Question about Garden
Craftsman chainsaw40cc engine clatters when I pull cord to start has good compression and spark
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Check a couple of things... pull the muffler off and look at the piston... if it's not smooth then bummer
check the ignition coil area and the recoil area
Posted on Oct 20, 2013
steve_lima
  • 181 Answers
SOURCE: husky 372 xp stopped working?
you need to check to see if the piston is scored.pull the muffler off the saw and look inside.the piston is right there.if the piston is scored all you can do is change the piston and cylinder assembly.if the saw is new it might be under warranty.check with who you bought it from.most saws have a one year for consumer use.....let me know if this helped...................
Posted on Jun 02, 2009
  • 255 Answers
SOURCE: pull cord difficult to pull..removed from saw it
Make sure someone hasn't run this saw without the oil in the fuel mixture. It is possible it is dry and some galling is happening. Or - if this saw is equipped with a compression bleeder (for easier starting), this could be not functioning and you're pulling through the normal compression (which can be a bit feisty!). Check for misalignment of some type having to do with the pull starter - check that the cord spool isn't rubbing on the housing when you pull. Good luck.
Posted on Nov 30, 2009
  • 4088 Answers
SOURCE: Compression in cylinder too strong to pull starter
We have a Husky 435 that does the same thing. Found that the engine is trying to fire after first pull. Try setting the choke at 1/2 after first pull, but don't bump the throttle which will release 'fast idle'. This process seems to limit the 'kick back' effect. It also helps if you have a strong arm. Good luck!
Posted on Nov 25, 2010
  • 82 Answers
SOURCE: cannot start saw because of
Not being able to pull the start cord because of "compression" is usually a sign that the cylinder head is full of fuel and/or oil. Take the spark plug out and try to pull again. look at what is in the cylinder, fuel mix or chain oil. If the engine turns over, pull several time to clear the cylinder. Clean the plug and put it back. Gas/oil in the cylinder means it is leaking into the crankcase. If it is chain oil in the cylinder, there most likely is a crack in the crankcase. If it fuel look for a leak the allows the fuel to get into the crankcase when it is stored.
Posted on Apr 17, 2011
kel1guy2002
  • 3740 Answers
SOURCE: Can't pull the starter cord,
Hi and welcome to FixYa, I am Kelly
Remove the muffler and clean out the exhaust port and screen. You will have to disassemble the muffler and clean off or replace the screen item 8 of this link:
http://www.partstree.com/parts/?lc=echo&mn=CS-330T++S%2FN%3A+C08611001001+-+C08611999999&dn=7946
Before taking the muffler apart... unhook the spark plug and just pull it though with the muffler removed. If it pulls normally you know you have found the problem.
If it still pulls hard...check the exhaust port of the cylinder head for 2 tiny holes (not screw holes) Some have them some don't depending upon the year of the saw. If you do find 2 small holes that appear clogged with carbon... do your best to clean them out.
Thanks for choosing FixYa,
Kelly
Posted on May 15, 2011
Testimonial: "TRIED SOULTION BUT THAT DIDN'T HELP."
4 cycle craftsman mini tiller won't start,makes clicking noise when I pull the pull cord
The clicking noise might be significant...
In order to start and run an engine needs compression, timing, the correct amount of fuel reaching the combustion chamber and a good quality spark.
Discovering why an engine will not start is a process of checking and ensuring all the items on the list are functioning correctly. When you have done that the engine will start.
If the engine doesn't start then it is wise to go through the list again because something got missed the first time - maybe there isn't as much compression as there should be, maybe a valve is sticking or bad, maybe the timing got messed up, maybe the spark isn't good enough...
Pulling the starter 50+ times is a lot of unnecessary wear and tear on you and the machine. Take a deep breath and start again, do the work and do it well and three or four pulls should be enough.
May 29, 2017 | Craftsman Garden
My 4 stroke petrol lawnmower engine won't start - where's the problem?
Hi try a new spark plug check if it's got petrol check for spark put the lead on the plug before U put it in hold the side of plug on the mower & pull the cord to c if it's got spark.. check for compression put your finger over plug hole & pull the cord if it's got compression it should push your finger away good luck
Nov 16, 2016 | Garden
Pull Cord Stops...
could be valve needs set. if it isn't opening at the right time it wont release compression for it to start. it may be the shear key in the flywheel has sheared if you have hit something like a big rock or log or something causing it to die suddenly.
May 17, 2016 | Craftsman Garden
Small gas engine won't start
hi u need 3 things for a motor to run spark petrol and compression buy a new plug earth it on the side of the motor with lead on it and pull the cord to check spark///// next pull the cord with youre finger over plug hole to check for compression and last check for petrol in carby it might need a clean ......good luck. .
Sep 17, 2015 | Garden
Managemylife.com sears
You need three things. Spark, compression and fuel. Pull the spark plug and make sure it is not fouled and you have spark when cranking. Put your finger over the spark plug hole and feel for compression while pulling the engine over. There is a reed valve between carb and block that clogs and prevents fuel from getting to cylinder.
Aug 15, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
Stihl chainsaw MS460 Can't pull recoil
It could be the recoil is stuck. a couple of things to check. Take the clutch and chain cover off, remove the spark plug and manually try to turn the motor over by turning the clutch. If the motor/engine is not seized, take the pull start/recoil cover off and pull on the cord to see if it will work and that the cord returns back into the recoil automatically. Don't take the nut off the inside of recoil holding the cord spool on. If the engine is not seized, and the recoil now goes in and out by pulling the start cord handle reassemble and pull over the engine a few times. This a good time to check the spark plug is working, now put the spark plug back in and start the engine. It's a good time to clean the air filter as well while the chainsaw is mostly apart and clean all oily sawdust off the chainsaw in the crevices etc..
Jun 05, 2014 | Stihl Chain Saw Handle Models 044 046...
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
The pull string will not pull out to start the
Remove the starter mechanism from the saw and try to turn the flywheel--it should turn freely except when the piston is rising against compression. If ok, pull the starter cord and watch for twisted cord or a damaged/split spool. Try to turn the spool CW by hand to see if it is bound up by something. Was the starter cord just replaced? If so, maybe the return spring was over-wound and can't be turned further. Hope this helps!
May 21, 2010 | Craftsman Garden
I have a Cub Cadet cc4125 string trimmer not starting
need a little more information .. but look for the following .. take out the spark plug and look inside with a flashlight ... if the piston is moving with the rotation of the flywheel then you likely have a blown head gasket .. if there is no compression there wont be a load on the pull cord .. a cracked or damaged piston can also do this .. ... if the piston is not moving when you rotate the flywheel then you likely have a bad "shear key" sometimes called a "shear pin" .. thats usually a half moon shaped small metal part that keeps the flywheel locked rotationally to the crankshaft .. it is designed to shear off if there is an excessive sudden load on the engine .. the flywheel will then spin without turning the crankshaft .. the same thing will happen if you have broken the connecting rod .. (a rod failure is often preceded by lots of clatter from the engine) .. the head gasket or shear key are much more likely to be your problem .. if you cant see in the spark plug hole you might try using a straw to feel the piston motion .. its possible that without the spark plug in place the piston might move even with a bad shear pin .. because with no compression the piston will move freely .. if thats the case you can stop the piston motion with a wood dowell thru the spark plug hole .. if it moves in spite of your dowell resistance then consider the head gasket option ..
Sep 19, 2009 | Garden
1996 yamaha virago 535. no power on top end,50mph tops-- pulled rear spark plug wire off with eng. running and no effect. looked at spark plug- Black and smelled of gas. Please --- any suggestions??
1 st check compression on that cylinder by taking spark plug off and getting a compression tester and screw into spark plug hole then turn the engine over and if the compression goes over 100psi/7.5 bar then your ring are ok a picture below will demonstrate get back to me if the ring are ok i have more solutions d292560.jpg
Aug 26, 2009 | 1996 Yamaha XV 535 Virago DX
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
