Question about Toys
I have a Ferris Procut Z with Kawasaki FH680V 23HP engine. How much oil does it take and what oil filter do I need?
2 Suggested Answers
  • 39 Answers
SOURCE: How much oil does a Kawasaki FH680V 23HP take?
1.8 quarts
Posted on Oct 18, 2013
KAWASAKI FH680V NEEDS CARBURETOR ADJUSTMENT
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Kawasaki Engine, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.encoreequipment.com/wordpress/wp-content/uploads/2012/06/17hp_FH500V1.pdf
Kawasaki FH680V AS01 4 Stroke Engine Parts
Kawasaki FH601D Owner Manual
Kawasaki 23 HP Rough Idle FH680V
Jul 09, 2016 | kawasaki Engine FH680V-FS06S
Toro zero turn mower with Kawasaki 691v 24.0 horse motor starts cutting out and smoking after running for about 20 minutes.
Check the oil to make sure you don't have gas getting in your oil. If that's not a problem then you may have a leaking head gasket.
Sep 29, 2013 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Oil in carburetor
Make sure your air filter is clean, if it gets dirty and or plugged then it causes it to **** oil out of the crankcase through the pcv valve
Oct 06, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
23 hp fh680v motor wont start carb keeps filling up with fuel but plugs are dry
perform a compression test low compression will not draw in fuel into the cylinder see them blow head gaskets around 2500 hrs
Sep 24, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
What cooling hydraulic oil is used in a cobra zero turn mower
Well yes and yes. It is engine oil but it is synthetic. That is what many smaller hydro units use.
Aug 10, 2012 | kawasaki Garden
After changing oil that was like grease flushing out made sure the oil was pumping the engine starts and runs good,buts starts blowing oil out and runing hot.the oil looks like coming from the seal out the...
It sounds like this engine has a large amount of blowby. Remove the oil dipstick and see if it looks brown. If it is the engine has overheated and needs to be rebuilt.
To see how bad it is put your palm on the fill tube (without the dipstick installed) start the engine and see if you feel pressure. If you do the engine is blowing the compression generated from the combustion of the fuel past the piston rings and pushing oil out of the preather or wherever it can.
Sorry for the bad news. Take the engine to a good dealer like www.arcolawn.com and have them perform a leakdown test to tell you if it is worth rebuilding or not.
Good luck
Dec 12, 2010 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Kawasaki fh680v 23hp will not start at random. Coils are good, fuel pump, filters air and fuel, plugs and battery are all good. Valves are adjusted correctly and one head gasket has been replaced. It will...
Check solenoid on the back of carb! I just had a similar issue with the same motor, would start rite up but had no power! new fuel pump coils, plugs ect I found the ground wire going to the coils were zip tied to manifold and rubbed through on the underside of wire never saw it 2 days later ripped it apart again and bingo found it taped it fixed problem.
Aug 12, 2010 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Open Questions:
Toys Logo
16 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
