Code eu24 comes up on dash - what does this mean?
SOURCE: PANASONIC CU160C53XP
BEST WAY IS TO GET AHOLD OF THE MFR'S TECH SUPPORT LINE EASILY OBTAINED FROM YOUR SERVICE MANUAL OR INFO (NOT SURE OF STATE)
SOURCE: Engine light is on, Toyota Corolla 140I, 2004
DTC P0134 OXYGEN SENSOR CIRCUIT NO ACTIVITY
DETECTED (BANK 1 SENSOR 1)
SOURCE: kia spectra fault code 1586. What does it mean?
http://www.troublecodes.net/Kia/
Sounds like you need to replace your ECM for your Transmission.
SOURCE: fault code
Check your cable connections to the ECU. The "Can" in question is the information Bus, so the chances are that either a cable or connector has become loose. If you can't find a harness fault, then it would most likely be an internal fault with your ECU. Sorry!
