Question about OKI C3400n Laser Printer
A simple fix that solved it for my OKI C5650 "310/311:Cover Open"
In my OKI c301dn cover open, but it isn't
when cover open in oki c 301 dn then push pull switch is UN link and information show cover open in printers or copiers. just change push pull switch or clean that with ctc the switch you can search on casing were the cover is close and can push that.
Jun 03, 2015 | OKI Office Equipment & Supplies
How do you fix density shutter error and sensor calibration error on OKI C9650 Printer
The shutter protects the density sensors and keeps the windows on the sensors clean, until they wear out. Replace the shutter assy (part number 42755401) and clean the sensor windows.
If this doesn't solve the problem, you may be at the beginning stages of a broken gear for the top cover mechanism that protects the LED printheads when the cover is open. As a test, you can remove the 4 black protective covers from the printheads and see if your machine will calibrate itself. If it does, I recommend leaving the protectors off and just be extra careful of the LED printheads when you change toners...
Jul 06, 2013 | Oki Printing Solutions C9650 Led Printer
OKI error 310 and 311....
both are "cover open errors"
310 is top cover
311 is front cover
make sure both are closing properly.
Jun 18, 2010 | OKI C3400n Laser Printer
How to clean an OKI B4100 (new toner, blotchy printing)
Open the cover, remove the cartridge and vacuum carefully the interior. Clean the leds when the cover is open and it should work.
Apr 04, 2010 | OKI B4100 Laser Printer
Dear Sir(s) I have an OKI data OL400e the problem is "Message --Cover open" even i close it well Please advice Thanks
had the same problem. It is easily fixed.
On my printer a OKI C5750 is had to main covers, at the front (which you have to open to fix a paper jam) and a big cover on top (which you need to open to replace toners).
On the left is a piece of plastic which (when closed) presses on a switch.
When you open both covers, and close the top one, you can see it on the left when it comes down.
You can easily remove the error (only for a brief moment) by prushing the shining metal switch to the back.
But the problem is that one of the rollers is in a wrong position.
So just take a flat screwdriver and press on the bottom roller, and it will click and the problem will be gone when you close the covers.
Feb 11, 2010 | OKI OL 400e Led Printer
Close cover 310: cover open, but it isn't
Nov 23, 2009 | OKI C3400n Laser Printer
My OKI 5200 is saying it has a paper jam open front cover there is no paper jammed and i have looked everywhere for a problem and cannot find one. Still it won't print until the paper jam problem is...
Mine did the same once and although at first I was convinced it was the printer reading incorrectly, in the end, after opening all the parts that open up, I did find a sheet of paper wrapped around the rollers at the back.
Nov 17, 2009 | OKI C5200n Laser Printer
My Oki B4545 MFP alarm always on
Solution provided by printer manufacturer tech support which worked for me.
1. Open all doors (front & back)
2. Remove tonner
3. Turn off power
4. After 20 secs turn on power
5. Close back door
6. Insert toner
7. Close front door
Fixed now!
Jan 25, 2009 | Oki Electric Industry Oki - B4545 MFP...
Oki c7300
Error 051 is a CU fan error.
It is solved by first replacing fan then the CU board.
I would call the seller or 1-800-OKIDATA
If you're comfortable with a screwdriver I would take the cover off
and look at the fan to see if anything is obstructing the flow.
Mar 24, 2008 | OKI C5200n Laser Printer
OKI C3400n Laser Printer Logo
60 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
