Question about Garden
I have a Ferris ProCut Z with a 23 HP Kawasaki FH680V engine. How much oil does it take and what type of oil filter do I need?
  • 22 Answers
SOURCE: engine smokes when first cranked
this sounds normal to me
Posted on Apr 03, 2009
mickey813
  • 472 Answers
SOURCE: hour meter flashing hours and oil
soundslike the oil sensor is bad
Posted on Oct 15, 2009
aquaman987
  • 927 Answers
SOURCE: I Have a FH680v 23
Find the carburetor and take a look inside. Don't buy any kit until you visually inspect the bowl, float and seal. The float could have gas inside. If you can get inside the carb, then you may be able to see the problem. You are also right, it may need a cleaning.
Gary
Posted on May 08, 2011
  • 6468 Answers
SOURCE: My lesco viper 54" 23 hp kawasaki engine zero turn mower dies down when mowing. What could cause this?
plugged fuel filter?binding governor linkage?
Posted on Jun 30, 2012
  • 2239 Answers
SOURCE: 23 hp Kawasaki FH680v engine losses power when engaging pto!
We had issues in the UK with issues like this, they would blacken and soot up the plugs and start to run on on cylinder, there was an internally vented carb rather than the externally vented carb to cure this.
Posted on Aug 10, 2012
KAWASAKI FH680V NEEDS CARBURETOR ADJUSTMENT
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Kawasaki Engine, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.encoreequipment.com/wordpress/wp-content/uploads/2012/06/17hp_FH500V1.pdf
Kawasaki FH680V AS01 4 Stroke Engine Parts
Kawasaki FH601D Owner Manual
Kawasaki 23 HP Rough Idle FH680V
Jul 09, 2016 | kawasaki Engine FH680V-FS06S
Oil in carburetor
Make sure your air filter is clean, if it gets dirty and or plugged then it causes it to **** oil out of the crankcase through the pcv valve
Oct 06, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
23 hp fh680v motor wont start carb keeps filling up with fuel but plugs are dry
perform a compression test low compression will not draw in fuel into the cylinder see them blow head gaskets around 2500 hrs
Sep 24, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Aug 10, 2012 | kawasaki Garden
What cooling hydraulic oil is used in a cobra zero turn mower
Well yes and yes. It is engine oil but it is synthetic. That is what many smaller hydro units use.
I Have a FH680v 23 hp engine on my mower and raw fuel is coming out of the exhaust sounds like a stuck float is my theory correct and if so is there a rebuild kit or just a good cleaning will do the...
Gary
May 08, 2011 | kawasaki Garden
Lost owners manuel and need to know what type of engine oil to use for a Husqvarna 25-HP V-Twin Hydrostatic 54" Garden tractor
if engine is briggs use briggs sae 30 oil also change out filter use briggs black std oil filter or yellow filter if els version
if engine is kohler use kohler 10w/ 30 oil and use kohler oil filter
if its honda use 20w/50 oil and use honda oil filter
if its kawasaki use 20w/50 and use kawasaki oil filter
cheers pauly 46
Mar 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Kawasaki fh680v 23hp will not start at random. Coils are good, fuel pump, filters air and fuel, plugs and battery are all good. Valves are adjusted correctly and one head gasket has been replaced. It will...
Check solenoid on the back of carb! I just had a similar issue with the same motor, would start rite up but had no power! new fuel pump coils, plugs ect I found the ground wire going to the coils were zip tied to manifold and rubbed through on the underside of wire never saw it 2 days later ripped it apart again and bingo found it taped it fixed problem.
Aug 12, 2010 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
