faults i don't think there connected. It would be a help if your friend had a code reader to see why the engine light comes on this may give a clue to what is going on. A stab in the dark disconnect the maf sensor and try. The ECU will set a default setting and the car will run as if it is connected. If this rectifies the starting/running issues fit a new maf sensor do not just leave it disconnected.If the fault remains a code reader needs to be hooked up to diagnose what is bringing on the engine light and that needs to be rectified 1st.The engine and transmission should run in harmony with each other so I wouldn't completely rule out the transmission issue being connected. The MAF sensor is on the air intake to the Air filter box Good luck
Jul 23, 2017 | Holden Cars & Trucks
Hi i have 2004 Holden Astra ,speedo not working,abs light and traction control light stays on , have put.computer on car will not let us in to engine area,has any body got any ideas
what the real problem
faulty diagnostic fault scanner tool
or no engine bay fault codes?
you could toss lots of new parts and not fix the faults
tow to a workshop or DIY fixes are possible if you can know the
specific fault codes
po500 seems to fit
https://www.obd-codes.com/p0500
a few things going wrong for that astra
fixable
speed sensor
wheel sensors faulty /abs module
if auto it will have strange gear changes and brakes unreliable
Oct 17, 2016 | Holden Cars & Trucks
Engine light not going off Holden Astra 2001
The check engine light will remain until you have dealt with the issue that is causing the engine malfunction.
The car will need to be scanned for fault codes generated by the computer to assist in diagnosing and locating the cause of the problem.
Mar 19, 2016 | Holden Cars & Trucks
I have 2003 astra Sri Turbo ts hatch the engine light is staying on but the car runs fine? Suggestions on what it could be?
Tags location of knock sensor
https://outofthebooks.top/term/location-of-knock-sensor
Need to locate knock sensor on 1999 camry V6. Where is ... Cabin filter · I have 2003 astra Sri Turbo ts hatch the engine light is staying on but the car runs fine?
Common problems with the Astra G [Archive] - Astra Owners Network ...
www.astraownersnetwork.co.uk > ... > Astra Chat > Astra G
Mar 20, 2007 - 100+ posts - ‎100+ authors
Also, rear disc brakes on the SRi models have a tendancy to seize up ... Pre 2003 2.2i.... about 10mins but the engine temperature stays fine when running. it .... theengine manigement light is constantly on, but car running like a dream! ..... I have a 2007 astra sport hatch sxi 1.6 and seem to have a strange ...
Holden Astra known issues? - Holden - Automotive - Whirlpool
forums.whirlpool.net.au > Automotive > Holden
WhirlpoolDec 12, 2012 - The TS Holden Astras, late 90s to early 2000s, stay away. Unreliable ...People give the TS Astra a lot of flak but its a superb car. We have one ...
Jan 20, 2016 | Cars & Trucks
Sorry 2003 holden astra city i put another engine into it and have done a new fuel pump all the sensors feul relays coil pack sparkies timing belt etc etc etc nothing left to change and when she starts she...
You need the computer that went with the engine you put in,it controls all the sensor.the sensors are set to that computer box.please let me how you get on
Mar 03, 2015 | Holden Cars & Trucks
On cold mornings 2001 Aurora is stalling at stoplights till it warms up
air temp sensor are maf fault on the air intake. most of the newer types have the temp sensor fitted to the maf sensor box tel's engine to pump more fuel in until engine temp sensor reaches it temp then turns off the add more fuel. if not this it can be a clogged up egr and some fuel clean should sort this out if you not competent at removing it and cleaning it out, also another part can be the idle controller dirty injector cleaner can clean this out to.
Mar 24, 2014 | 2001 Oldsmobile Aurora
2007 Toyota Matrix XR Idling is rough most when engine still cold. I already change the 2 oxygen sensors , PCV valve , MAF sensor and exhaust gasket.any suggestions?
Idling goes down it is about .8 and engine shake little.some times work excellentI replace spark plugs with new but it is same.any sugestions?
Jan 20, 2013 | 2004 Toyota Matrix
2001 tahoe idle rouh & stalling
Hello
The Engine and Automatic Transmission (not applicable to manual transmissions) in this vehicles drive train are fully electronically controlled by a computer called the PCM and TCM (Power Train Control Module, Transmission Control Module). When a problem like this or other drive-ability related problems occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM. Also always check fuel pressure for correct spec for your make and engine type.
Sep 19, 2012 | Cars & Trucks
Our holden/vauxhall/opel astra 2001 model has an intermittent problem with the gearbox. It get stuck in gear and we cant change it. We have to restart car to change gear and drive home in 1st gear. I...
opel astra ,which is marketed as vauxhall or holden ,also dawoo .right now what i need to know is and as a woman you have ommited to state, is it a manual or a automatic gearbox ,now remember the time zone difference iam in spain and you in vegamite land .Where my son is and i want to visit .
Dec 05, 2010 | Ford Aspire Cars & Trucks
Vehicle Parts & Accessories Logo
117 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
