Question about Husqvarna Garden
How much oil does a Kawasaki FH680V 23HP take?
  • 39 Answers
1.8 quarts
Posted on Oct 18, 2013
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: hi,im looking for valve clearance specs for the
The adjustment is .003 - .005. You must hold the rocker arm by lifting up on the valve depressing side and pressing down on the push-rod side while making the adjustment. Any other means of adjustment and it will be incorrect.
Below is quoted from the service manual without pictures
(FixYa Note TORQUE on lock screws is 61 inch pounds)
Valve Clearance Inspection
NOTE
?? Valve clearance must be checked when the engine is cold (at room
temperature).
• Remove the rocker cover (see Cylinder Head Removal).
• Place the piston at top dead center (TDC) of the compression stroke
turning the crankshaft clockwise facing the flywheel.
No.1 Cylinder:
?? The left projection [A] on the flywheel is faced with the right leg [B]
on the #1 ignition coil [C] as shown.
?? Check the intake and exhaust valves are closed completely, if not turn
the flywheel one turn (360??) clockwise and face the left projection with
the right leg again.
No.2 Cylinder:
on the #2 ignition coil [C] as shown. Follow No.1 Cylinder alignment.
• Then check the valve clearance.
?? Using a thickness gauge [A], measure the valve clearance between
the rocker arm [B] and the valve stem end.
If the valve clearance is incorrect, adjust it.
Valve Clearance (when cold)
Intake, Exhaust 0.075 0.125 mm (0.003 0.005 in.)
Thanks for using FixYa.
Kelly
Posted on May 19, 2010
SOURCE: What cooling hydraulic oil is used in a cobra zero turn mower
Well yes and yes. It is engine oil but it is synthetic. That is what many smaller hydro units use.
Posted on Aug 10, 2012
Testimonial: "Very helpful info. Thanks heaps."
KAWASAKI FH680V NEEDS CARBURETOR ADJUSTMENT
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Kawasaki Engine, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.encoreequipment.com/wordpress/wp-content/uploads/2012/06/17hp_FH500V1.pdf
Kawasaki FH680V AS01 4 Stroke Engine Parts
Kawasaki FH601D Owner Manual
Kawasaki 23 HP Rough Idle FH680V
Jul 09, 2016 | kawasaki Engine FH680V-FS06S
Toro zero turn mower with Kawasaki 691v 24.0 horse motor starts cutting out and smoking after running for about 20 minutes.
Check the oil to make sure you don't have gas getting in your oil. If that's not a problem then you may have a leaking head gasket.
Sep 29, 2013 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Oil in carburetor
Make sure your air filter is clean, if it gets dirty and or plugged then it causes it to **** oil out of the crankcase through the pcv valve
Oct 06, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
23 hp fh680v motor wont start carb keeps filling up with fuel but plugs are dry
perform a compression test low compression will not draw in fuel into the cylinder see them blow head gaskets around 2500 hrs
Sep 24, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Aug 10, 2012 | kawasaki Garden
How do i adj the valves on a 23hp kawasaki ?
You need to remove the rocker arm cover. Then most engines have a set screw and a locking nut that hold the valve rocker arm on. Loosen the locking nut and with a feeler gage make whatever adjustment you need (tighten or loosen) then holding the adjusting screw from turning, tighten the lock nut. It is not very hard to do and remember that they are all metric fasteners.
May 19, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Kawasaki fh680v 23hp will not start at random. Coils are good, fuel pump, filters air and fuel, plugs and battery are all good. Valves are adjusted correctly and one head gasket has been replaced. It will...
Check solenoid on the back of carb! I just had a similar issue with the same motor, would start rite up but had no power! new fuel pump coils, plugs ect I found the ground wire going to the coils were zip tied to manifold and rubbed through on the underside of wire never saw it 2 days later ripped it apart again and bingo found it taped it fixed problem.
Aug 12, 2010 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Garden Logo
286 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
