Question about Honda 25cc 4-cycle Mini Tiller
My Honda tiller was working fine last time I used it but the I did not start it up until the following summer and then it started but dies off when I start tilling
SOURCE: Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
Posted on May 24, 2009
  • 16 Answers
SOURCE: I have a Honda mini tiller FG-100. Haven't used
You need to check your engine oil on a very level surface.
Its all too easy to over fill these engines with oil and the results can spell disaster if not rectified. On a level surface, with the machine level (not tipped forward) the oil should just be reaching the top of the threads for the bung. Any more than that and you have to much in.
This symptom can also be caused of incorrect storage .ie the machine being left on its side allowing oil to fill the exhaust box.
Check your oil level first then run the machine until the left over oil in the exhaust box has been burnt off. I would then advise either replacing the spark plug with a new one or cleaning your existing one and checking / replacing your air filter
Posted on Oct 13, 2009
  • 10865 Answers
SOURCE: Honda Tiller revs and works for 30 seconds and then shuts down.
Hello. you have some gunk in the carburator. Get a can of starter fluid or carburator cleaner aerosol and a helper. Remove the air filter and start it up. Spray a little starter fluid into the air cleaner to keep it running for three or four minutes and the problem should clear. If it does not clear the carburator will have to be disassembled, cleaned and rebuilt. j.
Posted on Jun 16, 2010
  • 5 Answers
SOURCE: i have honda fg 110 a mini tiller it starts fine
I have a similar problem.
The first time it was cause by the ethanol in the gasoline. It deteriorated the carberater rubber membrane so that it had a crack in it. The carberater would run lean. Take off the primer bulb and there is a plastic cover that goes over the rubber membrane. Remove that cover, and check the membrane. If this has a crack, you can order another from a honda dealer. It is about 14 dollars. After that just use ethanol free gas. Search the internet for a local source.
The second problem I had developed a little later. The engine would start, but if I gave it full throttle, it would quit. It got worse and worse till it would run at all. I noticed when I loosened the Gas cap, then the engine would run. And when I loosed the cap, I heard a whoosh, like air being sucked in.
So I figured the cap wasn't breathing like it should, which cause a suction in the gas tank. So I took a diaper pin and went through the holes on the inside of the cap, and through the little rubber plug in the center of the inside of the cap, several times. This allowed the cap to breath. Now it runs great.
Posted on Sep 11, 2011
  • 5 Answers
SOURCE: fg 110 mini tiller by honda
I have had the same problem.
The first time the solution was to replace the rubber membrane underneath the primer bulb. Take off the bulb, then remove the plastic part underneath the bulb. There is a rubber membrane underneath that. The ethanol in the gasoline tends to deteriorate the membrane. The honda dealers sell them for about 14 dollars.
The second time the problem was caused by the gas cap, not properly venting. In this case the engine would start and run, but when I gave it full throttle, it would quit.
It got so bad that it wouldn't even run. I noticed when I loosened the gas cap it ran great.
So I took off the cap, removed the inner parts, and got a diaper in and pushed it though the holes in the plastic part underneath the cap, and through the rubber plug in the center. I did this a few times and check with my mouth to see if I could pull some air through the cap. When it breathed satisfactorily, I put the cap back on the gas tank and it ran great. Now it runs better than new.
My mantis tiller with a honda gx22 engine starts then shuts off after approx. 30 sec.
If your unit has a primer bulb, start your engine . When it starts to die push your primer, if the engine comes back to life you have a carb issue.
Aug 09, 2014 | Mantis Tiller 4-Cycle Engine Handy Item...
MANTIS TILLER WITH HONDA GX25 ENGINE STARTS FINE BUT WHEN GIVEN THROTTLE DIES OUT. ALSO A LITTLE WHILE BACK OIL WAS COMING OUT OF CARB BUT THIS HAS NOW STOPPED. THIS IS A 4 STROKE ENGINE WITH APPROX 4...
I also have Mantis tiller for 2 years. From the very beginning I had a problems. I was referred by Mantis to the repair store and was charged $90.00 for oil drainage. The second time I was waiting for handle replacement for ~ 1 month. This tiller can't handle even little jobs and the warranty doesn't worth a dime. Maybe I will be more successful using it in my living room . I have an equipment with Briggs and Stratton engines and I never had a problem.
To me Mantis mean big advertisement and waste of money.
Feb 20, 2011 | Honda Hmantis Mantis Garden Tiller with...
Runs fine until I engage the PTO and am on a slight incline.Starts to spit and sputter and cut off. Checked Plug Gap, Magneto Gap. Worked fine last summer. All I did this time was replace the blades....
check your fuel lines for clogging if it ran fine last year means you have a clogged fuel line somewhere or the carb itself is stopped up disassemble the carb and do a visual inspection also use B12 chemtool carb cleaner use both the spray and the fuel cleaner treatment i know for sure your problem is related to ethanol fuel hope this helps good luck and always run your equipment completely out of fuel for long term storage or between seasons
Apr 07, 2017 | Mtd Garden
I am borrowing my father-in-law's chainsaw. He is only here in the summer. I used his pre-mixed gas from last summer. It started well and ran super for about 20 minutes and then it faded, like short of...
sounds like the carburetor's getting plugged up. First, sta-bil doesn't burn that great, so you may want to dump it and start over. If the fuel has already sat for that long, sta-bil won't help it anyways. You want to start with fresh gas, with the proper mixture. If that doesn't solve it, you can look at the wide open mixture screw and see if you can tune it better.
Jan 22, 2010 | Mantis 2-Cycle Tiller
1999 honda 4 cyl non v tech starts and dies does not idle just starts and dies until i try to start it like ten times then it will start and idle fine
Sounds like fuel problem.Check fuel pressue,make sure pressure is up to specs.If not,change fuel filter and fuel pressure regulator may be bad.
Sep 13, 2009 | 1991 Honda Accord
2002 Honda Passport just stopped
alternator on its way out, replace alternator bushing.
Jul 02, 2009 | 2002 Honda Passport
Engine won't keep running when using the throtle.
Hi Don. There are two adjustment screws on the carburetor. Start the engine and while it is idling, turn the screw closest the engine (low speed adjustment) counterclockwise until it starts to falter, then back a 'hair' and try the throttle again. If that doesn't work, I would recommend doing what I usually do... put a new carb on and be done with it! Carb is a Zama C1U-K54A
May 19, 2009 | Mantis Tiller
Ryobi Model 65020 gas tiller dies when engaging the throttle
sounds like you need to adjust the carburator
Apr 25, 2009 | Ryobi Cultivator
Honda 25cc 4-cycle Mini Tiller Logo
50 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
